05-18-2008, 08:29 PM | #1 |
Member#: 117378
Vehicle:2006 2.5i Regal Blue Pearl |
What type of sand paper do I need?
Hey guys I picked up a pair of thoroughly scuffed sideskirts that aren't my color and I plan to paint them. Question is, what is the series of grits that I will need to get this job done?
Also, I need primer or some sort of promoter right? The procedure should be Sand > Sand > Prime > Paint X times > clear coat x times right? Thanks guys
05-18-2008, 09:24 PM | #2 |
Member#: 149752
Vehicle:2017 wrx ICE ICE BABY SILVER! |
depends on how scuffed they are...i would start with a very light grit and see how that works. less scratching you do will make you job easier.
05-19-2008, 11:38 AM | #3 |
Member#: 117378
bump for anymore suggestions? Maybe the exact grit I should be using?
05-19-2008, 12:16 PM | #4 |
Member#: 154434
NWIC
Vehicle:2009 WRX Hatch <@_@> SWP |
You may or maynot find some articles in here useful. It has a sandpaper grit guide in it
http://images.google.com/imgres?imgu...US274%26sa%3DN Lemme know if it helps any |
05-19-2008, 12:57 PM | #5 |
Member#: 104078
Vehicle:2013 WRX SWP |
i used 400 wetsand on mind...
i just used regular auto primer and they're holding up just fine.... my procedure... sand, primer, sand, wetsand, primer, wetsand, paint, finer wetsand, paint, clear clear clear clear clear clear |
05-19-2008, 01:27 PM | #6 |
Member#: 93307
Vehicle:05 WRX WRB |
Are the sideskirts painted now or still raw plastic?
05-19-2008, 01:38 PM | #7 |
Member#: 69161
South East
I bought my 02 used with unpainted side skirts. The first thing I did was scrub them with dish detergent and then simple green to get as much grease/tar/etc off before sanding. Then I started with 60 for the gouges and parts that needed to be smoothed out. Then 80, wash and sand. 120, wash, sand and repeat until they were squeaky clean and smooth. I think I ended with 200 or 300 for the final before paint. You want them smooth, but not so smooth the paint has nothing to adhere to. Several thin coats of primer, paint and clear later they are still holding after 1+ year.
05-19-2008, 04:11 PM | #8 |
Member#: 93307
I would use bull dog adhesion promoter before you seal it. You don't have to use primer unless you want to fill some scratches. If they are new and unpainted all you really need to do is use Scuff it and a red scuff pad. Spray your adhesion promoter and seal it. Base/clear and you are done.
05-19-2008, 11:26 PM | #9 |
Member#: 117378
I am receiving really scuffed up scratched silver sideskirts which I plan to sand like all of you awesome people have advised above and then paint regal blue pearl. Thanks for all the info guys - I won't be getting to this project till I get home from college but when I do I'll post pics every friggin step of the way. Heck maybe I'll so one step, post it, wait for feedback, and move on to the next just to be sure they come out perfect.
You've all been really helpful. |
05-20-2008, 12:17 AM | #10 |
Member#: 177473
W. Canada
Vehicle:03 wrx spec r1 yellow |
hey man if there painted and if there scuffed sane them with 180 or 240 grit prime sane with 400 or 600 then put 3 coats of color on then 3 coats or clear that wat we do at a body shop and wat i did to mine on my wrx
05-20-2008, 02:36 AM | #11 |
Member#: 159215
NESIC
Vehicle:2008 LGT Limited |
These guys are really trying to make you work.
As long as there are no deep scratches or pits all you need to do is a light sanding with 400 grit and then paint. No need for primer unless the paint already on there is not good, i.e peeling and chipping. |
What type of Christmas tree do you use? | [27] | Off-Topic | 26 | 11-29-2019 06:27 AM |
what type of doc/specialist do i need to see? | [27] | Off-Topic | 11 | 07-19-2009 05:21 PM |
what kind of sand paper for plastic | sch3838 | Interior & Exterior Modification | 6 | 07-02-2008 02:15 PM |
EJ 20, what type of exhaust system do you have? | stevedood | Bay Area Impreza Club Forum -- BAIC | 0 | 03-01-2002 02:57 AM |
Poll: what type of aftermarket rims do you have? | Rimmie | General Forum Archive | 12 | 06-16-2000 03:39 PM |
