02-05-2002, 01:45 AM | #1 |
Member#: 13043
Vehicle:2002 WRX Sedan Platinum Silver Metallic |
Scoobysport exhaust fitment problems
Has anyone had the following problems with fitment of the Scoobysport turbo-back exhaust:
1. The original heatshield that bolts over the turbo/downpipe connection no longer fits because of the oversized mouth of downpipe is to wide for the opening on the shield. Has anyone modified the shield? Is it necessary to keep the shield in place? 2. My first section of muffler pipe rests on a metal housing that attaches to the left transverse link. If that wasn't bad enough, the pipe has only about 3 - 4mm clearance from the left halfshaft. I think if I trim the metal housing to clear the pipe it will then move closer or even touch the halfshaft. What to do? 3. The spring bolts don't seem to be able to firmly tighten down the joint between the front and rear center pipes giving me a slight exhaust leak. What fix have others used? Thanks
02-05-2002, 10:14 AM | #2 |
Member#: 7988
SWIC
Vehicle:2004 STi, WRB w/dirt Co-drive GrpN GC8 |
E-mailed you.
02-05-2002, 05:39 PM | #3 |
Member#: 12043
Psst
Sergeant_V E~Mail Mee too .....secret info? I am goin gome tonite to "Bolt up"
02-05-2002, 06:09 PM | #4 |
Member#: 7988
SWIC
e-mailed you too, ToolMan
02-06-2002, 12:17 AM | #5 | |
Member#: 3767
SCIC
Vehicle:2015 WRX Limited WR Blue |
Re: Psst
VERY QUICK Exhaust fitment question, SCOOBYSPORT 03 sedan to 02 wagon? | MrMakesitRain | Newbies & FAQs | 7 | 05-03-2008 06:32 PM |
exhaust fitment problem. | alvinli217 | Vancouver Impreza Club Forum -- VIC | 3 | 03-29-2008 04:58 AM |
Monte el Scoobysport Exhaust | Prog | Puerto Rico Impreza Club Forum -- PRSIC | 9 | 06-12-2001 08:26 AM |
Scoobysport Exhaust? | Pat Green | Bay Area Impreza Club Forum -- BAIC | 10 | 05-09-2001 09:32 PM |
Scoobysport exhaust ?'s | rbehny | Normally Aspirated Powertrain | 8 | 04-07-2001 04:22 PM |
