08-31-2007, 10:59 PM | #1 |
Member#: 152647
did i fry my coil pack?
Hello, i went to change my coolant hose connected to the top reservoir tank next to the manifold. In the process i spilled some coolant. After i replaced i i started up the car and added some more coolant to top it off (spilled some again). I then went to drive around and just to make sure everything is ok. Then i get a CEL of P0301 on cylinder 1. Did i fry it cuz it was wet? How can i test this coil? is it ok to start the car again to see if the CEL comes on again after it dries?
Thanks.
08-31-2007, 11:17 PM | #2 |
Member#: 52863
RMIC
Vehicle:2007 B7 A4 Silver |
take a multimeter and check for restitance put one lead on the one of the coil leads and put the other lead on another coil lead and check the resitance,
08-31-2007, 11:53 PM | #3 |
Member#: 152647
Do i do that with the key on the ON position ? or just have the car totally off?
thanks |
08-31-2007, 11:59 PM | #4 |
Member#: 52863
RMIC
key off, let me know what the readings are, but if it comes up ofl you have issues
did i fry my turbo? Just installed EWG... | felixk | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 07-19-2009 12:30 PM |
why did my coil packs melt down? | wrxtuner02 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 30 | 03-20-2006 06:16 PM |
can someone check my coil pack wiring for me? | rabbitnutz | Subaru Conversions | 7 | 01-24-2006 10:26 PM |
Boost problem...did i fry my stock boost controller | brazymstrp | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 11-30-2004 02:14 PM |
Did I fry my pads? | driggity | Brakes, Steering & Suspension | 12 | 11-20-2003 07:49 AM |
