Welcome to the North American Subaru Impreza Owners Club Monday April 27, 2015
Old 05-28-2005, 04:45 PM   #1
subynube
Member#: 63442
Default Anti-freeze smell from engine??
I have MY02 WRX, 53,000 miles, no mods (except recently had a new clutch and flywheel assembly put in to correct clutch shudder in cold weather). I have started to smell the scent of anti-freeze coming from my engine bay when I lift the hood. Any ideas where this could be coming from??
Thanks
subynube is offline   Reply With Quote
Old 05-28-2005, 06:29 PM   #2
jlevy
Member#: 15696
2015 WRX 6 speed
Default check out this thread
jlevy is offline   Reply With Quote
Old 05-28-2005, 08:06 PM   #3
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
check the seal on the top of the radiator where the metal is crimped onto the plastic top tanks - 02's are notorious for leaking there (it's not a big leak - more of a weeping sort of thing - just look along the crimp and see if there is a bunch of green coolant residue.)
Old 05-28-2005, 09:43 PM   #4
Antonios Kintos
Member#: 81122
08 STi white
Yeah me too. I just realized this week I have a coolant leak somewhere as well. I put coolant in the reservoir. Some time later after driving for a little while I smell coolant and even see it evaporating through the hood scoop. I'm hoping its just something that came loose and not something broken.
Antonios Kintos is offline   Reply With Quote
Old 05-29-2005, 12:15 PM   #5
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
I found that if I overfill the reservoir, and I drive hard, the coolant slops out and hence the smell. Did you notice the smell only affter topping the reservoir?
ebeck is offline   Reply With Quote
Old 05-29-2005, 06:47 PM   #6
subynube
Member#: 63442
Actually, I just started noticing the smell over the last week or so, and I haven't filled fluid into the car for at least 3-4 months. It just all of the sudden started to smell like that.
Thanks
Josh
Old 05-29-2005, 06:56 PM   #7
cabe
Member#: 55864
2002 WRX sedan
What does antifreeze smell like when it's burning? Slight highjack.
cabe is offline   Reply With Quote
Old 05-29-2005, 08:19 PM   #8
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Sweet smelling.
Old 05-29-2005, 08:29 PM   #9
cabe
Member#: 55864
2002 WRX sedan
Like cookies? LOL jk. What color is the smoke?
Old 05-29-2005, 09:40 PM   #10
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
smoke is white - if you want to smell it, go drive your car, then when you get back, drop a couple of drops of coolant on the downpipe heatshield. (you won't hurt it - obviously, don't remove the radiator when the car is hot to get the coolant)
Old 05-29-2005, 09:44 PM   #11
cabe
Member#: 55864
2002 WRX sedan
I don't have a heat shield anymore. Can I just drop it on the dp?
Old 05-29-2005, 10:03 PM   #12
driftwhore
Member#: 56682
2003 wrx wagon
rally blue
Impreza WRX STi mystery smoke fix
well with mine i had to make expensive mods to figure it was a 1.99 fix (a hose clamp at home depot is freakin stupid)
well anyhow, i was getting the same mystery smoke and took it back to subaru and they said i fried the turbo cause my turbo xs rfl bov caused the seals to go bad. well a friend was demoding his rex and gave me a price i couldn't refuse so i went ahead and put everything on (perrin uppipe, vf30 turbo, xs dp,testpipe, sti pink injectors, xs massive topmount,and utech) well it ran fine for a day or so and then i saw the mystery smoke again! well i pulled it in to our shop and found the problem. the coolant line going to the turbo had a freaking loose clamp. $xxxx for a freaking hose clamp. never would have seen it if i was still running a heat sheid.
so long story short see exactly where it's coming from.
but thats what happened for mine
driftwhore is offline   Reply With Quote
Old 05-29-2005, 11:06 PM   #13
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Yes - you can drop it on anything hot enough to evaporate the coolant.
Old 05-29-2005, 11:17 PM   #14
Ghost Rider
Member#: 70346
2013 Focus ST
Performance Blue
maple syrup
seriously
Ghost Rider is offline   Reply With Quote
Old 05-30-2005, 12:59 PM   #15
MT_WRX
Member#: 24409
'03 Comatose WRX
Wagon. Parked.
Originally Posted by Ghost Rider
maple syrup
seriously
winn4r!!1!
MT_WRX is offline   Reply With Quote
anti freeze smell shizwrx Service & Maintenance 3 01-31-2007 11:34 PM
Anti freeze smell alfabc Southern California Impreza Club Forum -- SCIC 3 03-27-2004 09:29 AM
Anti-freeze Smell!! 1DOWNCLOWN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 33 03-03-2004 06:38 AM
Anti-freeze smell veteq General Community 34 03-03-2004 12:47 AM
Hmm Funny Anti-Freeze smell after a Spirited drive Clegg Mid West Subaru Owners Club Forum -- MWSOC 10 01-13-2002 01:13 AM
