08-08-2004, 07:41 PM | #1 |
Member#: 60525
Vehicle:05 wrx sedan black |
engine balancing problems on lightned pulley?
does anyone know if you replace the stock power pulley that drives alternator, power stee. etc throws the engine out of balance which can do serious damge to your engine? ive heard horror stories on other cars but im not sure about subbys.
08-08-2004, 07:53 PM | #2 |
Member#: 63076
Vehicle:2004 Outback Sport Red! |
No. Its not a harmonic balancer.
08-08-2004, 07:58 PM | #3 | |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
08-08-2004, 08:14 PM | #4 |
Member#: 37870
Vehicle:2012 ISM WRX '16 Forester XT |
The crank pulley is the one to worry about with other cars/engines. As far as I know, Subaru does not use a harmonic balancer on the end of the crank (pulley) It is just a heavy two piece pulley with a rubber insert. That is what I learned before I put my lightweight crank pulley on. The other pulleys should have no effect on balancing at all (if they are made decent) My two cents. Brian
08-08-2004, 11:57 PM | #5 |
Member#: 53992
BAIC
Vehicle:SOLD CGM 2005 2.5RS 35 PSI -- in my tires |
Subaru Does NOT have a harmonic balancer due to the h4 or even h6 design. I have the full lightened pulley set (crank, alt and power steering) and all I have had problems with is going to fast...
08-09-2004, 02:39 AM | #6 |
Member#: 16523
The opposing piston design (H piston format) naturally cancels out vibrations from the engine.
08-19-2004, 05:18 PM | #7 |
Member#: 23535
SCIC
Vehicle:2015 WRX Galaxy Blue Pearl |
How long have you guys had your pulleys on? Just curious because I have one I haven't installed becasue I heard of the misfire codes and pulled timing problems they were creating if you didn't have any engine management (aftermarket, of course).
08-19-2004, 06:08 PM | #8 | |
Member#: 13793
Vehicle:2007 specB, 03 Ram '92 SVX-5 speed |
The part is heavy (for a reason) and expensive to manufacture (multiple steel components, adhesive, rubber). Why would Fuji use them if they weren't beneficial? Certainly the one piece machined pulleys sold are lighter and easier (read cheaper) to make. If they were so good (and cheap) FHI would have been using them for years, saving millions of dollars. Do the makers of these pulleys design engines or make parts? Todd |
08-19-2004, 09:16 PM | #9 |
Member#: 67127
Vehicle:3.3 I <3/h8 my GF3 1.8-2.5-2.2-2.5-2.2-3.3 |
08-20-2004, 01:02 AM | #10 |
Member#: 57120
Vehicle:1999 Forester Red |
So, is the engine internally balanced? Balanced on the crank rather than on the flywheel or flex plate?
08-20-2004, 02:12 AM | #11 | |
Member#: 60743
Vehicle:'95 Impreza L dirty and on jack stands |
08-20-2004, 03:02 AM | #12 |
Member#: 43539
Vehicle:95L 97L 03hedgehog 02 wag 180mph monster |
have you guys noticed a big difference when you installed the crank pulley
08-20-2004, 05:33 PM | #13 | |
Member#: 2272
BAIC
Vehicle:2019 Macan 4cyl 1993 Impreza FWD WRX swap |
08-20-2004, 10:25 PM | #14 |
Member#: 64673
NWIC
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
I just installed a 7.5" custom crank pulley. Barely lighter than the stock pulley but 2.25" larger in diameter. Have yet to drive it but starts and idles fine. It is for my supercharger since I cant make a smaller supercharger pulley.
08-21-2004, 12:27 PM | #15 |
Member#: 17984
Vehicle:1967 Barracuda 2000 OBSTi |
I hope you dont overrev your alternator
Engine advice needed - same problem on different engines! | EVT_Dan | Legacy Forum | 7 | 03-27-2009 08:34 AM |
Engine surging problems on Baja Turbo 2.0L | Loscocco | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 02-16-2009 03:39 PM |
Engine cut problem on stock MY05 WRX | Mutters | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 12-07-2004 01:41 AM |
balance problem? | ezatnova | Brakes, Steering & Suspension | 6 | 07-03-2002 05:40 PM |
Balance problem or brakes? | AudioFan | Brakes, Steering & Suspension | 4 | 02-19-2002 06:40 AM |
