10-22-2010, 02:24 PM | #26 |
Member#: 229726
Vehicle:'09 2.Slow OBP |
Do you know specifically which part and where on the air intake?? This noise doesn't seem to sound plastic but more metal but if you're right than I'll be happy if its an easy fix.
10-24-2010, 11:08 PM | #27 | ||
Member#: 169623
Vehicle:2008 2.5i 5d 100k+ Dark Grey Metallic |
Which, I have to say, really pisses me off because the service tech on the phone said it was probably a heat shield, and I told them it was probably a heat shield, and I wanted to pay to get a heat shield fixed, and they said it wasn't the heat shield. So either it's a heat shield, or Subaru's sound like **** normally. I don't have time to go back for an extra trip, so I will take it up with them again for the next scheduled visit. |
10-26-2010, 05:17 AM | #28 | |
Member#: 229726
Yeah I have a feeling its almost definitely a heatshield as well. |
10-27-2010, 09:59 PM | #29 |
Member#: 157783
The air intake duct is what causes this vibration about 99% of the time. You will notice it when at low rpm and a slight to heavy load on the engine. Also it gives the illusion of coming from the passenger side dash/a-pillar. At my dealership we have replaced and insulated the duct on just about every impreza we service.
10-27-2010, 10:17 PM | #30 | |
Member#: 229726
10-28-2010, 12:55 PM | #31 | |
Member#: 169623
And besides, they did the above fix and the first time I drove away from the dealer the noise I'm talking about was still there. |
10-28-2010, 10:13 PM | #32 |
Member#: 229726
^^^Same here
02-28-2011, 08:37 PM | #33 |
Member#: 229726
I just got the car back from the service department earlier today and they diagnosed it as a loose grille...I specifically told them it was a heat shield but they diagnosed it otherwise. They stated they removed and then reinstalled the grille. I even told them it happened while I had the stock 2.5i grille before installed the OEM Sport grille.
The weird thing is, I've driven roughly 5 miles since I got it back and so far the sound is gone. |
03-02-2011, 12:31 PM | #34 | |
Member#: 169623
Weird. Now I have to find those sport grill install threads to find the points to tighten myself. Thanks for the update. |
03-02-2011, 03:44 PM | #35 |
Member#: 229726
06-05-2012, 01:57 PM | #36 |
Member#: 148735
NESIC
Vehicle:2006 WRX wagon Dog Balls |
07-17-2012, 06:02 PM | #37 | |
Member#: 222395
08-02-2012, 11:05 PM | #38 |
Member#: 327995
I have the same problem on my 09. I brought it to the dealer twice with no fix. I'm gonna try the foam by the intake to see if that works
08-06-2012, 06:50 PM | #39 | |
Member#: 222395
I rolled up some carpet foam and it fixed the problem. Does anyone know the part number for the clip? |
08-06-2012, 10:29 PM | #40 |
Member#: 301247
Vehicle:09 Impreza 2.5i MT White |
i also have this issue here in canada with my 09 2.5i sedan. there is a rumble at 1500rpm. it doesnt bother me cause of im rarely cruising at that engine speed. i think its normal for these cars. a rental 2011 i was driving had same issue. i personally think that its pulsating exhaust gases in the headers. also when i turn off my car there is lots of knocking and rattling noise from the cat/exhaust, it's definately sound of hot air in the pipes. again normal but some manufacturers have managed to muffle these stuff.
what bothers me is sound of air rushing probably due to poor intake design on partial throttle. Last edited by Pickler; 08-07-2012 at 12:17 AM. |
Best Way To Gain Boxer Rumble For 2.5i?? | Impreza2.5i-Kid | Normally Aspirated Powertrain | 36 | 07-31-2008 01:44 PM |
WRX/2.5RS/2.5i wing rattle fix. | ScubaruImpreza05 | Car Audio, Video & Security | 17 | 04-08-2008 06:19 PM |
The 2.5i finally has come (boxer) rumble to it | skribblez32 | Normally Aspirated Powertrain | 40 | 11-08-2007 08:47 PM |
Need Rumble on 2.5i | SubIELove | Normally Aspirated Powertrain | 7 | 07-24-2007 11:19 PM |
Real deep rumble from engine | WRXwannbe | Normally Aspirated Powertrain | 7 | 04-06-2001 10:49 AM |
