04-24-2001, 10:45 AM | #1 |
Member#: 4322
Vehicle:1998 OBS Black |
Help! I fogged my paint while debadging...
Help me please! I made a small spot (the size of a quarter) of fogged paint while debadging my WRX. Otherwise it went very well.
Any tips on taking it away? Thanks, Dan |
04-24-2001, 11:00 AM | #2 |
Member#: 6040
OUCH!! well take it to a paint shop they can touch it up for about $20...i had a key scretch a while ago. i took down to a paint shop they touched it up for $25..looks just like normal....
04-24-2001, 03:35 PM | #3 |
Member#: 3672
Vehicle:2002 WRX Aspen White |
Try a small amount of rubbing compound, then use some McGuires cleaner wax... I had a small spot like that behind the S. This method worked for me.
04-25-2001, 01:44 PM | #4 |
Member#: 4110
BAIC
Vehicle:04 FXT PSM |
What do you mean by fogged? I was thinking about debadging my girlfriend's RS and was worried about the paint. I'm just worried about stuff exactly like this.
-Brian |
04-25-2001, 03:20 PM | #5 |
Member#: 3713
Was the fogging from the heat or the solvent used to clean up? Use the minimum amount of heat from a heat gun or hair dryer necessary to soften the adhesive, then pass very fine dental floss behind the badge/letters and they come off easily. I thought that clean up with WD40 sounded pretty weird, but it doesn't affect the paint and the goo eventually comes off with a bit of rubbing. Finish up with car wax/polish. Looks like those letters were never there. If your paint is just fogged it should buff out.
04-25-2001, 05:34 PM | #6 |
Member#: 4322
It was from too much rubbing... The first S took a little to get the hang of it. The rest was easy. After rubbing with GooGone to get rid of the little bits, I noticed some fogging. Again, only a tiny bit.
I just wanted good advice before I tried to fix it. |
04-25-2001, 05:41 PM | #7 |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
detail clay and detail spray....
if you havent tried it.. do it... you can find some here: http://www.griotsgarage.com that's the clay and spray i recommend and use on my RS... what it does is remove all solvents, dirt etc from the paint... even yellow paint over spray... hehehehe... not that i'd know... j. www.subiegal.com |
04-25-2001, 06:52 PM | #8 |
Member#: 5391
just get a good wax and hand rub it out i use to work at a recon shop that should work realy good the fogy spot is from puting hair line scraches in the clear cote you should be fine see ya
Similar Threads | ||||
Help! I broke my #&!@ing fog light! | ursine | Electrical & Lighting | 7 | 01-14-2004 02:09 PM |
Who can help me wire my Fogs? (Hella 500's) | Davenow | New England Impreza Club Forum -- NESIC | 28 | 12-06-2003 01:20 PM |
Does someone wanna help me with my car while I'm in town? PLEEEEZ!! | GooseMan | New England Impreza Club Forum -- NESIC | 8 | 03-27-2003 01:40 PM |
Got gasoline on my paint! Help!!! | djerickd | Car Care & Detailing | 6 | 08-13-2001 02:33 PM |
Help! Is my paint ruined? | MagicMT | Car Care & Detailing | 23 | 05-29-2001 07:15 PM |
