02-14-2011, 05:07 PM | #1 |
Member#: 269282
CEL: p0325 and p0420
BONE stock 99 imprezza automatic AWD, 195,xxx miles. Had the car running for a week and out of no where CEL! I smell gas but no hesitation at all.
p0325 - knock sensor, plan on replacing and maybe front O2 sensor? p0420 - catalyst efficiency below threshold bank 1. Like I said no hesitation at all no stuttering but on accusations the ignition will get stuck in lock for like a minute till I shimmy it and start it. Any ideas on this one?
02-14-2011, 05:31 PM | #2 |
Member#: 269282
Anyone know the location of the knock sensor too?
02-16-2011, 06:31 PM | #3 |
Member#: 245018
Vehicle:06 Forester SGM |
under/behing the intake mani im pretty sure.
02-16-2011, 11:04 PM | #4 |
Member#: 255948
Vehicle:95GC 02 Outback H-6 Burg-GC OffWht-Outback |
I replaced the ign. cyl. because it was dragging when I turned it and that was all it took. Guess the 261K had taken its toll on the tumblers. If it is the cyl., they are not that hard to replace and you can pick them up at most parts houses as long as you don't mind having one key for the doors and one for the switch. Knock sensor is under the intake on that one, I believe, toward the rear of the engine. Might try replacing the rear O2 also. P0420 is Cat eff. below threshold and replacing the rear O2 is cheaper than a Cat and can set that code if it is shot. You'll replace it when you replace the cat anyway, so give that a shot first, IMO, HTH!
Similar Threads | ||||
Car throwing CEL: P0031 and P0032 HELP! | Propaganda | Newbies & FAQs | 5 | 10-04-2008 04:18 PM |
Engine Codes P0031 and P0420 | tarbo | Service & Maintenance | 5 | 09-04-2007 11:52 AM |
CEL p0138 and p0420 HELP ME! | fastlanerex | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 02-26-2007 05:19 PM |
CEL: Accelerating and then CEL + feels like timing is pulled? | dowroa | South East Region Forum | 12 | 05-26-2006 12:59 PM |
Question about CATs and P0420 CEL | USA1 | Service & Maintenance | 5 | 01-31-2005 10:17 AM |
