11-08-2009, 01:42 AM | #1 |
Member#: 192351
21 psi on stock motor?
My AP is showing me hit 21 psi - tapers off, but is 21 to high for a peak? Safe? Is the AP accurate?
Oh yeah, car is 2009 wrx, TMIC, TBE, UP, CAI.
11-08-2009, 02:28 PM | #2 |
Member#: 171948
Vehicle:19 Sti Crystal white |
what kind of downpipe do you have? that is kinda high. if you go too high the car is gonna overboost and your gonna get a cel. my stage 2 08 has never been above 17 psi. give some more details. what map are you using?
11-08-2009, 02:56 PM | #3 |
Member#: 156342
is 21 too high?... depends on what turbo you have and how much timing you want to run
11-08-2009, 10:37 PM | #4 |
Member#: 192351
It's the stock VF52 (coated) and I've got an Invidia catless DP. I'm running an etune from Clark Turner until I can get it down to P&L for a dyno job. I'm just hoping to get some second, third, etc. opinions.
Thanks for any advice you all might have! |
11-12-2009, 04:23 AM | #5 |
Member#: 186257
SCIC
Vehicle:2015 WRX Premium CBS |
21 psi on your vf52 should be okay with a proper tune. that's what i peak at too.
11-12-2009, 09:05 PM | #6 |
Member#: 216278
I have a 08 wrx as well, what supporting mods do i need to run 20lbs of boost on the stock motor set up?
I have a catess DP and full piping. im running 13 lbs and hitting over boost and fuel cut. HELP!!!!! |
11-12-2009, 09:31 PM | #7 |
Member#: 186257
SCIC
just hi jack the thread why dont ya?
just fyi, i'm running a turboback, perrin tmic, 750cc injectors, 255 pump, vf52, and got it cobb ap tuned at hb speed. hope that helps... |
Project sti 06 mania: SZ65 420whp @ 21 PSI on a VERY conservative tune (PICS, PLOTS) | sticrazy | Proven Power Bragging | 48 | 07-08-2006 01:11 AM |
Only 10 psi on stock turbo? | boulder wrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 03-26-2003 12:12 PM |
Hit 20 psi on stock turbo tonite | AstroScooby | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 17 | 11-16-2002 02:21 AM |
What kind of HP with [email protected] PSI on STOCK motor | Davenow | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 09-08-2002 11:19 AM |
new TXS intercooler installed, and OOPS 21.8 psi on stock turbo? | zmw | Texas Impreza Club Forum -- TXIC | 2 | 08-10-2002 10:17 AM |
