Tire & Wheel Forum sponsored by The Tire Rack |
09-21-2006, 03:52 PM | #1 |
Member#: 51735
E. Canada
Vehicle:2006 2.5i Steel Gray |
Rotating tires on an AWD car...
Is the frequence of the rotation required any lower than on a FWD or RWD?
09-21-2006, 03:54 PM | #2 |
Member#: 66540
MWSOC
Vehicle:2004 WRX Sedan 2005 Legacy GT wagon |
09-21-2006, 04:03 PM | #3 |
Member#: 16157
South East
Vehicle:'03 Mazda P5 <>< '02 WRX & '08 MS3 SOLD!!! |
IIRC, I believe the manual states every 7,500 miles.
09-21-2006, 04:08 PM | #4 |
Member#: 51735
E. Canada
My dealership says 15k miles.
09-21-2006, 04:26 PM | #5 |
Member#: 1403
TXIC
Vehicle:99 RBP GC8 Impreza |
Your dealer should look at his manual.
09-21-2006, 04:34 PM | #6 |
Member#: 60082
MWSOC
Vehicle:2004 Forester STI Silver |
I don't but I'm lazy. So far, wear has been quite even. Our cars put power down pretty evenly, so the only excess of wear would be the front from on-power + steering. Well, that and the front end is slightly heavier. Unless you take different routes to and from work, wear should be similar on both sides. If you were just doing all left turns, then you'd expect more wear on one side.
Wear is just lot less of an issue with awd than it is with fwd or rwd where all the power is going to a single set of tires. As well, rotating may depend on how you buy tires. On a fwd car, you could get away with running through 2 or maybe even 3 sets of tires on the front before you ever wore down the rear tires. It could be similar with a high powered rwd car. You could rotate and eventually buy 4 tires or just replace the two high wear ones every so often with no rotation. |
09-21-2006, 04:37 PM | #7 |
Member#: 80918
Vehicle:02-7 MBP RS/i hybrid now w/ AVLS! |
i thought it was 4,000? oh well, i rotate/balance mine every oil change.
09-21-2006, 06:13 PM | #8 |
Member#: 80631
NWIC
Vehicle:2016 WRX Premium 6MT Ice Silver |
Similar Threads | ||||
How bad is it really, to have 2 different sets of tires on an AWD car? | WhiteFox | Tire & Wheel | 12 | 03-19-2008 03:22 PM |
rally racers, how does one get an AWD car to rotate? | steve | Vancouver Impreza Club Forum -- VIC | 57 | 01-14-2007 03:53 AM |
Has anyone gone from a rwd car to an awd car? | BlackoutWRX | General Community | 40 | 11-23-2005 11:43 AM |
okay so its bad to tow an AWD car with 2 wheels on the ground | jasona | Normally Aspirated Powertrain | 15 | 12-11-2002 02:04 AM |
Slicks on an AWD car? | ScoobieSnacks | Bay Area Impreza Club Forum -- BAIC | 4 | 02-15-2002 10:57 AM |
