Brakes & Suspension Forum sponsored by The Tire Rack |
12-03-2008, 09:33 PM | #26 | |
Member#: 104922
MAIC
Vehicle:2016 WRX |
Here's a good one http://forums.nasioc.com/forums/show....php?t=1515466
01-07-2009, 01:41 AM | #27 |
Member#: 88501
BAIC
Vehicle:2011 WRX Hatch Dark Grey |
When assembling all this stuff, do you need to grease the parts... especially the scooby spacer and the contact of the conical washer to the strut tops?
01-07-2009, 01:48 AM | #28 |
Member#: 71092
MWSOC
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
No, if those parts are moving relative to one another, you're already screwed.
01-07-2009, 07:38 AM | #29 |
Member#: 118698
MAIC
Vehicle:07 WRX Ltd Wagon 94 Miata |
My factory rears had a lower rubber seat that fit between the bottom of the spring and the top of the strut perch. It does not seem to appear in the pic. Did you reuse these on the D-Specs? I didn't, but that's mainly because I didn't notice the lower rubber seat until after I had both sides assembled and one side reinstalled. The spring seemed to sit just fine without the lower rubber seat, so I am thinking it won't be a problem. So far, I have not noticed any ill effects.
01-07-2009, 12:46 PM | #30 | |
Member#: 88501
BAIC
You're in no danger without them, but if someone ever is in the process of assembling struts/springs, they probably should put it on there. |
01-08-2009, 12:36 PM | #31 |
Member#: 88501
BAIC
%&*%^&*$ ok, one difference with Ohlins FPS struts vs d-specs on the install is that because the Ohlins are inverted, you can't use the "mouse pad and vice grips" method to hold the shaft to prevent it from spinning. Therefore, you MUST use pass-thru sockets and hex wrench.
BTW, anyone know the actual size of the hex wrench that fits? (I haven't finished assembling because of this tool snafu) Also... I wasted a lot of time fiddling with the right position for the spring compressors on the front springs. Because the fronts have barely 3 coils exposed (unlike your average import car), it's not so obvious where to put the spring compressors. And the compressors MUST span at least 3 coils... 2 is not enough The problem with 3 now is that the compressor will get stuck in the perches. The only place I found that worked was one compressor goes about 2" in from the end of the bottom coil. The other compressor goes about 4" in from the end of the top coil. And unfortunately this is NOT 180 degrees apart... more like 160. Another thing... make sure to orient the compressors so that the tightening nut of the compressor is pointing to the TOP of the strut. If it's pointing to the bottom, the perch has a tendency to get in the way of a wrench. You need to majorly compress the springs because they won't sit nicely in the perches while you line up the top hat/perch. This is because the strut sits at an angle in the car and so the spring is tilted at an angle. This bring you to the next problem... make sure you have a hex t-wrench and pass thru socket set for the top nut. You have to tighten the nut (but not torque) at this time or else the pieces won't be aligned on the shaft. Don't forget a 14mm washer for the rears to space the top nut away from the top hat. Often, the threads on the shaft don't "go deep enough" and the nut stop (due to lack of threads) before it makes contact with the top hat surface. |
01-08-2009, 01:25 PM | #32 |
Member#: 38772
MAIC
Vehicle:2 Cars, No Bling |
Why won't the "mouse pad/vice grips/hold the strut with your hand" procedure work on inverted struts? Rather than holding the shaft, you're holding the housing, which is the part that will move with the tophat, preventing the assembly from tightening. Am I missing something?
Actually, now that I think about it, this is the same thing that I've done with STi struts, which are also inverted, and it worked fine. |
01-08-2009, 01:29 PM | #33 | |
Member#: 88501
BAIC
Also... pretty hard getting your hand in there between the coils to get a good grip. And no, I don't feel comfortable using vice grips on my strut housing. |
01-08-2009, 03:19 PM | #34 |
Member#: 109216
MAIC
Vehicle:08 STI DGM 76-77 Lancia Scorpion(s) |
For the wagon pinks in the front I used one compressor covering two coils and the other compressor on the other side covering three coils. The line that connected the two compressors was either perpindicular or parallel to the strut ear (can't remember). The main PITA for me was to get the spring uncompressed and have everything keep alignment (rubber isolators seated properly and the 3 tophat holes facing in the correct direction). If you don't have anything to hold the strut and are only using hand tools you kind of have to be a brazilian jujitsu master to simultaneously hold the strut assembly and wrench the compressors (at least for the cheapey Harbor Freight compressors I was using).
Try using a hose clamp or two around the mousepad and grabbing the tails of the hoseclamp with the vice grips. It always made me nervous vice gripping the shaft. |
05-05-2009, 05:59 PM | #35 |
Member#: 180395
SWIC
Vehicle:2008 Impreza 2.5i Red |
Ok in your first picture you have the "insulator"(?) on the spring when you install it. Is this necessary? I just put the cobb springs on my 08 and in the front I'm hearing a clanking sound when I go over bumps and I'm wondering if I didn't rotate the spring in the lower perch to the stop or if the spring is vibrating against the raised edge of the perch.
05-06-2009, 07:54 AM | #36 | |
Member#: 58797
MWSOC
Vehicle:2011 Legacy 2.5i Steel Silver |
Also, did you orient the upper spring perch properly? I know for the 02-07 front struts, there were three holes in the upper spring perch that needed to be pointed outward (or, in the same direction as the lower strut clevis/bracket. Lastly, did you torque down the upper strut nut properly? If that's loose, the hole thing will rattle over bumps. |
05-06-2009, 07:54 PM | #37 | |
Member#: 180395
SWIC
10-18-2012, 08:45 PM | #38 |
Member#: 97732
RMIC
Vehicle:2004 STi 65 Nova 8.80@151 |
Bumping this old thread... This should be sticky'd. By far the best detailed strut assembly pictures I've ever seen on this board.
10-19-2012, 07:45 AM | #39 |
Merci Buckets
Moderator Member#: 88606
MWSOC
Vehicle:2018 Grand Cherokee Velvet Red Pearl |
Done. Added to the install/walkthrough sticky.
11-20-2012, 11:07 PM | #40 |
Member#: 111692
Tri-State
can you clarify which 14mm washer to get. The typical SS and SAE spec 14mm washers are too big (outside diameter) to comfortably fit under D=spec nut inside the top-hat.
11-21-2012, 01:39 AM | #41 | |
Member#: 88501
BAIC
11-22-2012, 01:06 AM | #42 |
Member#: 111692
Tri-State
thanks, do you remember part number/manufacturer. Our local Vatozone had only M12 washers, the salesman claimed it was biggest size they have. I may try to order online.
Did the washer help to eliminate rear clunk? Also, considering D-specs are sedan strats how is the alignment? Can you still get within OEM specs? or need camber bolts? |
11-23-2012, 12:44 PM | #43 | |
Member#: 88501
BAIC
I actually have Ohlins FPS (sedan) struts on my wagon so the rear clunk issue was never present. However, I did note that without the washer, the top nut ran out of threads before it was actually holding the top hat flush; ie there was top hat play and I could clack it up and down. With the washer, the nut is able to hold the hat down. So I'd say I needed the washers. As for camber... you have no choice but to do SOMETHING about it. I never aligned it with only sedan struts because I already knew that wasn't going to work. You'd get something closer to 0 camber max with sedan struts and that just defeats the whole purpose of a more performance oriented suspension over stock. So I'd recommend just getting the Whiteline Com-C's to go with your new D-specs. You probably don't want to be using old top hats anyways, and if you're going to buy new hats you might as well buy the com-c's. That being said, with Com-C's I could only get a lousy -1.0 camber max out of them. Which SUCKED. So now I'm working on the slotting solution with the Com-C's (because I like the caster). And/or the H&R Triple-C's camber bolts in the front lower. (H&R's have a torque spec much closer to the stock bolts... wayyy more than the SPC camber bolts). This is a work in progress. You last, most costly and most correct solution would be sedan arms (and sedan sway bar, endlinks, probably axel). In the rear, I'm not sure. I had SPC camber bolts in the top. |
03-23-2013, 07:15 PM | #44 |
Member#: 290298
MWSOC
Vehicle:2007 Impreza WRX TR Blacked |
Did u use stock bump stops if so did u cut them
Similar Threads | ||||
Is it my imagination or is this racist? (pic inside) | edkwon | Off-Topic | 28 | 06-09-2008 12:20 PM |
Is this correct? | lilsix | General Community | 9 | 01-27-2005 01:08 AM |
Is this correct engine air filter for STi? | 2dino | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 12 | 04-25-2004 11:30 PM |
Is this correct for Boost ? | waitandbleed92 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 04-15-2003 11:50 PM |
Is this correct | WR-REX | Texas Impreza Club Forum -- TXIC | 4 | 07-01-2002 07:53 AM |
