09-23-2003, 01:06 PM | #1 |
Member#: 18958
BAIC
Vehicle:13 TDI pollutr Black as my heart |
diff between a 300hp wrx and 400hp wrx? (joke...and serious q inside)
nothing!
they both run 12.8 sounds like an old supra joke. so the serious question here is what can be done to avoid having such bad lag that the car can't spool the larger garret turbochargers and you end up with another 12.8 -13.1 second car with lots of power in 5th but no streetable power in any other gear? can tuning help reduce lag? what headers reduce lag the most? i know from MANY sources that the stock header design on the wrx is piss poor. also...what are some other ways (besides the obvious n20) to reduce lag on a big turbocharger setup? changing the housing? reason being is i read sport compacts article on the various tuner wrx's out there and the highest hp wrx ran a very average timeslip and probably made terrible power on a road course or autocross course as well. what kind of trick sare out there to keep this from happening? and are there any adapter kits to fit a t3 60-1...i hear that turbo would spool almost as quick as stock and make much more power than the vf30. reason being that im looking at a cheap vf30 right now...but am wondering what other options are out there. -Milin (looking to max out his sti injectors and walbro fuel pump which i am installing asap!)
09-23-2003, 01:15 PM | #2 |
Member#: 36797
South East
FP18G is the same price...
and it can do between 20 and 75whp more than a vf30 depending on your tune, the gas, and your mods. the spool seems to be pretty early, all i have heard is positive reviews from them
09-23-2003, 01:21 PM | #3 | |
Member#: 12454
Vehicle:10 Toyota Taco K8 SV650SF |
09-23-2003, 02:03 PM | #4 |
Member#: 37101
Vehicle:2008 WRX |
A forced performance Green recently made 425 awhp and made an 11.9 second pass at 121 mph on a completely ****ed clutch. And yes tuning can help to reduce lag.
09-23-2003, 02:05 PM | #5 | |
Member#: 23260
BAIC
Vehicle:Patr ick Willis for Rookie of the year |
Re: diff between a 300hp wrx and 400hp wrx? (joke...and serious q inside)
09-23-2003, 02:17 PM | #6 | |
Member#: 18958
BAIC
Re: Re: diff between a 300hp wrx and 400hp wrx? (joke...and serious q inside)
kind of like using a sniper rifle for skeet shooting.... anyways...i was hoping i could find a snail with enough lag that it wouldnt fry first gear (it would not spool too quickly in 1st...that would help) under normal use (i dont plan on dragging the car more than once or twice a year) id like to see some dyno plots. also...what kinds of tunes can you have for the cars? Can you tune the car to spool early and have a nice smooth "sports-car" powerband with the fp 18g? can it be tuned to spool around 3k with a full compliment of exhaust and header mods? also...anyone graphed out their lag with headers and a tune? |
09-23-2003, 02:52 PM | #7 |
Member#: 12454
Can you get positive boost pressure at 3k rpms with an 18G, i would sure think so, but is that going to be the point at which you are thrown back into your seat? Nope.. however with good tuning you can bring that point down to a reasonable rpm, maybe 4k rpms honestly i havn't had the chance to tune a car with an 18G so i wouldn't know.
I think your confusing boost threshold with achieving peak boost pressure or high boost pressure. The lag not hurting 1st gear is not going to work, because when that turbo spools up the car is going to rip towards redline in 1st gear I know it. |
09-23-2003, 02:54 PM | #8 |
Member#: 23260
BAIC
The only car I have ever been in with an 18G had full boost at 3500 RPM, however full boost was only 15psi and the car had a 2.4 stroker motor, not the stock 2.0. So based on that car I would estimate that a 2.0 would recieve full boost at around 4000 RPM as stated above.
09-24-2003, 01:56 AM | #9 |
Member#: 31555
My 18G on a flat road in third gear did the following boost levels with a roll-on at 2750;
3132=4.7psi 3465=8.0 3827=12.5 4182=18.6 4504=20.4 I have set my utec to hit max at 20psi or it would go higher. The car is fast and seems to actually out-race the the boost in third gear, I know it would actually build boost quicker in 4th or 5th gear. Bob |
09-24-2003, 01:33 PM | #10 |
Member#: 18163
Vehicle:2002 2.5 WRX MBP |
In a 4th gear pull I logged
18.5 psi at 3800rpms 22psi at 4100 rpms |
10-01-2003, 02:00 AM | #11 |
Member#: 44503
Vehicle:2006 Evo 840whp/E85 66 Chevelle, 468bbc/600hp |
Headers
Straight from Nathan's (TurboXS) mouth:
"Been there, done that! Every header we tested on the dyno sucked. I had the HKS headers on my car for a little while and hated every minute of it. I went back to stock manifolds after about a week and have been on stock manifolds ever since. " I have some designs floating around for a race header that wouldnt be too fun for oil changes that might help spool but will reduce ground clearance and make a few other things a whore. I am gonna build it and see. |
02-18-2014, 08:22 AM | #12 | |
Member#: 381985
Vehicle:2011 Wrx Sti Black |
02-18-2014, 08:42 AM | #13 |
Member#: 379357
Vehicle:2011 STI DGM |
11 year old thread bud
02-18-2014, 09:15 AM | #14 |
Member#: 341903
Vehicle:2016 STi Hyperblue |
02-18-2014, 09:49 AM | #15 |
Member#: 280177
Vehicle:2016 wrx LBP |
wow ..
02-18-2014, 11:41 AM | #16 |
Member#: 381985
Lol how the hell did I even stumble upon this? My bad my bad
02-18-2014, 12:20 PM | #17 | |
Member#: 246990
You must have been REAL bored to go that far back in history |
02-18-2014, 07:07 PM | #18 | |
Member#: 381985
02-19-2014, 01:08 AM | #19 | |
Member#: 246990
02-19-2014, 10:39 AM | #20 |
Member#: 381985
Okay thanks for the explanation mtarr07, makes sense
02-23-2014, 01:31 PM | #21 |
Member#: 378625
NWIC
Vehicle:2004 WRX Silver |
hehe, 11 year lag, we're not even discussing the same Subarus anymore!
what is the diff between a WRX and R1 WRX ? | Prelude | Canada Region Forum | 11 | 02-17-2006 09:28 PM |
whats the difference between a 300hp and 600hp neon on street tires? | dvang | Off-Topic | 16 | 09-30-2005 04:42 PM |
05 Impreza: Diff between RS and WRX | ERRM | General Community | 17 | 10-04-2004 08:31 AM |
diff between wrx and sti engine-wise | wonthanhboi | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 03-10-2002 03:35 AM |
Whats the Diff between WRX and WRX STi? | Jeff | General Forum Archive | 3 | 11-22-2000 06:52 PM |
