Mid Atlantic Impreza Club Forum sponsored by Annapolis Subaru |
07-23-2012, 10:46 PM | #2201 | |
Member#: 230925
Vehicle:04 WRX Wag Stage 4 06 Impreza 2.5I |
07-23-2012, 11:31 PM | #2202 | |
Member#: 255716
NWIC
Vehicle:Itsa bugeye 04, V9 RHD and it makes me smile |
I finished it up today, I made a few small adjustments to make it seal better. |
07-24-2012, 12:33 AM | #2203 |
Member#: 233501
Vehicle:07AD 337/335SAXWAGON 99 outback sport |
Looks good, have you thought of adding another diverter into the center of the splitter to direct air towards the front of the intercooler, like so:
07-24-2012, 02:38 AM | #2204 |
Member#: 255716
NWIC
Yes I have thought of that, I ran out of free metal. Once I can get another piece I will add one. I am happy with it for now though.
I have noticed the car feels better having cooler air to burn. |
07-24-2012, 09:26 AM | #2205 | |
Member#: 310254
Vehicle:04 Forester XT Silver |
i installed my heat shield, topped my coolant, and tightened my belt tension for power steering. for some reason it doesnt want to stay tense, and every couple of days (up to a week or so) it gives me ****, all squealing and whatnot. Last edited by gaedikus; 07-24-2012 at 09:28 AM. Reason: and also |
07-24-2012, 08:23 PM | #2206 |
Member#: 305538
Went Stage 2. Mach V did all of the work and they did an excellent job : )
07-24-2012, 09:32 PM | #2207 |
Member#: 308019
Vehicle:2006 Wrx Wagon PSM |
Installed beatrush radiator cooling panel and pulley cover. Disappointed. First it took two months to get it shipped. Second they're not the same color. Third pulley cover rubs on the belts. Fourth! I realized they rubbed when i started my car rite before it rained. Fith! I had to take it off in the rain before i could go anywhere. Fcking sht
07-25-2012, 12:12 AM | #2208 |
Member#: 272144
Vehicle:2008 Legacy GT Lim |
Dropped the LGT off at Fortune Auto for a prototype kit
07-25-2012, 06:26 AM | #2209 |
Member#: 131379
Vehicle:2003 354 ftlb@3k rpm justablue hatch |
changed oil - motul - and attached skid plate for fall rx season. also ordered enough materials to make upper and lower grills...from customcargrill.com.
they have about 12 different styles in sheets, silver or powder coat black and edging materials. |
07-25-2012, 08:05 AM | #2210 | |
Member#: 255716
NWIC
07-25-2012, 08:13 AM | #2211 |
Member#: 310254
i took off both the driver front and passenger rear lights, sealed them with silicone (the tail was holding water, and the front was showing condensation), and the inner housing of the front headlight is like... loose. the beam shoots low no matter what. also took out my grille because it is a raging piece of poo which was GLUED to the front bumper (ill have to do something about that as well)...
and to top it off when i put everything back together and started it up this morning, the airbag light came on for some reason??? should i do the battery disconnect+brake pedal trick??? help? also got my DEI CoolTape in last night, but with no time to wrap anything. ill most likely do the intercooler first. |
07-25-2012, 08:17 AM | #2212 |
Member#: 305538
299hp 335tq. With my set up (especially the due to the header) it lost a little bit of power down low but as soon as you hit 2k rpm the car becomes a monster. It definitely changes the the way I've been driving though as it now has a brand new powerband. Loving it so far and I gained like 2mpg too LOL.
07-25-2012, 10:04 AM | #2213 | |
Member#: 233501
Sometimes a bottle will wiggle its way under one of the seats and jar the connector loose. Happened to me 3 weeks ago. |
07-25-2012, 10:48 AM | #2214 |
Member#: 310254
there shouldnt be anything under my seats, but ill definitely check the connectors. thanks jim!
07-25-2012, 07:39 PM | #2215 |
Member#: 314812
NESIC
Vehicle:2012 STI Wagon DGM |
Installed a grimmspeed license relocation kit.
07-25-2012, 09:11 PM | #2216 |
Member#: 74392
Vehicle:2010 STI DGM |
Broke a few bolts and swapped out my Greddy SE exhaust for a stock exhaust.
07-25-2012, 09:59 PM | #2217 |
Member#: 111343
Registered it for the MachV charity car show
07-26-2012, 08:45 AM | #2218 |
Member#: 310254
well the airbag light turned off last night after i started up the car, and is remaining off up to present. my LED kit didnt come in last night either, and i didnt get to install my supertones or wrap my intercooler cuz gf came back from visiting her parents >:C
tonight. you. hopefully ill get to it tonight (and yes that was an ATHF reference) |
07-26-2012, 06:00 PM | #2219 |
Member#: 201736
Vehicle:12 IS-F Sold!! :( 07 STi...SOLD :'( |
Got my door lock/unlock chime to work. YES!
07-26-2012, 06:06 PM | #2220 |
Member#: 22290
TXIC
Vehicle:2002 STI Ver 9 Spec C Wagon |
Installed a Grimmspeed lightened crank pulley. My original one was mostly rust.
07-26-2012, 06:44 PM | #2221 | |
Member#: 247473
Vehicle:2007 wrx wrb |
07-26-2012, 09:38 PM | #2222 |
Member#: 264849
Vehicle:2015 WRX DGM |
Wrapped my side skirts gloss black was a b! Looks good though
07-26-2012, 10:23 PM | #2223 |
Member#: 255716
NWIC
I have one. It did make a bit of difference in the way the motor revs up. I have a ej207 though and I am willing to bet that a 205 would benefit more from it. The motor does seem to run a bit smoother as well.
07-26-2012, 11:08 PM | #2224 |
Member#: 221364
Vehicle:2002 Wrx EJ207 Ver 8 Wrb Dccd jdm 6 speed now! |
Installed a Yakima rack for my stand up paddle board
07-26-2012, 11:20 PM | #2225 |
Member#: 294359
Vehicle:1993 MX5 Miata Red, BCs, Hard top, C1Ms |
Swapped out old coil pack for a new one. Misfiring mystery is now solved!! Such a good feeling to see the CEL turn off and stay off. Who would have known after all these months the answer was just 85$ and 10 minutes of labor.
What did you do to your car today? | Jester808 | Texas Impreza Club Forum -- TXIC | 3235 | 08-05-2013 12:55 AM |
what did you do to your car today? | Schrecken | Bay Area Impreza Club Forum -- BAIC | 11 | 09-25-2012 03:08 AM |
What did you do to your Scoob today? | Sheehan | North West Impreza Club Forum -- NWIC | 27 | 11-23-2007 12:02 PM |
