Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 05-20-2015, 11:51 PM   #976
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
Originally Posted by xluben View Post
Yeah, boost ramps in to try and preserve the motor as much as possible. It still makes 600+ WHP from 6k to 8k so it's fine for running through the gears. I do still worry about lifting a head or cracking a stock sleeve though.
How do you sleep at night knowing what you put your cylinder liners through
user1029 is offline   Reply With Quote
Old 08-03-2015, 12:57 PM   #977
smokey07
Member#: 151683
Originally Posted by smokey07 View Post
Vehicle: 2008 Civic Si
Motor: Stock 106k miles
Boost: ~9psi
Transmission/Clutch: Stock
Redline: 8600
Fuel: 93
Upgrades:
Jackson Racing Supercharger w/ stock 3.2" pulley ~9psi
Hybrid Racing 3.5" cai
Skunk2 Alpha header
Full Race 3" exhaust
Weight: ~3200ish with driver
50-100MPH: 7.4sec
**first attempt at this.. started in 2nd, sloppy shift to 3rd, decent into 4th. Car will go a bit quicker with cleaner shifts but happy with the time considering its a 90-mile per day commuter
still wish it was a suby but it is what it is... same car as above just 1 year later and 20k+ more miles..
Motor: Stock 127k miles
Boost: 5.5-6psi
Transmission/Clutch: Exedy stg 1, stock gearset
Redline: 8600
Fuel: 93
Upgrades:
Sheepey coated manifold
Garrett gt3076r
Turbosmart hypergate + dual port bov
boost junky's piping and fmic
dw 1k + walbro 255
mac 4-port bcs (not plugged in, just running spring pressure)
Vit Viper tuned
Weight - 3200ish w/ me in it
50-100 - 6.6sec checked in a datalog through flashpro..
plugging in the 4-port and going to run ~12psi soon to make a good bit over 400.. e-dyno is reading around 350whp/240wtq right now vs 300whp/200wtq with the supercharger.. pretty fun daily, and its stupid reliable.. but I want my suby one day
smokey07 is offline   Reply With Quote
Old 08-04-2015, 12:49 PM   #978
no694terry
Member#: 220816
2018 Exotruck
logged a 4.88 today, new feramic clutch is helping but still had some 3rd gear slippage
i was still getting on the throttle past 50mph (81kpm) and didnt hit full boost til almost 60mph.
https://drive.google.com/file/d/0By3...ew?usp=sharing
no694terry is offline   Reply With Quote
Old 08-10-2015, 04:22 PM   #979
Wireeater
Member#: 76503
2016 Mustang GT
I don't have the car anymore but this was some testing on my 2012 WRX the other year. Nothing spectacular.
Vehicle: 2012 Subaru Impreza WRX (Sedan)
Motor: Stock - 40k
Boost: ~18psi
Redline: 6500
Fuel: 93
Upgrades:
(Engine)
Invidia Catted Downpipe
K&N Typhoon SRI
Torqued Performance Stage 2 eTune
Weight: ~3400ish with driver
50-100MPH: 8.1
Wireeater is offline   Reply With Quote
Old 11-10-2015, 01:28 PM   #980
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
Originally Posted by Dave D. View Post
Well, after my SD tune I was expecting a better time, if just a little, over the 5.1 seconds. But after several pulls it's extremely consistent at 5.4 seconds. But I don't think it's a horsepower issue. All my previous pulls were done on the factory-spec tire size of 215/45R17's. But this last pull was on 225/45/R17's. Did a speed check and it turns out the bigger tires are dead on, not the factory-spec ones.
Looks like I was doing a 49-98 pull vs. a 50-100 pull. So there's a couple of tenths there. Extra wind resistance -- maybe a tenth? It's really too close to call if I gained much if anything. The only other variable might be temperature. Anyway, 5.4 should be my true reading, not my 5.1. Guess if I really want to go faster I'll be needing a front mount.
Checking against GPS is always a good idea. Another reason why these 50-100mph times aren't perfect, but they're usually close enough. 5.4 is still pretty good. I am surprised your tuner won't push the TMIC more. I know there have been people running into the 10's with a TMIC. My 20G XTR was pulling times in the mid 4's when I had it at 27-28psi on a FMIC, so you should have a little more to go if you push things.
With 12k on the motor I had my builder do a refresh tune -- by installing a bigger MAP he was able to turn the boost up to 22psi from the low 20's. Gained about 25 WTQ, although hp stayed about the same -- more boost, but had to pull 2 degrees up top due to IATs. Managed a few pulls averaging about 5.2 seconds, consistently faster than my 5.4's. So I guess that's about it for pump + octane booster. Maybe I can get into the fours if I put my 215's back on.
Dave D. is offline   Reply With Quote
Old 11-10-2015, 03:38 PM   #981
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here's an updated video from mine:
0-60mph: 1.87s
0-100mph: 4.17s
50-100mph: 2.77s
60-130mph: 4.90s
1/4 Mile: 9.5 @ 150mph
1/8 Mile: 6.2 @ 118mph
60 Foot: 1.565s
xluben is offline   Reply With Quote
Old 11-10-2015, 03:43 PM   #982
user1029
Member#: 57064
2008 STi IAG built
1.87s? Impossibru
Old 11-10-2015, 03:47 PM   #983
340Duster
Member#: 52314
... 02 and 04 WRXs!
2020 G70 3.3T RWD
Xluben, your car is ridic.
340Duster is online now   Reply With Quote
Old 11-10-2015, 04:07 PM   #984
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
Except for the launch that motor lives between 7k and 8.5k. Fantastic build.
Old 11-10-2015, 06:53 PM   #985
no694terry
Member#: 220816
2018 Exotruck
so your saying you go from 0 to 60mph in the length of a standard over the road tractor trailer?
Old 11-11-2015, 08:46 AM   #986
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by user1029 View Post
1.87s? Impossibru
Probably not that accurate.
Thanks.
Yeah, pretty much. I wish it had a little wider spacing between gears.
I'm not really familiar with that form of measurement...?
Old 11-11-2015, 09:24 AM   #987
no694terry
Member#: 220816
2018 Exotruck
I have them around 80' long, so from bumper to bumper your doing about 60mph
Old 11-12-2015, 12:01 AM   #988
krisk
Member#: 333048
2013 WRX
VF52+E85+TP Road Tune
xluben - super cool!!!
krisk is offline   Reply With Quote
Old 11-19-2015, 11:35 PM   #989
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
Did 5-second flat pull tonight. My tuner told me my IATs really climb between 5500-redline, but at 38 degrees it was no longer a factor. Really shot from 80-100. What a huge difference cold temps make. Annoyingly, however, I did throw a P0103 code (mass or volume airflow circuit high input) in spite of a speed-density tune and a new 3-bar map sensor. Boost gauge did indicate 24psi. I'll have to ask my tuner about that. Xluben, I'm only 2.23 seconds behind you, now.
Old 11-19-2015, 11:39 PM   #990
Harey
Member#: 270569
'15 Foz XT & GT86
Did 5-second flat pull tonight. My tuner told me my IATs really climb between 5500-redline, but at 38 degrees it was no longer a factor. Really shot from 80-100. What a huge difference cold temps make. Annoyingly, however, I did throw a P0103 code (mass or volume airflow circuit high input) in spite of a speed-density tune and a new 3-bar map sensor. I'll have to ask my tuner about that. Xluben, I'm only 2.23 seconds behind you, now.
3.23 secs you mean
Harey is offline   Reply With Quote
Old 11-19-2015, 11:44 PM   #991
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
Originally Posted by Harey View Post
3.23 secs you mean
Double-checking -- no, compare the 50-100 times. I still have some catching up to do on 0-60 as well, however -- He's got me beat by 1.93 seconds there.
I'm sure once I throw on a front-mount I'll have him.
Old 11-20-2015, 12:27 AM   #992
Junior2JZ
Member#: 64908
10.8 XT+9.2@155 GR+
9.1/157mph 2015 STI
Wish I logged VSS on CJs car yesterday. I wonder what the 0-60/50-100/60-130 was on it
Junior2JZ is offline   Reply With Quote
Old 11-20-2015, 01:54 AM   #993
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
Does the software account for Einstein's theory of relativity?
Old 11-20-2015, 05:47 AM   #994
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
If you logged the passes just base it off of rpm using a calculator. Close enough for guessing its not like we are using v boxes.
Shortpersonbk is offline   Reply With Quote
Old 11-20-2015, 07:30 AM   #995
no694terry
Member#: 220816
2018 Exotruck
i miss sub 5 seconds. i blew that 2.2 but building a real motor now.
Old 08-16-2017, 05:29 PM   #996
moonlightmidnight
Member#: 472649
Default 48-98mph log
I noticed today in my data logging that I went from 48 to 98 in 1.8 sec so
I searched 50-100 times and found this thread. It's pretty cool. I will have to read through the rules and make a couple logs from 50 to 100.
I have a pro tuned 2005 with a lot of goodies. I was at 21.5psi boost
When I logged the 48 to 98. More to come.
moonlightmidnight is offline   Reply With Quote
Old 08-16-2017, 05:32 PM   #997
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Is that in miles per hour?
Old 08-16-2017, 06:03 PM   #998
no694terry
Member#: 220816
2018 Exotruck
could be glitchy. mine did 69-94 in 0.5 seconds lol
http://datazap.me/u/terryjr/felt-better?log=0&data=2-11
Old 08-16-2017, 08:12 PM   #999
moonlightmidnight
Member#: 472649
Default Yeah man
I was thinking glitchy too. I have two other logs one at 4.6 and 6.3. Sounds. Like a fun test.
Old 01-06-2019, 11:31 AM   #1000
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
I did a 0-100mph pull on my Tesla model 3 Performance for reference:
NASIOCers!! Starter mods list Daniel son Legacy Forum 4 11-21-2006 03:56 PM
50 cent listings on eBay motors plunk10 Off-Topic 7 10-17-2006 12:15 PM
Official NASIOC OT C List dr_wheel Off-Topic 25 02-22-2006 05:41 PM
NASIOC GMail Invite List AVATAR-X Off-Topic 458 05-21-2005 10:04 AM
Japan's Top 50 car list Tragedy Off-Topic 5 07-29-2003 11:49 PM
