07-08-2014, 09:26 PM | #326 |
Member#: 361761
BAIC
Vehicle:2002 wrx wagon aspen white |
[quote="666stars;42220872"]The pfr7b would be the double platinum version. That's what I use on my Ver8. Amazon sells them http://www.amazon.com/gp/aw/d/B001MU5JB2?pc_redir=1404745697&robot_redir=1[/QUOTE
Thanks much!
07-09-2014, 08:48 AM | #327 |
Member#: 221364
Vehicle:2002 Wrx EJ207 Ver 8 Wrb Dccd jdm 6 speed now! |
The one place I found the pfr7g is eBay from the u.k. For about 70.00 usd plus shipping
07-09-2014, 08:50 AM | #328 |
Member#: 221364
Like you said, The one place I found the pfr7g is eBay from the u.k. For about 70.00 usd plus shipping
07-09-2014, 08:52 AM | #329 |
Member#: 221364
Oops double post
07-11-2014, 07:32 AM | #330 |
Member#: 77737
Vehicle:2003 spec C White |
07-11-2014, 08:01 AM | #331 |
Member#: 46135
Vehicle:19 GLA45 AMG C63 AMG |
in US, $75-80 may buy you the plugs packaged in the pink box from Sti as well.
I am waiting to see who will post first that they tried the 8 series plugs in their 207. |
07-11-2014, 08:13 AM | #332 |
Member#: 6886
Vehicle:MY01 EJ207 HTA35r AVCS ON! |
i tried the bkr8iex..they worked but a tad too cold for my tune.
07-11-2014, 09:31 AM | #333 |
Member#: 43196
TXIC
Vehicle:1999 STi Type R 93GF 95GC 02GD 01SF-T |
pfr7g-11s Is readily available, is there a difference between the pfr7g-11s and pfr7g?
07-11-2014, 09:46 AM | #334 |
Member#: 361761
BAIC
07-11-2014, 09:50 AM | #335 |
Member#: 46135
These questions have been answered in the 207 thread. Yes, there is a difference, don't buy the -11, even in a platinum, not only iridium.
While some have found work-arounds for regapping platinum plugs, the safe advice is to stay away from re-gapping anything but plain copper, buy the right plugs. |
07-11-2014, 10:07 AM | #336 |
Member#: 43196
TXIC
gotcha
07-13-2014, 02:57 PM | #337 |
Member#: 209375
Vehicle:2002 wrx wagon silver |
Does anyone know if any usdm timing belts will work on a EJ207? I work at O'Riellys and get a good discount so I wanted to order a Gates thru work.
07-13-2014, 03:25 PM | #338 |
Member#: 50586
BAIC
Vehicle:64 Impala |
07-16-2014, 03:02 PM | #339 |
Member#: 88954
Vehicle:'05 Saab 92X Spec C desert silver metallic |
Just fyi, I passed emissions in dc this past weekend with my v8 spec c swap. OBD2 reader, no problems.
07-16-2014, 04:53 PM | #340 |
Member#: 166324
NESIC
Lucky.
07-16-2014, 07:35 PM | #341 |
Member#: 174706
SCIC
Vehicle:2008 LGT-B DGM |
I wonder why it's so hit and miss with emissions?
Sent from my iPhone using NASIOC |
07-16-2014, 10:22 PM | #342 |
Member#: 266954
Vehicle:04 wrx v7 sti swap agile tuned 389hp 342ftlb |
Probably because some states require more readiness monitors to be set than other states. The jdm swap wont set all the monitors.
07-16-2014, 10:54 PM | #343 |
Member#: 167739
Vehicle:15 Forester NA dat gas mileage |
07-17-2014, 07:59 PM | #344 |
Member#: 166324
NESIC
07-25-2014, 10:25 AM | #345 |
Member#: 88954
I will admit, it looked like they had to test the car two times but I passed. My car happens to be catless too...
07-28-2014, 02:41 PM | #346 |
Member#: 218358
Vehicle:2002 WRX PSM |
EJ207 Info
For the 2 vac lines off the valve covers that connect to the inlet line via that piping on the stock top mount. I'm running an FMIC and don't have that piping setup, so I have a few questions. It's a 2001 ej207.
How important is it that the valve cover lines be equal length? The inlet line is larger ID that the valve cover lines, if I use 10mm ID for all of them will I have problems? Will high temp, thick walled silicone vacuum lines work ok for this or will I have problems? I planned on just using a 10mm T fitting for this, but considered fabbing up a pipe setup similar to the OEM one to mount on the firewall, my only issue with this is that the vacuum line/piping length will be starting to get a little ridiculous. Thanks, Teddy Sent from my iPhone using NASIOC |
07-31-2014, 12:34 AM | #347 |
Member#: 361761
BAIC
Hopin to get a few opinions. Swapped a v7 into my 02 wrx wagon. Had a huge issue with avcs wiring. Car is at the tuner. Avcs doesn't seem to be working 100% and also car is running lean under load. Checked fuel pump, smoke test. I think next thing to check is maf, fpr, and injectors. Anyone know what else could be causing it to run lean under load?
07-31-2014, 08:44 AM | #348 | |
Member#: 57287
Vehicle:2002 Bugeye STi MY07 WRB FXT |
07-31-2014, 03:02 PM | #349 | |
Member#: 361761
BAIC
Thanks. I'll let them know to check that. Hoping it's a simple fix Sent from my iPhone using NASIOC |
08-04-2014, 01:49 PM | #350 |
Member#: 86656
Vehicle:05 WRX SQC228 San Remo Red |
Got my swap running and having a few issues. Idles rough but smooths out when you give it gas past 1100 rpm. Also breaks up when the cars in boost. Car hasn't been tuned yet and I also have cel that I can't pull. Anyone got any ideas?
Sent from my SCH-I545 using NASIOC mobile app |
