12-28-2004, 11:54 AM | #1 |
Vendor
Vendor Sales Rating: (0)
Member#: 20081
Vehicle:JDM IMPREZA's Gr8wheels.com |
JDM STi 5 Speed's DCCD & Non-DCCD & Tiptronic
We Include Everything to make your swap as simple as possible, NO ONE includes more!
PRICES LOWERED!!!! ~Version 5 Impreza WRX STi 5 Speed STi hardend gear transmission handle 300+Hp, Linkage, crossmember, driveshaft, R160 Diff, & 4 CV Axles. Low Miles! $2500.00 Also: ~1995 Version 2 WRX STi Type RA 5 speed hardend gear DCCD Transmission, DCCD ECU, DCCD roller knob, Linkage, driveshaft, Rear Lsd Diff, 4 Cv Axles, tranny crossmember. Between 45k miles. $3000.00 Also: 2002 LEGACY B4 RSK Tiptronic Automatic Transmission, Driveshaft, rear diff, $1500.00 More detailed facts from our friends at Ravensblade (click here) Dont forget to check: http://www.gr8wheels.com/Forsale.html Thanks, Jon Gr8wheels.com 480 560 3488 |
12-29-2004, 03:10 PM | #3 | |
Vendor
Member#: 20081
01-04-2005, 11:15 AM | #8 | |
Vendor
Member#: 20081
From what I know they are the same internaly....possibly different ratios... |
01-04-2005, 12:55 PM | #9 |
Member Sales Rating: (3)
Member#: 45256
South East
Vehicle:2002 Aspen WRX Wagon 04 STi Conversion |
OMG! i iwhs i had the money for this. Its soo much easier it looks to do than puttin the gears in your existing box! How hard to get the DCCD to work?
01-05-2005, 01:01 PM | #10 | |
Vendor
Member#: 20081
The dccd can be wired in since we include so much more than other people it makes it easier to get that wired up. |
01-06-2005, 03:38 PM | #11 |
Member Sales Rating: (16)
Member#: 55009
MWSOC
Still have the version 5 trans and etc? Also which would be better for higher hp the version 2 or version 5 and how low is low miles on the version 5? Thanx a lot
Don- |
01-16-2005, 01:33 PM | #17 |
Member Sales Rating: (15)
Member#: 44581
BAIC
Vehicle:3 Boxers 2 AWD 3 turbo 1 6cyl & a 13BT |
Can you tell me more about the RSK trans, is it a VTD? Does it come with a TCU and wiring? What are the gear ratio's and what is the final drive? How is the "Tiptronic" set up? Does it use the same style as the 03-04 legacy/baja shifter or does it have steering wheel mounted buttons? Will it come with that?
01-17-2005, 11:42 AM | #18 | |
Vendor
Member#: 20081
Yes it has the steering wheel shifter and the wheel is included, you can also shift via shift lever if you slide it over. Whats VTD? we should have the TCU and we have the Wiring cause its still in the car! Here is the Tranny code I dont know what the ratios are: TV1B4YBDAB Jon 480 560 3488 |
01-17-2005, 07:32 PM | #19 |
Member#: 44581
BAIC
Heh, I like to be thorough . How is/was the fluid in the tranny? Will it come with the wiring fully uncut from tcu to trans? How much is shipping looking like to 95841? Is it coming with the panel surrounding the shifter aswell? What's the mileage on it? What about the crossmember? Torque converter? Shift cable from shift lever to trans? Is the rear a r160 or r180? Does the steering wheel come with the boss and all related wiring (buttons, cruise, airbag, etc)? Do you have a picture of everything that it comes with? Does the owners manual say anyting about the ratios (assuming it has one)?
01-18-2005, 10:50 AM | #20 | |
Vendor
Member#: 20081
Jon 480 560 3488 |
01-28-2005, 03:28 PM | #22 |
Member Sales Rating: (32)
Member#: 15822
Vehicle:1999 WRB GM6 2.34 LR destroker |
question on B4 tranny
-bolt on swap from 4EAT? -how much power can it hold -comes with TCU/how does it work (ie in terms of distribution between front and rear wheels) |
02-07-2005, 08:43 PM | #25 |
Member Sales Rating: (10)
Member#: 33782
MAIC
Vehicle:96 3MI Racing search FIRST, then PM!!! |
you told me to check back in feb about radiators...do you have any in?
thanks, Micah also quite interested in the ver 2 RA tranny, being my second gear syncros are dieing are you sure you read the tranny code correctly...TV1B4YBDAB...because I can't find anything on it Last edited by Homemade WRX; 02-07-2005 at 10:29 PM. |
Similar Threads | ||||
DCCD and NON DCCD, How to recognise? | adofly | Transmission (AT/MT) & Driveline | 6 | 10-21-2021 04:48 PM |
jdm sti ver5-6 cluster pinout for dccd? | ImprezaRSfan! | Subaru Conversions | 12 | 01-11-2019 07:05 AM |
DCCD vs non-DCCD tranny | milcic07 | Transmission (AT/MT) & Driveline | 11 | 03-20-2008 09:51 PM |
dccd to non dccd center diff | mcu81 | Transmission (AT/MT) & Driveline | 6 | 08-30-2006 09:09 PM |
STI VER 8 gauge cluster non DCCD and other parts... | 996Cabby | Private 'For Sale' Classifieds | 3 | 02-18-2004 10:26 AM |
