03-13-2015, 08:26 AM | #901 | |
Member#: 319017
Vehicle:15 Prius 2JZ miata Death Trap |
NASIOC 50-100mph List
Yeah my rev limiter was there also in the 62 and I was trapping mid 130s in 4th with a little room left so it just has to be our difference in tires if you have the same trans. I haven't used 5th gear yet in the 1/4th. Multiple tracks also so it's not like my tracks timing equipment is off or something which is already pretty rare I bet. My 594whp was at 30.5 psi but my passes at the track were on 33ish from memory. On my laptop i think i may have a log or two of me at the track ill try to find it and send it to you tonight..not my 10.4 pass but i assume the trap should be right around there, then you can take a look at how my 62 was doing and give you a idea on your trap may be. Sent from my iPhone using NASIOC
03-13-2015, 10:29 AM | #902 |
Member#: 261612
Vehicle:2002 WRX - 750WHP 9.5s @ 150mph |
Yeah, that would be cool to look at. Knowing your actual tire size as well as your car's weight would help a lot. My car should be at least a few hundred pounds lighter than an average GR STI so that should help traps quite a bit.
Full weight on a GR STI is listed at 3,384lbs so with a few minor reductions and a lightweight driver that would still put it around 3500lbs. My car was around 3,100lbs last year with a full tank of fuel and driver. Now I have no uppipe/downpipe/exhaust so I hope to be close to 3,000lbs with under a 1/2 tank of fuel and driver. Based on those rough numbers and assuming both cars have 650HP the internet tells me this: Your ET / MPH computed from your vehicle weight of 3500 pounds and HP of 650 is 10.21 seconds and MPH of 132.37 MPH. Your ET / MPH computed from your vehicle weight of 3000 pounds and HP of 650 is 9.70 seconds and MPH of 139.35 MPH. These calculators assume a super good launch. The ET's are usually better than most people with Subaru's can do for a given trap. I believe it's like 1.2 or 1.3s range for 60'. It's very hard to get that with a Subaru even on slicks, but the traps should be somewhat accurate. |
03-13-2015, 10:47 AM | #903 |
Member#: 319017
On my old fp red I was down to 3250 with driver but I since added a lot more stuff back into the car plus surge tank and stuff.
I will weigh the car today also outside of the surge tank it should be about the same weight as the 62 was. I know my drag radials are 26 inchs tall so that's what my log from the track will be on. My winter tires are the mystery. With 700hp and 3,300 pounds what is its estimated trap? Not that I'm 100% on the accuracy of vd yet. Sent from my iPhone using NASIOC |
03-13-2015, 12:12 PM | #904 |
Member#: 52314
South East
Vehicle:... 02 and 04 WRXs! 2020 G70 3.3T RWD |
xluben, what's your current setup?
03-13-2015, 12:30 PM | #905 |
Member#: 261612
Details here:
http://forums.nasioc.com/forums/show....php?t=2707544 All pulls have been with the air filter on. |
03-18-2015, 03:28 PM | #906 |
Member#: 57064
Vehicle:2008 STi IAG built HTA86 E85 Kel272s Cos IM |
video has been sitting in my journal for the longest time, I guess I'll throw it in here Short STi gears are short |
03-18-2015, 03:45 PM | #907 |
Member#: 57064
03-18-2015, 05:43 PM | #908 | |
Member#: 319017
Time to put a 26inch tall tire on helps a bit to draw it out to a higher mph. M and h drag radials are only like $550 shipped thru a guy around me who has a couple sets left. I am buying a set tonight. Sent from my iPhone using NASIOC |
03-18-2015, 06:05 PM | #909 |
Member#: 57064
I'm too wimpy to commute everyday on drag radials
03-18-2015, 06:32 PM | #910 |
Member#: 319017
03-18-2015, 08:01 PM | #911 |
Member#: 56203
Vehicle:00 RSTI Coupe Twin Scroll 2.5XTR EJ207 |
550 for all 4? Got any more info?
03-19-2015, 04:57 PM | #912 |
Member#: 319017
Just bought a set today and he said I bought the last set he had bad luck :/. I dded on a set all last summer would have made it more but I must have hit a pot hole pretty hard as the side of one bubbled I noticed when I went to put it back on . Id still buy these for full price though it is a claimed 26 inch tall tire 245/45/18, lasted a whole summer outside of the michigan roads. They are M&H cambered drag radials. Sent from my iPhone using NASIOC |
03-28-2015, 02:55 PM | #913 |
Member#: 328635
NWIC
Vehicle:2004 STi GTX3076R Rally Blue |
Vehicle: 2004 Sti
Motor: 2.5L Forged Pistons, +1mm valves, BC272 cams Turbo: GTX3076 .82 Boost: 25psi Transmission: Stock 6 speed Redline: 8000rpm Fuel: 101 Upgrades: •Perrin ELH w/rotated kit •Perrin duel tube cat back •Tial 44mm EWG •Perrin FMIC •Perrin CAI •Cosworth manifold •ID1000 injectors •Walbro 255 Fuel Pump in tank w/Perrin FST •Perrin fuel rails •DSS carbon shaft •Michelin Pilot Super Sports 235/45/17 Weight: 3238lbs w/driver 50-100MPH: 4.4 sec all in 4th, was doing a 2,000-8,000rpm pull to log for my tuner and figured I would add it to your thread. |
03-29-2015, 09:28 AM | #914 |
Member#: 181717
Vehicle:12 sti hatch w r b |
/\ please post a video of that
03-30-2015, 04:53 PM | #915 |
Member#: 328635
NWIC
03-30-2015, 11:25 PM | #917 | |
Member#: 261612
I have the same gearing, and doing the same number of shifts. I think my lighter weight is helping quite a bit though. EDIT: Just saw you dyno'd at 570WHP Dynojet. The time seems pretty on par vs. what my Virtual Dyno is telling me. Last edited by xluben; 03-30-2015 at 11:31 PM. |
03-31-2015, 01:54 PM | #918 | |
Member#: 130990
NWIC
Vehicle:06 Red Ltd.Wagon Dom 1.5xtr JJ tuned |
I'm hoping to break into the 4's when I go to a SD tune in a couple of weeks and can hopefully add a couple of psi boost (20 now going to 22). As long as it doesn't pull timing... |
03-31-2015, 02:05 PM | #919 | |
Member#: 261612
03-31-2015, 03:03 PM | #920 | |
Member#: 130990
NWIC
It's one of those "looks slow but it's actually fast" things. |
03-31-2015, 03:11 PM | #921 |
Member#: 261612
Yeah, watching the tach jump up and down through multiple gears looks fast, but it would really be much better off if I could just make it through all in one gear like some of the 5MT's or high revving 6MT's can.
When I have all the clips trimmed down to just 50-100mph to check the times I sometimes watch through them all and then it's really much more obvious how close they are in actual time. |
03-31-2015, 04:58 PM | #922 |
Member#: 130990
NWIC
04-13-2015, 06:47 AM | #923 |
Member#: 294644
Vehicle:2011 WRX Agile Auto DGM 440whp 420wtq |
Vehicle: 2011 WRX
Motor: 2.5L Cosworth Piston/Rod Turbo: Dom 1.5XTR 10cm Boost: 25psi tapered to 22psi @ Redline Transmission: Albins Rally Spec 5 Speed Redline: 7000rpm Fuel: E85 Upgrades: •Full Race ELH •Cobb Catted Turbo Back •Tial 44mm EWG •Process West TMIC •AEM CAI •ID1000 injectors •Walbro 450 •Speed Density Weight: ~3500lbs w/driver 50-100MPH: 5.0 sec 3rd and 4th Car Dyno'd 455whp w/ 26psi but had trouble trying to keep at that boost level on the road so we ended up moving it down to 25psi and the car liked it so I'm assuming around 430-440whp? https://docs.google.com/spreadsheets...it?usp=sharing |
04-13-2015, 08:03 PM | #924 |
Member#: 325545
W. Canada
Vehicle:2006 STI OBP |
Holy conservative tune! Good job on the numbers!
04-13-2015, 11:22 PM | #925 |
Member#: 294644
NASIOCers!! Starter mods list | Daniel son | Legacy Forum | 4 | 11-21-2006 03:56 PM |
50 cent listings on eBay motors | plunk10 | Off-Topic | 7 | 10-17-2006 12:15 PM |
Official NASIOC OT C List | dr_wheel | Off-Topic | 25 | 02-22-2006 05:41 PM |
NASIOC GMail Invite List | AVATAR-X | Off-Topic | 458 | 05-21-2005 10:04 AM |
Japan's Top 50 car list | Tragedy | Off-Topic | 5 | 07-29-2003 11:49 PM |
