10-15-2006, 10:01 PM | #1 |
Member#: 112314
Vehicle:2002 wrx wagon platinum silver |
factory ECU reflash?
i have an 02 wrx with full catless exhaust an up pipe and a drop in k&n. I had the factory ecu dyno tuned using the ecutek. When i first got it back it ran great. Just recently it developed a hestation/loss of power from 4500rpms to 5500 rpms. I also noticed when im cruising on the highway if a let off the gas then give it a 1/2 throttle the boost flucuates from 8 to 10 psi for a couple seconds then it settles at 10psi unless i give it more throttle. Could this be a reflash problem or do I have a A/F sensor going bad or maybe the MAF sensor messing up. Any ideas?
10-15-2006, 11:38 PM | #2 |
Member#: 177
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
when was the last time you changed your plugs?
10-16-2006, 07:10 AM | #3 |
Member#: 112314
i just changed them 2 weeks ago that was the first thing i tryed
10-27-2006, 12:06 PM | #4 |
Member#: 118474
SWIC
let me guess...you have aftermarket fuel rails? and you still have your tgv's
Similar Threads | ||||
can you reset factory ecu to stock after factory ecu updates | SHAG SCOOB | Engine Management & Tuning | 6 | 11-29-2009 02:55 AM |
Beg, borrow, or fake a "CE" issue for the ECU reflash! Just got mine back... | gtguy | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 37 | 02-05-2002 07:51 PM |
On-site ECU reflash | JimmyOOOOO | North West Impreza Club Forum -- NWIC | 5 | 01-22-2002 10:14 AM |
