10-29-2012, 07:25 PM | #1176 |
Member#: 260868
South East
Vehicle:2011 STI White |
This is a cable that came with my DW300. I'm thinking that I can easily change these wires to 10ga wires and reuse the plug connections so I do not need to do any soldering or splicing inside the pump housing. Where can I get these connectors for the wires? Are these typical connections you find at an automotive store?
10-29-2012, 08:33 PM | #1177 | |
Member#: 253304
AKIC
Vehicle:2001 Impreza 2.5RS Plus MOAR |
10-29-2012, 08:51 PM | #1178 |
Member#: 260868
South East
Alright I hope so. I'll bring them with me in hopes of finding them. Now I am thinking leaving this portion of the circuit the OEM wire might not be as bad as people say. We are increasing 15' or so feet of wire to 10 ga and only about 3" being OEM gage whatever that is. Hmmmm
10-30-2012, 07:52 PM | #1179 |
Member#: 260868
South East
Intercooler sprayer bar installed
10-30-2012, 09:08 PM | #1180 | |
Member#: 283784
RMIC
Vehicle:2015 MUSTANG GT PP GUARD |
10-30-2012, 09:21 PM | #1181 |
Member#: 260868
South East
It is a NOS intercooler sprayer bar. I am using all of the equipment from the meth kit up to the fast acting valve. Then there is one AN line to the spray bar. I may go and tap the other end so that it fills from both ends but it is probably enough the way it is.
10-31-2012, 01:55 AM | #1182 |
Member#: 336617
im drooling dude, beautiful.
10-31-2012, 05:15 AM | #1183 |
Member#: 260868
South East
Thank you sir.
10-31-2012, 10:29 AM | #1184 |
Member#: 321211
South East
Most expensive water sprayer ever.
10-31-2012, 10:38 AM | #1185 | |
Member#: 249068
South East
Vehicle:2010 WRX DGM Phatbotti Tuned |
10-31-2012, 12:52 PM | #1186 | |
Member#: 260868
South East
No point in selling the system if E85 turns out to be a bigger pain than it is worth. I can easily go back to meth injection if I want. Last edited by jockeygolfs; 10-31-2012 at 01:55 PM. |
10-31-2012, 02:38 PM | #1187 | |
Member#: 325324
VIC
Vehicle:2010 STI Wagon |
Wow, i can't believe I came across this.... I found the same thing on my car, just plugged the FPR back in, runs much better.
10-31-2012, 02:42 PM | #1188 | |
Member#: 260868
South East
11-02-2012, 06:06 AM | #1189 |
Member#: 260868
South East
Deatschwerks hard wire kit is done! For anyone looking to do this, make sure to check the fuses first if things don't fire up after the first time turning the car on! I'd like to thank Themaus and WRX02ftw, TJ and Gerry for their help.
The instructions from Deatschwerks were miss leading. Only one wire, the 12V positive needs to be cut and two splices need to be made. On my car the wire was a green one with a yellow stripe on it. The rest is ground to the car and the direct connection to the battery. The Instructions say to splice the ground on the fuel pump harness. Don't need to do that. Plus the unit came with a five lead relay which I had to pull the center 87A lead out since it is not used. This confused me for a bit until I called Deatschwerks. We spliced into the wires between the fuel tank cover in the back seat and the plug that connects to the rest of the car. This means no splice under the cover to the gas tank. The main goal in my mind is to take the power off sharing with other systems in the car that make the power fluctuate. The gauge of wire should not be an issue since the smaller gauge is relatively short compared to the upgraded 12 gauge wire that is coming from the battery. Now we will do a few cruise logs to finish up the limp 93 map. Hopefully we will be done today and then switch to E85 for the real tune No pictures since it was about 1 am when we finished. It was 2 am when we went to Walmart to find replacement 30amp fuse lol. Last edited by jockeygolfs; 11-02-2012 at 09:59 AM. |
11-02-2012, 09:49 AM | #1190 |
Member#: 283784
RMIC
Glad to see they helped you get taken care of. Sorry I just got your messages today. Prepare for E85 it's a ton of fun
11-02-2012, 09:54 AM | #1191 | |
Member#: 249068
South East
Jock I suggest u get a Zeitronix meter ( my next purchase), i suspect there are different blends of 85 around. |
11-02-2012, 09:58 AM | #1192 | |
Member#: 260868
South East
11-02-2012, 09:59 AM | #1193 |
Member#: 260868
South East
We were buying fuses at Walmart at 2 am lol.
11-02-2012, 10:06 AM | #1194 |
Member#: 321857
I take it WalMart had the fuses then? That's good. It was nice to work on your car finally.
-T.J. |
11-02-2012, 10:08 AM | #1195 |
Member#: 283784
RMIC
Haha nice job. I just fill up at the same place and they are pretty consistent. It's a nice safety investment
11-02-2012, 11:19 AM | #1196 | |
Member#: 260868
South East
11-02-2012, 02:09 PM | #1197 | |
Member#: 260868
South East
11-02-2012, 02:13 PM | #1198 | |
Member#: 283784
RMIC
11-03-2012, 09:35 PM | #1199 |
Member#: 260868
South East
Car is running on E now. Doing cruise longs. Can't wait to turn it up!!!
11-04-2012, 01:49 PM | #1200 |
Member#: 260868
South East
Full Blown double pump hanger purchased . Thinking future lol.
Will it fit: 2011 STi Sedan exhaust on 2010 WRX Sedan | btr22 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 42 | 07-08-2016 02:26 PM |
Forged Performance: 2011 STi Sedan MONSTER Build **check back often** | Forged Performance | NASIOC Project Cars | 462 | 07-06-2016 08:06 PM |
Fast Motorsports Prototype 08+ wrx sedan and 2011+ sti sedan catback! first pics! | IMPORTIMAGE | Vendor Announcements | 4 | 05-02-2011 09:50 PM |
Comparing 2011 STi Sedan to 2011 WRX Sedan | DasWRX | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 4 | 12-21-2010 07:09 AM |
new with a question about 2011 STI sedan vs. previous STI sedans | tommygsubie | Newbies & FAQs | 37 | 11-02-2010 12:16 PM |
