12-13-2007, 06:31 AM | #1 |
Member#: 155937
South East
Vehicle:1995 Impreza w/EJ255 Red |
Electric throttle pedal problem
Lately when I'm shifting my RPMs are rising instead of falling when I put in the clutch. If I get my foot under the gas pedal and pull up a little it will stop. So it would seem that it's sticking a little the last few cm of it's travel. I was thinking maybe bending the spring perch to increase tension? Of a lube of some type but since the electric control modual is part of the pedal I'm not to keen on lube. Any ideas?
12-13-2007, 09:03 AM | #2 |
Member#: 2348
Vehicle:2006 WRX TR Steel Grey Metallic |
if your pedal is sticking i'd check to make sure its not getting stuck on the floor mat or any debris in the footwell. Other wise get your head down there and actuate the pedal, see where it binds and lube from there. I doubt the servo motor is sticking so it should be the mechanical side of it.
12-13-2007, 08:52 PM | #3 |
Member#: 162942
Vehicle:2006 STi Black&Gold Stage 2 |
Get it up to specs. ALthough I don't know what it is
05-15-2009, 02:21 PM | #4 |
Member#: 209216
I have an 06 and the idle stays high between shifts also. Onlyfor a few extra seconds. Feels strange when driving. Thought maybe it was to assist in keeping boost pressure up
05-15-2009, 04:40 PM | #5 | |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
OP - is your car DBW or DBC? Does this happen at partial throttle (normal driving), WOT, or both? How long does the RPM stay high? The issue I mentioned above only lasts a second or so and the RPM only rises by a couple hundred, if that. It also only does it when releasing from partial throttle, not WOT. |
FS:Ky DBW throttle body and throttle pedal | 02KyRex | Engine/Power/Exhaust | 0 | 07-02-2009 08:11 PM |
WTB: 2005ish STi DBW throttle pedal assy | dlatourette | Private 'Wanted' Classifieds | 0 | 01-11-2008 02:08 PM |
Throttle Pedal Switch | Norcalrallyist | Subaru Conversions | 0 | 09-16-2006 02:31 AM |
04' Throttle Pedal Sweet Spot????? | motomavrick | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 01-14-2004 08:29 PM |
Problem with the throttle pedal, and cable, maybe | JGard | Normally Aspirated Powertrain | 1 | 04-04-2001 12:04 AM |
