09-08-2003, 01:59 PM | #1 |
Member#: 26658
South East
Vehicle:1 Love Grassroots NASA Rally Sport FTW! |
3.0 H6 into 95 Impreza: Phase Two, Wiring
Well, mechancally, the engine is in. Now I'm messing with the wiring harness.
Working with a stock H6 computer and H6 wiring harness, pulling it all apart, labeling everything, and then figuring out what I need and what I don't. Now, here's an interesting thought. The computer is (obviously) available in a "connected to an automatic transmission" model only. Some of the signals to/from the engine are "AT load" and whatnot. I wonder what sort of effect or influence these signals have... Anders |
09-10-2003, 01:31 PM | #2 |
Member#: 26658
South East
Well, found that one of the connectors to a lot of grounds is completely gone... So I have some fabbing of harness to do. Perhaps I'll build the exhaust while waiting for the connectors to arrive...
09-10-2003, 01:40 PM | #3 |
Member#: 756
Vehicle:2003 Legacy L wagon 2009 Kawasaki C14 |
That's very cool.
Is there going to be enough room for the radiator? The engine looks very far forward. Also, what did you do about the transmission? |
09-10-2003, 01:43 PM | #4 |
Member#: 2213
Vehicle:1995 Impreza w/EJ257 Brilliant Red |
ECU Reflash?
I put an automatic ECU into a manual car and it knew that the current car was manual. But I looked to see out of curiousity what signal values were changed by it now knowing it was a manual. One of the key ones was the value for netural from the transmition was reversed. Meaning it was something like Manual neutral the pin on the ecu for the signal recieved 5v but automatic neuteral it received 0v. Just something you will probably want to look into. There were a few others such as EGR system but your engine doesn't have that anyways. I know an ECU reflash was discussed. I wonder how many of these things an ECU reflash would be able to address.
Joshua |
09-10-2003, 01:47 PM | #5 | |
Member#: 26658
South East
2) Ehh, it's about the same 3) Bolted it on. See the H6 Conversion Page it has plenty of pics. |
09-10-2003, 01:49 PM | #6 | |
Member#: 26658
South East
Re: ECU Reflash?
09-10-2003, 02:34 PM | #7 |
Street Racing Instructor
Moderator Member#: 110
Vehicle:1989 1989 XT6 |
Congrats!
Awe man I am absolutely LOVING this.
Anders, I posted this on the XT6 boards. The guys there should have a field day with this. Congrats! I'm really hoping your project is seen through until completion. It's exciting! Keep the news coming......I need to change my boxers. |
09-18-2003, 01:11 AM | #8 |
Member#: 43491
Vehicle:1997 Impreza Outback Red |
that engine looks HUGE, i am suprised it "Bolted right in"
09-20-2003, 06:56 AM | #9 |
Member#: 26658
South East
VROOOOOOOOOOOOMMMMMMMMMM!!!!!!!!!!
IT'S RUNNING!!!!!!!!!!!! Woohooooo! The engine is running! It's been about two weeks of futzing and fiddling, but the engine has started! Eric Adams is here, and we were going through the wiring diagrams again, measuring signals, and tracing. Then we came across one wire that I hadn't marked, and it turned out to be important. Touched it straight to the battery positive, hit the manual crank button, and voila! The first time was a little rough, as the battery voltage was low. Hooked an Optima battery in parallel and vrooooOM! it started right up! Now begins the next step of actually routing all these wires and mounting everything. Then putting in the radiator and cooling system, and figuring out how to adapt the belted accessories from a 1.8 to the 3.0, and so on. Lots of work yet before I can even drive it around the block. No pictures or video yet... I'll get that up at some point. Anders |
09-20-2003, 10:10 AM | #10 |
Member#: 13793
Vehicle:2007 specB, 03 Ram '92 SVX-5 speed |
Nice application of the smilies!
Well done. Good luck with the remaining jobs.
Todd |
09-20-2003, 01:43 PM | #11 |
Member#: 31035
Vehicle:10 Mazda Miata 21 CWP Outback XT |
My question is probably a while off, but what do you think this engine is going to do to the handling characteristics of the car? The H6 is obviously a lot heavier than your EJ18, and I *think* there is still a significant weight difference between the EJ25 that has actually been in a GC8 chasis and the EZ30 which hasn't yet been in that chasis. Any ideas?
Great project! I can't wait to see more on it. |
09-20-2003, 10:17 PM | #12 |
Member#: 2213
been adressed before
Past threads have mentioned that things like light wieght bumper beam, a carbonfiber or aluminum hood and moving the battery to the rear or replacing it with a lightweight quickly help accomidated the weight bias.
Joshua |
09-20-2003, 10:47 PM | #13 |
Member#: 10607
RMIC
Vehicle:'17 JKU Rubicon |
you actually did it...the "impossible"!!
god bless ya. let us know how it drives... |
09-21-2003, 06:56 PM | #14 |
Anders
Will you be offering your services to the general public on doing this swap? What I mean is, say I took an Impreza to your shop and ask if you can do what you did to your Impreza (swap in an EZ30 engine). Would you do the swap? If so, what would be the costs (engine, other parts, labor?)
I just feel you can make a lot of $$$ off of this and have quite a few happy customers. Yeah, I'm getting ahead of myself because it's not complete just yet but you are mighty close. Also, North Carolina isn't terribly far from me. 7-8hr drive or so. Just leaving some options open. |
09-22-2003, 09:53 AM | #15 | |||
Member#: 26658
South East
Re: Anders
I have a 9-5 job that is not automotive related, it's electrical engineering. Quote:
The biggest thing is that for my application, race car, I'm working with a different set of parameters. For instance, my dash is already _gone_. All the wiring is easy to get to. I don't care much if I have to toss the AC... or the heat. To have _everything_ working like it would in a production car... ugh. I wouldn't want the responsiblity. And my girlfriend would kill me if I was working on someone elses car instead of fixing the lawnmower. Cheers, Anders |
09-22-2003, 01:06 PM | #16 |
Member#: 17270
Vehicle:1998 Fender Bender Holds 1000lbs. |
Holy crapola, just seeing an H6 in an Impreza looks awesome
09-24-2003, 05:52 AM | #17 | |
Re: Re: Anders
And you won't be needing that 'nose heavy' Impreza after you complete it and race it a couple of times. *cough, cough* |
09-25-2003, 11:31 AM | #18 | ||
Member#: 26658
South East
Re: Re: Re: Anders
Last night I took out the ABS mechanicals, there's 11 pounds from the front corner. I've already welded in the holder to put an Optima battery in the trunk, that moves another 36 pounds out of the engine bay. The lightweight bumper beam will loose another, what, 20? And then an aluminum hood drops about 20 from the front. So that's about 87 pounds. Won't really know till I get it back on the scales... Anyway, now that I can start the engine and it runs, I'm working on getting lots of other stuff done so that I can actually _drive_ it.... ---BELTS & COOLING--- Return belt to CarQuest Pick up belt at Advance Torque tranny bolts Find engine belt Install engine belt Install fan onto radiator Drop in radiator/fan, final clearance check with engine belt in place Connect upper & lower radiator hoses Connect hoses to passenger compartment Return belt to AutoZone ---MANIFOLD--- fashion some kind of intake filter Remove intake manifold Remove existing intake manifold gaskets and clean mating surfaces Install new intake manifold gaskets Torque intake manifold ---BRAKES--- Investigate rear bias adjuster Bleed brake system Install rear splitter Find 2 brake line splitters Bend lines and install front splitter ---WIRING--- stock computer -remove for wiring access air routing box -remove for wiring access gauges -remove for wiring access remove stock computer pull stock computer harness through firewall figure out how to connect computer to master relay conenct tach output codrivers foot rest -remove for wiring access |
09-26-2003, 02:05 AM | #19 |
Member#: 2272
BAIC
Vehicle:2019 Macan 4cyl 1993 Impreza FWD WRX swap |
Isnt the lightweight front bumper beam more like a 40-50lbs weight loss? Have you actually done it yet?
09-26-2003, 09:12 AM | #20 | |
Member#: 26658
South East
Anders |
09-27-2003, 03:57 AM | #21 | |
Member#: 2272
BAIC
09-28-2003, 04:14 AM | #22 |
Member#: 524
Vehicle:04 STi White |
Don't know about the GC8 but on the bugeye the front bumper beam is at most 40lbs. So its more like a 30lb loss.
which is still a hell of alot. |
10-01-2003, 06:21 AM | #23 |
Member#: 24269
Vehicle:2006 LGT GRP |
Since you're on the topic of weight. Do you have any sense of how much heavier that engine is than the old one? Now, I think I remember reading you had a 1.8L, so I'm sure it is a good bit heavier. I'm really more curious in gauging it against a 2.5L. Many people have the impression that the 3.0 is a lot heavier than the 3.0 too, but I have read other reviews that say it's only a shade heavier. So, can you shed any light, or even real numbers, onto that subject.
10-01-2003, 09:22 AM | #24 |
Member#: 26658
South East
I have guesses, but talking about them is as much use as pissing in the ocean. I had the car on racing scales before the conversion, and it will go on afterward as well. Then we'll all know.
10-01-2003, 12:02 PM | #25 |
Member#: 24269
well said....I'll be anxious to see some real numbers.
Similar Threads | ||||
3.0 H6 into 95 Impreza: Phase Three, Driving | anders8 | Subaru Conversions | 49 | 12-10-2020 05:59 PM |
3.0 H6 into 95 Impreza begins | anders8 | Subaru Conversions | 45 | 05-10-2015 11:17 AM |
3.0 H6 into 95 Impreza: Phase Four, 6 speed transmission | anders8 | Subaru Conversions | 7 | 06-27-2008 11:46 PM |
3.0 H6 | Sidwindr | Normally Aspirated Powertrain | 8 | 05-08-2001 10:57 PM |
2001 Outback wagons make 212hp w/ 3.0 H6 | cakagan | General Forum Archive | 6 | 07-27-2000 10:45 AM |
