09-30-2007, 02:26 PM | #1 |
Member#: 42478
South East
Vehicle:2004 WRX STi White/Gold |
What should I do to clean mating surface?
Hello,
I recently blew my head gasket and had the heads resurfaced. It now has a mirror finish. What I need to know is what is the best way to clean the block's mating surface so it too is ready for a great seal once I reassemble everything. Right now there is old head gasket residue on it. I appreciate your suggestions.....
09-30-2007, 08:14 PM | #2 |
Member#: 66310
South East
Vehicle:2023 korean muscle |
First clean the old gasket with a razor blade
Then sand it with 220 grit. If its aluminum do it by hand. If its anything else you can use a cookie wheel. Then clean with brake cleaner. |
09-30-2007, 08:44 PM | #3 |
Member#: 42478
South East
Thanks. The block is an 04 STi so it is aluminum. When you say "cookie wheel" do you mean a sanding disc on an air tool?
Thanks! |
10-01-2007, 07:06 AM | #4 |
Member#: 66310
South East
Yes but do not go near aluminum with the cookie wheel. An amateur mechanic can and will destroy the block / heads with an air tool. It will be ruined and no you probably cant fix it. You can even ruin an iron block if you grind down too much.
10-01-2007, 08:23 AM | #5 | |
Member#: 42478
South East
Sounds like a light duty scotch brite pad may be a better choice.
10-01-2007, 11:46 AM | #6 |
Member#: 2532
South East
Vehicle:2001 2.5RS-T BRP |
I have a flat steel block I can either wrap with sand paper or you those adhesive disks. Any very flat thing will do but you can usually find drops for pretty cheap at a metal supplier or even a machine shop. I would recommend against using scotchbright since you don't know if the surface is flat. If you use a know flat sanding block any low spots on the surface will show up. I'd use 800grit paper and WD40 as a lubricant while making a figure 8 across the surface.
10-01-2007, 01:23 PM | #7 |
Member#: 42478
South East
Good info!!
Thanks! |
10-02-2007, 03:18 AM | #8 |
Member#: 137502
Vehicle:1990 Legacy GT-t Blue over silver |
I've been using a bench mounted wire wheel to clean my block and the mating surfaces. Haven't gone near the deck with it though to avoid my freshly honed bores, but the outside is coming up nice!
I bought a wire wheel that you put in a hand drill today and attacked the bits I couldn't reach with the bench brush, but need a real small one to get into all the tight spaces... I noticed a little bit of rounding on some of the edges but nothing to really worry about. |
11-06-2007, 10:55 PM | #9 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
Late last week I picked up an assembled short block from a machine shop. I didn't really look too closely at the head mating surfaces as it was getting dark, but they said they were already cleaned. Now that I've put the engine on my stand and have taken a look, though, it doesn't look to me like they were. The machine shop's an hour away, so I'd rather just do this myself than spend 4hrs driving to/from the shop to drop off and then pick up the engine.
So, any tips on cleaning the head gasket mating surface of the block on an assembled shortblock? Obviously I don't want to get any mung into the cylinders. My thinking is that tilting the engine on the stand and cleaning the face that's pointed down towards the floor (so gravity helps keep stuff out of the cylinders) is a start. Thanks, Pat Olsen |
11-06-2007, 11:07 PM | #10 |
Member#: 99140
E. Canada
Vehicle:GD Racing chassis Slowly in construction |
I'm using a flat sheet of glass (window) with sand paper glued on it. A few drop of oil also on the sand paper. (split block half)
11-07-2007, 12:37 AM | #11 |
Member#: 41149
SCIC
Vehicle:09 FXT SSM |
Even regular scotchbrite would be fine if you're careful. I have a box of this light-duty stuff, and it's really only good for scrubbing counters.
Whatever you do, don't use a putty knife or anything steel for that matter. If you leave any steel in there, it can create galvanic corrosion down the line and cause you to end up with leaks. |
11-07-2007, 01:38 AM | #12 | |
Member#: 14364
Vehicle:2003 WRX, '06 Armada 05 Vette & 05 STi (sold) |
11-13-2007, 06:39 PM | #13 |
Member#: 56345
Vehicle:1997 OBS Primer Grey |
600 grit wet sanding paper, a bondo board, some saran wrap and some vaseline.
Smear Vaseline around the top of the bore, stick a cylinder of saran wrap to it to where the saran wrap is just below the deck, slowly, smoothly and straight sand with the bondo board with the 600 grit wet with wd40, go one direction across the deck for about 15-minutes, then intersect that direction at a 60* angle and do the same till it's nice and smoooth, clean with brake clean when done. |
11-13-2007, 07:11 PM | #14 |
Member#: 5030
Vehicle:1999 Legacy 2.5GT 19 Audi RS3, 13 Armada |
Take it to a machine shop and have them shave a few thousandths off. Shouldn't be much more then $100 and it gets the mating surfaces perfectly flush on the block and heads.
11-13-2007, 09:13 PM | #15 |
Sammo Hung
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
do it by hand..i usually have bits of 220 or 440
that i use. |
11-13-2007, 09:34 PM | #16 |
Member#: 74907
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
i use little scotch brite-like pads on an air angle drill, use the fine stuff. got mine at harbor freight for like $3-$5. i then finish up with 600 wet sanding paper on the hard to reach areas. If you do this go slow, i turn the speed on the air tool down a bit so i cant remove material.
but ill try laquer thinner next time......didnt think of that. ~Josh~ |
11-13-2007, 11:06 PM | #17 |
Member#: 56345
DO NOT USE SCOTCH BRITE!
It's not simply that it's aluminum oxide but it's fragile "sponge" that come art easily and little bits get everywhere unlike sand paper, this especially true when using a small air rotary tool. Contamination with this stuff will chew up any surface in your engine. |
11-13-2007, 11:07 PM | #18 |
Member#: 56345
11-22-2011, 10:31 AM | #19 |
Member#: 114530
Bump for more answers to this, preferably from people who did it successfully and ran without headgasket or other issues....
11-22-2011, 11:29 AM | #20 |
Member#: 212509
Vehicle:unde your hood makin your **** go faster |
we have a round flat sanding stone that i used on my block. we usually use it to clean tgv and intake manifold surfaces. still running and no problems. I did it to my moms leggo as well when i put new headgaskets on it. just make sure you blow everything out real good when your done.
11-22-2011, 11:36 AM | #21 | |
Member#: 33839
South East
Vehicle:2002 WRX Black |
It’s the only way to do it properly, the surface finish of the mating surface should be > 35 RA (I believe that is what most MLS head gasket manufactures suggest) - do it right and save yourself the heartache later. |
11-22-2011, 12:00 PM | #22 |
Member#: 114530
When you talk about taking the stuff to machine shop. Can they do it safely/cleanly without disassembling block or the heads?
Basically I have a block and heads that I want to put together without disassembling anything. Both block and head are low mileage and do not require messing up with. They also should not require decking, which as I understand involves removing more material (and I believe the allowable amount to be removed is very low). My plan was to clean them, use straight edge/feeler gauge to check if they are true, and put together. |
11-22-2011, 01:25 PM | #23 | |
Member#: 120
AKIC
Thanks! |
11-22-2011, 01:39 PM | #24 |
Member#: 199106
Vehicle:PMme 4 Speed Density Patches on OEM ECU |
It's a measure of surface roughness. http://en.wikipedia.org/wiki/Surface_roughness
This thread has so much 2007 fail. |
11-22-2011, 02:04 PM | #25 |
Member#: 114530
It has a lot of a fail (scotch brite for example), but I thought it's better to bump an existing one than to start a new one (with new fail).
Similar Threads | ||||
Did I **** Up? What should I do to make it right? (long with cliff notes) | huckedup16 | Off-Topic | 39 | 05-09-2004 02:20 PM |
how to clean mating surface of block and head for headgasket | jdchmiel | Subaru Conversions | 4 | 03-30-2004 06:27 PM |
What should I do to my TS next? | CKK | Normally Aspirated Powertrain | 9 | 10-03-2001 12:28 PM |
('93-'01) what should i do to my 2.5 rs | PEARLBLK99RS | Impreza Forum | 11 | 06-24-2001 12:42 PM |
Poll: What should I do to my car? | efoo | New England Impreza Club Forum -- NESIC | 17 | 05-27-2001 05:18 PM |
