Brakes & Suspension Forum sponsored by The Tire Rack |
04-25-2010, 08:20 PM | #1 |
Member#: 161569
Vehicle:2006 WRX Stage 2 Crystal Grey Metallic |
A rear wheel stud change?
Hello,
If I have to change a rear wheel stud, do I have to also replace the wheel bearing too? I have looked here and at Scoobymods, but the walkthroughs that I saw were for a 2002 Subaru and I think a 2004, but mine is a 2006 WRX. I was hoping it would be just the wheel stud and that's all, but I don't know. Thanks
04-25-2010, 09:32 PM | #2 |
Member#: 219162
Vehicle:2011 WRX Sedan Base Silver |
Just a stud. I had to replace one on my '05 STi.
04-25-2010, 09:44 PM | #3 |
Member#: 227995
just hit the stud out with a hammer and then pull back the brake shoe to get it out, then just put the new one in and thread a open faced lug nut on untill it is drawn back into place.
i actually just did this yesterday to a 3000gt lol |
04-27-2010, 08:33 PM | #4 |
Member#: 161569
Thank you for the replies. That takes a load off of my mind. I would have responded sooner, but I have been water-proofing my basement the past 2 days and it has been hell.
Thanks again. |
04-28-2010, 01:14 AM | #5 |
Member#: 124254
NESIC
Vehicle:2006 06 SGM Slowbaru "The Scoobinator" |
Just make sure you move the ABS tone ring out of the way first. You definitely don't want to smash that.
04-28-2010, 07:09 PM | #6 |
Member#: 161569
04-29-2010, 09:33 AM | #7 |
Member#: 202930
South East
Vehicle:2007 WRXLimited vf39 2006 Baja Sport |
Had to change one on my '07. It's fairly easy. If you can do a brake job, you can figure it out.
As for the abs ring, I think it is held in with one bolt, maybe two. If I remember correctly, it's magnetic too. |
04-29-2010, 12:18 PM | #8 |
Member#: 124254
NESIC
Re: A rear wheel stud change?
It's the silver ring behind the face of the hub. It's held on by 4 or 5 5mm hex bolts. Once you have those out, it's pretty easy to move around, as long as you took the sensor out first. Finagling the new stud into the hole is a bit tricky though. I used a pair of needlenose pliers.
08-25-2010, 01:18 AM | #9 |
Member#: 254785
sorry for thread jacking, but i'm putting in extended studs, does anyone have advice on removing the hub?
08-28-2010, 02:52 PM | #10 |
Member#: 246851
SCIC
Vehicle:2007 UGM 2012 LR |
Use one of those magnet sticks to gain control of the bolt..taking it out or putting it in through the hole..it will help.
As for the tone ring its easy to move around it after its off the bolts..just make sure u don't pressure it. I didn't know and I used it to help secure the bolt back in and tried tighten it and it cracked it. Been driving with the ABS light for like 2 month lol..its gonna cost me 3-400 bills at the dealer to change the bearings n all that. |
change rear wheel studs with drum brakes? | jasona | Brakes, Steering & Suspension | 1 | 05-26-2006 12:58 PM |
Replacing rear wheel studs, difficulty? | Chav | Tire & Wheel | 8 | 09-28-2005 11:43 PM |
rear wheel stud change. | mbwrx20 | Tire & Wheel | 4 | 10-20-2003 02:59 PM |
rear wheel stud replacement??? | mbwrx20 | Brakes, Steering & Suspension | 2 | 10-20-2003 02:11 PM |
stripped rear wheel stud problems | eastbaysubaru | Service & Maintenance | 7 | 08-16-2002 01:52 PM |
