05-27-2005, 05:54 PM | #1 |
Member#: 69586
International
help with hella horns
I had a set of supertones installed using the relay and all was fine until a bodyshop messed somehting up. I am trying to put the relay back on with the harness I made. I saw that one of the wires wasn't in secure, so I fixed it but the horns still wont sound with the relay. I can hear both the subaru and Hella relay clicking when I press the horn. Could it be a bad relay?
05-27-2005, 06:29 PM | #2 |
Member#: 51002
SCIC
Vehicle:2016 Pig STi Pearl |
markadopolous
05-27-2005, 06:52 PM | #3 |
Member#: 69586
International
sanchez
05-27-2005, 07:47 PM | #4 |
Member#: 31719
NWIC
greek?
Check the grounds on the horns themselves. |
05-27-2005, 08:19 PM | #5 |
Member#: 51002
SCIC
schmordadropalotabass
05-27-2005, 08:58 PM | #6 |
Member#: 69586
International
horns were grounded, relay was grounded, fuse was good........I dont understand
05-27-2005, 09:03 PM | #7 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Probe around with a meter or test light to find where the power is being lost.
05-27-2005, 09:47 PM | #8 |
Member#: 69586
International
ok now all i need is a meter. thanks.
05-27-2005, 10:48 PM | #9 |
Member#: 31719
NWIC
meter is the best but your not dealing with anything really complicated here. What happens if you run a wire fom the battery to the wire that connects the horns to the relay(unhook the wire from the relay and apply direct power from the battery) If this sounds the horns then you either have a bad relay or you have it connected to the relay improperly.
If it doesn't sound then you know you have either a bad ground, a bad power connection or a bad horn. |
05-28-2005, 06:05 PM | #10 |
Member#: 69586
International
Well, it turned out to be a bad relay. I picked one up at autozone for 3 bucks and now I can make people deaf again. Thanks for all your help.
Need help with Hella Horns install. | Angel81 | Mid Atlantic Impreza Club -- MAIC | 5 | 04-14-2009 07:26 PM |
for those with hella horns... | Suby*Doo | Newbies & FAQs | 39 | 07-27-2007 05:33 PM |
Need some help with Hella Horn Install | Dragonbreak | Interior & Exterior Modification | 18 | 07-22-2007 07:52 PM |
Subie owners with hella horns...brushless car washes ok? | tacomaprime | Interior & Exterior Modification | 3 | 12-03-2005 11:49 PM |
WRB with Hella horn & w/o front grille & Debadged w/ "Subaru" decal&Custon Hea | WRXVII | Member's Car Gallery | 12 | 09-04-2002 12:43 AM |
