04-04-2011, 12:42 PM | #1901 |
Member#: 118141
Vehicle:95 'lifted' legacy |
04-04-2011, 12:47 PM | #1902 | |
Member#: 118141
gravel express awesomeness!! Are you going to try and source the rear tire carrier also??
Sounds like a great setup! We want profile photos too! Quote:
04-04-2011, 12:57 PM | #1903 | |
Member#: 118141
Are those gen 1 Forester steelies? what size tires?? Your IMP reminds me of my wife's old 93 Imp that we put gen 1 FOR struts on stock 99 FOR struts and springs 99 FOR struts and springs front, 99 FOR struts and 95 LEG springs rear (leveled out the rear better) |
04-04-2011, 01:04 PM | #1904 |
Member#: 118141
compare FOR strut-lifted 93 imp with OB 15's to stock 98? IMP
Twas a good car that we bought from a friend for $1, then fixed up!!! Spring time in Moab!! |
04-04-2011, 01:09 PM | #1905 |
Member#: 103179
SCIC
Vehicle:2017 Focus RS SoCal F4 #21 |
04-04-2011, 04:28 PM | #1906 |
Member#: 2272
BAIC
Vehicle:2019 Macan 4cyl 1993 Impreza FWD WRX swap |
04-04-2011, 09:22 PM | #1907 |
Member#: 80569
NWIC
Vehicle:1996 OBS |
^Yup forester steelies on 205/70/15 tires.
04-05-2011, 10:23 AM | #1908 | |
Member#: 118141
Could you extend it all the way over towards the passenger side to cover the canister and the rest of the open space of and next to the spare tire well? Did you fab it from something or is this a product intended for this purpose? curious and now interested. . . |
04-05-2011, 10:47 AM | #1909 | |
Member#: 103179
SCIC
Rear diffusers are common on track cars where high speed stability and good aerodynamics make a big difference. The one he has looks like the 07 STI OEM diffuser. I have the same one except its good at catching a LOT of mud and drying up to become a giant weight . The one below is made by APR performance. |
04-05-2011, 06:57 PM | #1910 |
Member#: 2272
BAIC
Yes, its just a stock diffuser. It was cheap, and I was the first one to put one on a GC, but I've had to chop it a bit to fit it with my lift (lowering the swaybar caused it to run into the diffuser).
04-05-2011, 10:09 PM | #1911 |
Member#: 118141
Cool, I just got educated on tarmac stuff!
Thanks! Last edited by skunkman; 04-13-2011 at 11:13 PM. |
04-06-2011, 01:01 AM | #1912 |
Member#: 275505
Loving all the dirty subarus. Its they way they belong
04-06-2011, 02:32 PM | #1913 |
Member#: 1594
Vehicle:1999 2.5 RS 2002 Legacy |
Here is my Impreza.
04-06-2011, 05:55 PM | #1914 |
Member#: 2272
BAIC
^^^ Nice! Another Aegean Blue V2 L
Oh, and anyone need some snow? |
04-07-2011, 03:59 PM | #1915 |
Member#: 145996
Hey guys I have a 2002 wrx with stock suspension that I use to rip up the fields once in a while. I'm not looking to lift it but I do want to get the saggy butt spacers. What are the biggest spacers I can get without having to get longer studs and what would be a nice tire to fill out that wheel gap with stock 16" wheels. Car is mainly used as a daily driver but taken off road everyday too haha
04-07-2011, 06:19 PM | #1916 |
Member#: 2272
BAIC
3/8" are the biggest spacers without needing longer studs.
04-07-2011, 06:57 PM | #1917 |
Member#: 251060
Vehicle:2008 Impreza Outback Black |
Nevermind I'm retarded and dont read posts.
04-10-2011, 02:53 AM | #1918 |
Member#: 144352
Vehicle:2006 Impreza Wrx TR Grey |
I know this is the wrong forum but I just want to get it out there... I have a 06 wrx tr and just replaced the rear O2 sensor and just got the same p2097 code again? any thoughts?
Ps the car is stock except for aftermarket downpipe and no heat shield for the turbo ( both of which the previous owner did). Also, the code came back on after less than 50 miles after the dealer said they "fixed" it. |
04-10-2011, 02:40 PM | #1919 |
Member#: 2272
BAIC
The aftermarket downpipe could be causing the code.
04-11-2011, 10:39 AM | #1920 |
Member#: 244843
Vehicle:2006 WRX Sport Wagon 401whp/446wtq on 23.54psi |
yeah the aftermarket pipe has different airflow/turbulence that the stock tune isn't calibrated for. So, in essence you could always do an O2 removal kit (not sure how well they work in tricking the ECU into believing that the sensor is still there). The easiest thing I've found is to use a COBB to just deactivate the code. If you know someone with the same year and model that has the AP2 as long as they have the race tuner software they can create you a stock map and go into the parameters and deactivate the particular code. I have the software I could do it, but my access port and software is for just a standard 06 WRX not sure if that would make a difference since yours is the TR. If you pm me I can send you a map with the code deactivated as long as you can get a hold of an AP2 and map manager that comes with the AP2 for an 06 to load it on to your cars ECU, we can give it a try.
04-11-2011, 07:01 PM | #1921 |
Member#: 2272
BAIC
Found a skid plate!
Its from like an '83 GL wagon, EA81 skid plate AND a awesome little bash bar that came on those wagons I didn't know about. Found both at a pick n' pull for $20 This is the kind of wagon that skid plate and bar came from: All it required was drilling a couple holes up front. The rear holes on the subframe matched up exactly |
04-12-2011, 09:46 PM | #1922 |
Member#: 2272
BAIC
Photos from today, actually getting it dirty for the first time
04-13-2011, 08:41 PM | #1923 |
Member#: 2272
BAIC
I started a Unofficial Lift thread in the Suspension forum, I could use everyone's input from this thread:
http://forums.nasioc.com/forums/show....php?t=2166272 |
04-13-2011, 10:08 PM | #1924 |
Member#: 212805
NESIC
Vehicle:2000 WRSX Blue Ridge Pearl |
having a little fun in high waters |
04-13-2011, 11:16 PM | #1925 |
Member#: 118141
Chamois, or just plain Sham? | Lifino | Interior & Exterior Modification | 8 | 10-02-2013 08:01 PM |
SOA gotta love 'em or just plain hate 'em | kalbo-1 | Warranty Issues & SOA Problems | 1 | 01-19-2004 08:29 PM |
Hot or Not or Just Plain Ok.... | n20x3whitewrx | Member's Car Gallery | 28 | 07-29-2002 10:05 AM |
McRae: Dedicated or just plain nuts? | SubaruStu | Motorsports | 2 | 03-20-2002 09:55 AM |
Jinxed? Or just Plain UnLucky??!! | silverSurfer | General Forum Archive | 6 | 06-30-2000 10:27 PM |
