12-12-2004, 02:58 AM | #1 |
Member#: 43070
how to change the foglight bulb
As stated on the title. On a 02 WRX. Used search but cannot find it. Info will be greatly appreciated.
12-12-2004, 07:02 AM | #2 |
Trust no one
Moderator Member#: 11170
Tri-State
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
You have to remove the foglight from the bumper, three 10mm bolts (there is an adjusting screw in one corner, don't turn that). Once it's out unplug the connector (you don't have to but it makes it easier), open the rear cover and the bulb is there.
12-13-2004, 12:23 PM | #3 |
Member#: 52713
Vehicle:2004 WRX (black) 2000 RS (red) |
What about for an 04?
12-13-2004, 12:31 PM | #4 |
Trust no one
Tri-State
I haven't looked at the fogs on an 04, but I'd assume it's similar as far as having to remove the lights from the bumper to get to the bulbs.
12-13-2004, 07:07 PM | #5 |
Member#: 45212
NWIC
Vehicle:2004 WRX JBP |
it's pretty simple... here's how i did mine, i lifted my car, removed the fender well lining (becareful with those black pins, as they are easy to break) by using a flat head screwdriver to pry the middle part then pull the rest of the pins. then crawl under your car u will see your foglamp housing then unplug the wire and then push the holder of the bulb. thats it, easy.... i have to admit that the driverside bulb is kind PITA to replace other than that it's pretty easy. if you have anymore questions just fire away.
hope this helps. |
12-14-2004, 03:06 AM | #6 |
Member#: 59993
International
Vehicle:Ass, grass or cash no one rides for free!! |
for the 04's it's way easier if you take the fog light surround off. trust me. it's not that hard to figure out once you get that off.
04-27-2005, 02:29 PM | #7 |
Member#: 41233
RMIC
Vehicle:2008 Impreza 2.5i RIP: 2002 Impreza 2.5 RS |
My foglight on the driver side is out. I've changed the foglight on my Saturn before, how much would labor be if I took it to a dealership?
04-27-2005, 02:38 PM | #8 | |
Member#: 4597
TXIC
Vehicle:2011 Mitsu Outlander Sport (Ex-Suby owner X3) |
just remove the three bolts. the upper inside one is the adjustment screw dont turn that as mulder said. twist off the back cover remove and replace. |
04-27-2005, 02:48 PM | #9 | |
Member#: 41233
RMIC
04-27-2005, 03:58 PM | #10 |
Member#: 4597
TXIC
55w is stock wattage. i say go ahead and replace both. thats what i was talking about 15 minutes. i would say go with some hella yellowstars. although if you just want to replace one, go to autozone and get their 55w sylvania oem replacement, should be the same color and brightness. but for about $5 each you might aswell upgrade to hellas www.rallylights.com
04-27-2005, 05:06 PM | #11 |
Member#: 41233
RMIC
Thanks ATX25RS.
04-27-2005, 06:50 PM | #12 |
Member#: 4597
TXIC
oh yeah after all that i forgot to mention not sure if you got the bulb size, but they are h3's
04-27-2005, 10:25 PM | #13 |
Member#: 33330
Vehicle:2002 WRX 5spd sedan WRB |
PIAA Ion Gold. They rule.
Similar Threads | ||||
How to change brake light bulb | chapelhilldoc | Electrical & Lighting | 0 | 05-28-2009 06:07 PM |
How to Install H3 Foglight bulbs? | johnnybryan | Interior & Exterior Modification | 1 | 02-18-2007 02:49 PM |
How to change the Low Beam bulbs by yourself? | faiwu | STi Forum Archive | 0 | 06-30-2003 07:26 PM |
How to change fog light bulbs | mo168 | Interior & Exterior Modification | 8 | 08-22-2002 09:25 PM |
