Tire & Wheel Forum sponsored by The Tire Rack |
10-20-2003, 03:45 AM | #1 |
Member#: 31432
Vehicle:2002 wrx midnight black |
rear wheel stud change.
How do you change the wheel stud in the rear??? I stripped one and I need to change it out??. Do you have to take the whole hub out?? If so, HOw??????
10-20-2003, 10:21 AM | #2 |
Member#: 38120
South East
Vehicle:1991 Rio Red Legacy Turbo |
From what I saw with a friend's 2.5 RS, you just remove the wheel, caliper and rotor. The hub should be right there with a few (5 or so) screws holding a plate that holds the studs on. It should be about the same for a WRX.
If this is wrong, someone please correct me. |
10-20-2003, 12:14 PM | #3 |
Member#: 31323
Vehicle:02 RS midnight |
the studs are actually pressed into the hub. line up the stud with the hole in the back, look you'll see it, and knock the stud out. an air hammer works the best.
for installation, we used to put the stud in as far as it would go, use the end of an old closed end wrench for a spacer, and an old lug nut. then use an impact gun (although this is probably not as good an idea as say a torque wrench) to pull the stud tight to the hub. -PJ |
10-20-2003, 01:51 PM | #4 |
Member#: 31432
The thing is I have bought arp longer studs. they are 2.5 inches long. so I guess I am gonna have to take the hub out.
10-20-2003, 02:59 PM | #5 |
Member#: 38120
South East
I was close. Just didn't realize they were pressed in.
Similar Threads | ||||
A rear wheel stud change? | Kahn23 | Brakes, Steering & Suspension | 9 | 08-28-2010 02:52 PM |
change rear wheel studs with drum brakes? | jasona | Brakes, Steering & Suspension | 1 | 05-26-2006 12:58 PM |
Replacing rear wheel studs, difficulty? | Chav | Tire & Wheel | 8 | 09-28-2005 11:43 PM |
rear wheel stud replacement??? | mbwrx20 | Brakes, Steering & Suspension | 2 | 10-20-2003 02:11 PM |
stripped rear wheel stud problems | eastbaysubaru | Service & Maintenance | 7 | 08-16-2002 01:52 PM |
