02-22-2008, 04:51 PM | #1 |
Member#: 160784
Vehicle:02 wrx silver |
boost spike / surging when raining
anyone have any clues as to what could be causing this? the boost only spikes when it is raining outside. does it in every gear...coming home on the interstate today running 80 mph around 3000 rpm...it felt like it wsa goign to shut off on me. almost like the motor was having misfire issues...but it only does it when it is raining.
went through a drive through carwash earlier this week and noticed the same thing for the first few minutes...so it seems to stop after everything is dry...i am lost at this point and really don't want to get rid of the car...but at this point i can't drive it in the rain...so i might as well have a motorcycle
02-23-2008, 03:28 AM | #2 |
Member#: 51684
It'd be easier for people to help you troubleshoot if you listed the mods you have.
02-23-2008, 09:23 AM | #3 |
Member#: 160784
sorry.
2.5l STi block with WRX heads TGV's have been removed uppipe/turboback VF39 with modded injectors and a walbro 255 shortram intake I am going to try swapping out the intake and see if it is the MAF getting wet. |
02-23-2008, 10:24 AM | #4 |
Member#: 148681
Vehicle:TBD Looking for STI Back in the Game! |
Well take the rain out and what do get? A dry car, and it seems you have a possible electrical short or grounding issue. Go back to the last time the car didn't do it and think what you modded if nothing then start at the MAF.
Have you ever had that tuned by a pro? |
02-23-2008, 10:38 AM | #5 |
Member#: 165106
Vehicle:2017 WRX Gray |
I would swap out the intake, checking the maf is def. your best bet.
02-24-2008, 09:09 PM | #6 |
Member#: 160784
yes just got tuned by SS at topspeed...talked to the origional owner about the issue, he suggested going back to the stock air box....but i think i will just swap out the short ram for a true cai and see what happens.
What could cause this surging when boosting for the fisrt time in the morning?? | jugger | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 12 | 06-09-2012 03:16 AM |
not normal boost spike/surge | seanathanq83 | Open Source Reflashes | 10 | 08-19-2009 01:51 PM |
Boost surges when I try to hold it at 10psi? | BigD54 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 20 | 05-23-2009 05:17 PM |
Boost Spike/Compressor Surge | 94'325is | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 08-24-2006 10:14 PM |
Boost spiking/surging | jetsiphon | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 03-15-2005 08:06 PM |
