04-29-2010, 12:32 PM | #1 |
Member#: 235475
PRSIC
Vehicle:2008 WRX Silver |
What's the law like on your part of town?
Just like the title states... I'm not promotting anything. I was just bored out of my A$$ and thought this would be a good topic to talk about.
Let me start... I'm from Puerto Rico... Speeding Let's say I get caught doing 85 mph on a 55 mph zone. Here's what happens... First of all, ask the officer to show you the meter. Whether I was going at that speed or not, checking it can be useful. Most officers claim to have caught you at a certain speed. I could say that 80% of the times that happens, the officer just used the last speed captured from a previous speeder, and he will continue to use it until someone tells him (or her) to reset the meter after you've seen what he's pulling you for. You'll notice this a lot when an officer pulls to the side of the road, starts handing out speeding tickets to everyone that passes by, and he's nowhere near the patrol car to operate the meter. So, 85 on a 55 mph zone... Here's how the ticket works: You get a $50 fine for going over the speed limit, plus $5 for every single mile you went over. This means $50 +$5 x 30 miles, the ticket ends up being $200. You won't get a citation, but if you don't agree with the fine, you have 30 days to file a complaint. When you go to court, most of the times the officer doesn't show because the time spent in court is not paid, whether they're on duty or not. When this happens, the ticket gets archived and you won't have to pay for it. If the officer does show, and you know he was right, you'll probably end up feeling like a dumbass. Now, let's say you're doing 105 mph... Here you get a $500 fine, no citation, and if you file the complaint, pray for the officer not to show... Illegal Street Racing Here, they call it "Performance Measuring"... This is a tricky one. If you get caught street racing, you'll get a $3000 fine plus a citation. Your license will be revoked for 6 months (the first time and after the citation, indefinately the second time). Now, here's the tricky part... For the officer to claim "Street Racing", at least 2 cars have to get caught, otherwise you can prove in court that you were just speeding, and the officer needs to mention the speed you were caught at. Another line of defense is explaining how you got caught. From what I've heard from my friends, every time someone got caught, the officer would be far away, or headed in different directions. If the officer claims you were doing over 90 mph in this situation, then he needs to explain to the judge how fast He was going so that he could catch up to you. This is where some of the cases fail. The other situation... If there's no other vehicle caught, or any info on it, then all that applies is a speeding ticket, and the "Street Racing" charges are dropped. Still, you'll have to pay that fine. If you're not street racing, but you're near some place it's happening, the officer will inspect your vehicle thoroughly. You'll probably end up with fines in the $300-$500 range just for being there. And, since they already have your info, some ridiculous phantom tickets might pop up when you go to renew your license, i.e. "using slick tires on pavement"... HID and Fog Lamps Here, there's no specific law for HID systems. When an officer pulls you over because of this, the ticket he can write you for is "Using High Beams". For cars with projector headlights (no matter if they are true HID or halogen), you always get separate high and low beams. So, you can prove in court that you were not using the high beams, present some pictures of your headlight and demonstrate. If you don't have projector headlights, you're screwed. Another way you can prove NOT having the high beams on is if your car has factory Fog Lamps. Be sure that, if you're in this group, you'll get a ticket for the HID's and another one for the Fog Lamps, but that's where the ticket falls apart. If you have factory Fog Lamps, you know that when you turn on your high beams, the Fog Lamps go off, which is a good line of defense when you're in court. But, the law regarding Fog Lamps states that: 1- You cannot add the Fog Lamps, they have to be factory installed 2- If they're on, they have to be aiming to the floor (hence the factory installation) 3- They cannot be used alone, low beams must be on. So, by these 3 points, the case falls apart quickly, for both tickets. That is if your car is equipped with factory Fog Lamps. In other cases, if you have blue or pink HID systems, you're screwed as well because the law also states that light can't be colored. So here, you have to keep it under the 8000K HID range. Exhaust Systems This is the funny one... Make sure that it is made for your vehicle, and that the brand is your vehicle's brand (as TRD is for Toyota). Otherwise, here's what happens: You'll get pulled over for the noise. The ticket goes as follows: "Altered Exhaust System". Now the funny part... The way officers test this on your vehicle: If their boot tips fit the inside of your muffler tip, then you have an "Altered Exhaust System"... Yep, this does mean that you'll even get a ticket for those $10 exhaust tips from AutoZone, and it'll be a pain in the A$$ proving it's just that. Again, just pray for the officer not to show in court... Lane Changing This will be 3 tickets combined: - Improper Lane Change - Improper distance between vehicles when changing lanes - Not using turn signal when changing lanes And if he has a speed recorded in the meter, a fourth one: - Doing XXmph in a XXmph zone You'll end up with close to $400 in fines. Now, let me hear yours...
04-29-2010, 12:43 PM | #2 |
Member#: 39905
NWIC
well at least you posted in the appropriate forum... |
04-29-2010, 01:00 PM | #3 |
Member#: 200730
Vehicle:'08 E92 M3 '95 GC ZJ |
04-29-2010, 01:00 PM | #4 |
Member#: 78408
You have no laws in Puerto Rico, so don't worry about any of those.
04-29-2010, 01:03 PM | #5 |
Member#: 23676
NESIC
Vehicle:. |
Having been to Puerto Rico I can tell you that its VERY different from the mainland, and as much as its technically part of the US, anyone who lives in the US and has been to PR, can tell you, its a different country.
I liked it actually. Pretty neat place. |
04-29-2010, 01:40 PM | #6 |
Member#: 239452
Vehicle:2012 Volvo S60 T6 2005 Outback 2.5i |
Apparently it's also the general rule to bump people's cars through 4 way intersections. I learned really quickly and thankfully not in a good car that stopping at stop signs is a no-no, and will be proceeded with horns blaring and bumper cars ensuing.
04-29-2010, 01:43 PM | #7 | |
Member#: 234716
Vehicle:2005 WRX WRB |
04-29-2010, 02:36 PM | #8 |
Member#: 200730
04-29-2010, 02:57 PM | #9 |
Member#: 184977
South East
Vehicle:99 Impreza RS '13 BRZ |
in my town they just shut the police station down yesterday sooo...im gonna go do some mad tyte skreet racin through the local school zone
04-29-2010, 03:26 PM | #10 |
Member#: 225192
South East
Vehicle:2008 BMW E92 M3 Bat Mobile Black |
Just toss the cop a little coin and he'll leave you alone
04-29-2010, 03:32 PM | #11 |
Member#: 222689
Vehicle:2006 STi 2013 Outback 3.6 R |
04-29-2010, 03:48 PM | #12 |
Member#: 184977
South East
04-29-2010, 03:54 PM | #13 |
Member#: 200288
BAIC
Vehicle:2002 Impreza WRX World Rally Blue |
04-29-2010, 07:14 PM | #14 | |
Member#: 88618
SCIC
04-29-2010, 10:19 PM | #15 |
Member#: 225192
South East
Ma name a Borat!
04-30-2010, 02:21 AM | #16 |
Member#: 245545
They dont bother us at all in upstate ny for loud exhaust. unless you're doing something dumb, in which case it just gets tacked on to whatever you were doing.
04-30-2010, 05:41 AM | #17 |
Member#: 231058
TXIC
The cops here in Vegas have MUCH bigger things to worry about than modded cars...besides, everybody here drives 10mph below the speed limit anyways. When you do see a race, it's usually a one sided race between some punk in his Autozone special Civic and an unsuspecting tourist driving his rented Hertz Corvette.
05-05-2010, 11:58 PM | #18 |
Member#: 235475
PRSIC
05-06-2010, 01:09 AM | #19 |
Member#: 219009
Vehicle:2018 LBP WRX Ltd. 2005 PSM WRX - St.2 (rip) |
I had a sitdown with a Jersey cop when I got arrested (not for a moving violation) and he told me cops don't pull people over on the parkway unless you break 80mph. That is why I go 78 and have never had a problem!
05-06-2010, 01:51 AM | #20 |
Member#: 225998
South East
Vehicle:2011 STi Spark Silver Metallic |
i've been told its about the same on all the highways around chicago. i hit 78 and cruise control too and have yet to have encounter.
05-06-2010, 09:53 AM | #21 |
Member#: 175170
Vehicle:2005 WRX Wagon owl + bungee cord= my a$$ |
Got pulled over for and issued a ticket for "imprudent speed", really, thats what the ticket said.
I was |
05-06-2010, 02:35 PM | #22 |
Member#: 222835
SCIC
Vehicle:2007 Forester |
IF you go over 25+ mph than speedlimit, police man can put you in jail. That's wreckless driving
06-11-2010, 07:03 AM | #23 | |
Member#: 235475
PRSIC
Where is this? Here, wreckless driving is simply called "racing". Why? The fine for racing is more expensive and more record damaging than "wreckless driving". What they do is plague you with fines:
So, last night I got caught speeding (I needed to use the bathroom, and fast) doing 81 mph on a 50 mph zone (31 mph over... or so the officer says). It was about 11pm and the road was pretty clear. I had seen the the cop car headlights, but it was so dark, I just thought it couldn't be, so I kept on going. When he caught up to me, he asked if I wanted to race. I was alone, no other cars around, so I'm guessing he asked that because he couldn't keep up with me until I got to a stop light. A question... I know it's illegal in most states, but not here in PR... Can anyone recommend a good brand for a radar detector? I had a Whistler on my previous car, and it worked great for around 6 years, but I left it when I sold the car because the power supply was hard wired to it. I was doing fine these past couple of months without it, but I realized last night that it has been 6 years since I got a speeding ticket, so there might a reason for that. I had taken some fines before, but never for speeding because of my radar detector, and since the fines here are a bit ridiculous ($205 for last night), I've decided to spend the money again on something that I know will save me hundreds. So, what can you guys recommend, apart from me to stop speeding? |
06-11-2010, 02:17 PM | #24 |
Member#: 246426
Vehicle:2005 Impreza WRX STi Platinum Silver |
Id get an Escort or a Valentine, these are the two best radar detector brands out. Be prepared to spend at least $300 on one tho.
06-11-2010, 02:25 PM | #25 | |
Member#: 240385
NWIC
Vehicle:E92 BMW M3 |
I have used both the V1 and Escort and prefer the V1 just because of the arrows. |
So, what's the weirdest ornament on your tree? | Layman | Off-Topic | 32 | 12-19-2006 09:46 PM |
What's the shelf life on your average fart? | impez | Off-Topic | 21 | 11-09-2006 12:06 PM |
What's the quality like on JDM engines? | AlucardR | Subaru Conversions | 14 | 03-09-2004 11:42 AM |
I shall be on your side of town soon! | Hondaslayer | Mid Atlantic Impreza Club -- MAIC | 0 | 06-05-2003 11:50 PM |
