i've been having some issues with my abs system in my 95 legacy ls sedan. what will generally happen is if i have someone sitting in the rear seat passenger side (unless it is a heavier person then just the back seat in general), when i go over a bump or a dip the abs light will go off. then the next time i brake, there's a loud stuttering and vibration in the pedal. it takes a bit longer to slow down when that happens. though afterwards the brakes seem to work fine. i dont know if the abs system is working right, but i can still use brakes. if i restart the car, the light goes off and everything is back to normal.
basically, it seems that if the rear passenger side wheel gets depressed a certain amount, the abs goes off. i've taken it to my local dealer twice now for this problem, and they haven't been able to figure it out. anyone have any ideas? thanks in advance.
mike d.
