03-06-2009, 07:05 PM | #1 |
Member#: 137902
Vehicle:---- living life to the least!! |
will the oil pan from a 1.8L fit....
on a 2.2LT? mine has a tiny rust hole in it. why didn't it leak when it was at the lot? who knows. probably snake oil. anyway if any of you know i'd apreciate it. later....
03-07-2009, 11:59 AM | #2 |
Member#: 137902
really? no takers :sadface:
03-07-2009, 12:48 PM | #3 |
Member#: 123574
Vehicle:2005 STi CGM |
This should probably be in a technical forum.
And yes there's a thread preview feature, but nobody likes it when you leave 3 words out of the subject and instead choose to end it with '...' |
03-07-2009, 05:21 PM | #4 |
Member#: 137902
well, i would've but they're less frequented. well i wire wheeled the suspect area and jbwelded it by recommendation so we'll see how that goes. thanks anyway
03-08-2009, 11:43 AM | #5 |
Member#: 177
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
probably would fit .. you would need the 1.8 pick up as well
iirc the 1.8 pan has a smaller volume |
03-08-2009, 07:19 PM | #6 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
Correct. You need the Ej18 pickup and it's about 1/2qt smaller volume.
03-10-2009, 07:32 PM | #7 |
Member#: 137902
thanks but it looks like the jb weld is holding on! yay me!
03-11-2009, 09:30 AM | #8 |
Member#: 177589
i say it will fit, but you will want to swap the sump pickup and check the oil level before starting. if you want a turbo oil pan i have one off a 93 ej22turbo i will part with. g/l
Similar Threads | ||||
Will the top hat from a sedan fit a wagon in the rear? | ever12 | Newbies & FAQs | 4 | 02-18-2009 02:50 AM |
How does the oil drain to the oil pan? | msm98lw | Newbies & FAQs | 6 | 10-29-2005 12:05 AM |
How do you separate the oil pan from the block? | jasona | Normally Aspirated Powertrain | 16 | 10-06-2005 04:54 PM |
Will the instrument cluster from 2dr. 2.5RS fit a '98 OBS? | RootUsr | Electrical & Lighting | 3 | 06-27-2005 09:01 PM |
Will the turbo manifold from a 2.2 fit a 2.5RS??? | Xscreamer | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 06-10-2001 08:13 PM |
