06-29-2012, 09:28 PM | #1 |
Member#: 135140
cam seals help
Does anyone have the correct cam seal part numbers? Looking on rockauto they show different sizes and i am not sure which ones i need? Pretty sure i need 4 of them correct? mine are leaking oil pretty bad.
This is for a 1995 subaru legacy 2.2L
07-01-2012, 12:33 PM | #2 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
When it comes to that sort of thing I'd be inclined to go through a dealer, just to be sure I get the right part based on my VIN.
Alternatively, you can order a couple different parts from rockauto and then return what doesn't appear to be the correct size. |
07-01-2012, 02:25 PM | #3 |
Member#: 323720
Vehicle:1996 Legacy |
there is only 2 cam seals, and if you buy the cam seal kit it should come with 2 o-rings as well.
07-10-2012, 02:51 AM | #4 |
Member#: 174710
Vehicle:1997 Outback The $400 Special |
If your car is DOHC then you will have 4 front cam seals, if it is SOHC you will only have 2. There are no rear cam seals. I just ordered all of my seals from rockauto with no problems
07-11-2012, 10:49 AM | #5 |
Member#: 135140
I dont remember rockauto having kits for the cam seal? Ill have to look again. Thanks for the help so far though!
Similar Threads | ||||
2.2 impreza cam seal HELP!!!! | beppomarx | Service & Maintenance | 7 | 01-01-2013 06:30 PM |
Need help identifying part# for Rear CAM Seals | Mike1967 | Normally Aspirated Powertrain | 11 | 04-22-2007 02:16 PM |
cam seal installation help for a noob | q2brass | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 01-07-2007 05:47 PM |
Help with cam seal procedure and SOA | TlistGT | Service & Maintenance | 7 | 11-15-2006 06:15 PM |
HELP! My head cam seal fell into the motor | f1uxx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 10-11-2006 11:34 AM |
