01-20-2013, 11:28 AM | #26 |
Member#: 79983
Vehicle:2005 STI Aspen White |
Well idle air fuel is normal than. Its hovering right around 14.5 to 14.9 at idle.
01-20-2013, 11:47 AM | #27 |
Member#: 33593
Vehicle:2002 JDM T.K. 2.2 FancyPants Fast UglyWagon |
Cool.... Hopefully it was the charcoal canister that was affecting your fuel mileage. :-)
Then u can sell me your civic. :-) Mario |
01-20-2013, 11:55 AM | #28 |
Member#: 79983
Haha. Yea im not so sure I will ever get rid of the civic. I went 33 days without filling it up and when i did it cost me 34 dollars. Thing is unbelievable on gas. If i really push it I can cross the 420 mile barrier to the tank. Its amazing.
01-21-2013, 09:41 AM | #29 |
Member#: 58251
Vehicle:2004 Sti GT35R 530whp @ 27psi |
I definitely think it's something specific to your car or driving habits. I have a very similar mod list to you (built motor,278 cams, 52lb/min turbo, 850cc injectors, etc)...
And I get about 15-20mpg city, 25-28 mpg HWY. Of course, this means driving the car like a responsible person and doing like 70-75 on the highway. If you start hot dogging around and getting into boost, that will quickly change to 10mpg. If you want fuel economy, drive it like you would a fuel efficient car. I typically average about 275 - 300 miles per tank in mine - and that includes abusing it multiple times per fillup. For the most part, mods make a motor more efficient. But when you start getting into the throttle, you're making a lot more power and using more fuel to get there. If you dont use the power, you wont use the fuel (unless something is broken). |
01-21-2013, 01:06 PM | #30 |
Member#: 79983
If I was getting that kind of mileage I would certainly not have any concerns, I would be quite happy. Its definitely not my driving habits, I pretty much stay out of boost unless I need to pass someone. Im a firefighter/medic and have had a perfect driving record for nearly 16 years, I am not some idiot kid who boosty boosts beetween every stoplight and such. I never do more than 5 mph over the speed limit as I cannot get tickets in my line of work.
Im hoping its an 02 sensor or something that is throwing the mileage off, Im just gonna go ahead and suck it up and buy new front and rear ones and download the datalogging program so I can send in my results for someone to review. |
01-21-2013, 01:53 PM | #31 |
Member#: 33593
Before you buy 2 new sensors, there is a way to check the sensors are in the appropriate voltage range. I've seen threads on it in the past. I think there are programs that also put out the voltage reading so no need to play w/ a multi-meter.
I understand your frustration, but since u r trying to save money, i think you shouldn't throw money at the problem. Investigate more and drive the civic till you figure it out. Just my 0.02 |
01-21-2013, 07:41 PM | #32 |
Member#: 79983
Do you have a specific link to a thread of you have seen in the past about it ?. That would be appreciated.
01-22-2013, 02:04 AM | #33 |
Member#: 33593
Let me see what i can dig up...
01-23-2013, 04:52 PM | #34 |
Member#: 33593
I couldn't find the exact thread i saw this done, but ran into some other possible solutions you could try. Here is a short thread http://forums.nasioc.com/forums/show....php?t=2281766
01-25-2013, 03:13 PM | #35 |
Member#: 79983
Just a quick check as this may be related to the slightly discomfortable smell coming from the engine.
Is that a breather port ? Im assuming it should be covered cause its caked in grime all around that area. Also talked with agile and they said the same thing you guys did. No need to detune the car or swap back to stock stuff,i should be getting better fuel mileage than stock. They just said something is severely wrong. Vaccum leak. Fuel leak. Faulty 02,fuel connection leak etc etc. I guess i just need to run it down and tear the car apart. |
01-25-2013, 04:08 PM | #36 |
Member#: 33593
Lmk if want a second set of eyes. Or come to the meet Sat and i can show ya how the hoses should be hooked up.
I wonder if the breather to the PVC & the other one on the passenger side is connected.? Can u take pics of the pvc location & passengers side breather? Mario |
01-25-2013, 05:48 PM | #37 |
Member#: 79983
Once i put my son to bed ill try and find the other side. I would come to the meet but i have to leave for work at 5 and work till noon the next day. You guys meet at 4 right ?. But yes would love a second set of eyes. Think im gonna start taking stuff apart so i can take closer looks at the fuel connections.
01-25-2013, 06:35 PM | #38 |
Member#: 33593
Pm me your number... I dont have anything goin on til the meet then a fight.
Mario |
01-25-2013, 08:09 PM | #39 |
Member#: 79983
I have my kid all day until the wife gets home around 4. Wont be doing anything with the car till possibly sunday afternoon unfortunately.
01-25-2013, 08:39 PM | #40 |
Member#: 33593
Ok pm me sun if u want.
01-26-2013, 01:23 AM | #41 |
Member#: 290896
Vehicle:2004 STi, FOR SALE PSM |
I average 14-16mpg in the STi regularly (no longer the DD however) and that's with at least one pull each time I drive it. Make sure your air filter is clean, your plugs are fresh, quality gas, fresh oil, equal tire pressure and a GOOD alignment. When is the last time you had your fuel filter changed? Definatly check your alignment if you haven't done it recently, having even slighly too much toe-in or toe out can really screw with your fuel economy.
01-26-2013, 09:07 AM | #42 |
Member#: 79983
air filter is brand new with less than 100 miles on it, plugs may need to be changed. I use shell 93 since its supposedly really good fuel. Oil change has less than 500 miles, synthetic used after the initial break in of the motor. Alignment was done in march 2011 after the wheels were added and the suspension was installed. Camber kit added as well and car was lowered with a four wheel alignment, car drives straight as an arrow. I will replace the fuel filter and go over my vaccum connections, all my fuel lines and fix that breather port/pcv issue.
01-26-2013, 11:12 AM | #43 | |
Member#: 32669
SCIC
Vehicle:2007 2.34LR, EFR7670 LINK G4+ hybrid STi |
01-26-2013, 11:30 AM | #44 |
Member#: 79983
If I can average 20mpg I would be pretty ecstatic. I have the daily driver civic so when I have time I will be tearing the sti down and inspecting everything, than replacing stuff afterward.
02-09-2013, 03:01 PM | #45 |
Member#: 79983
So after poking around a bit i found this.
I can't recall if that is for the stock egt probe or for an o2 sensor. Trying to nail this stuff down. And input would be appreciated. Thanks. |
02-09-2013, 03:43 PM | #46 |
Member#: 248202
Vehicle:2013 WRX Sedan SWP |
Is that a resistor jammed into it?
02-09-2013, 03:54 PM | #47 |
Member#: 79983
nope, it looks like it is the end of a male clip, solid piece of metal that just plugs in.
trying to figure out why its there and what it goes to. |
02-09-2013, 07:07 PM | #48 |
Member#: 248202
02-09-2013, 07:50 PM | #49 |
Member#: 61724
Vehicle:04 FXT silver |
Looks like the PCV bypass for a silicon turbo inlet mod or the DRL. I did both on mine.
See last page - http://www.perrinperformance.com/sha.../pspint400.pdf |
02-09-2013, 10:48 PM | #50 |
Member#: 79983
Certainly looks like it after reading that.
