02-26-2003, 03:29 AM | #1 |
Member#: 25243
SCIC
Vehicle:2006 Legacy Outback Blue |
Which Up-pipe for best Torque ...
I'm looking for an up-pipe that will give me the best possible improvement in lower-end torque ....
APS, Zero, Scoobysports, Vishnu? Best place to buy it ... ?
02-26-2003, 05:18 AM | #2 |
Member#: 2692
TXIC
wrong forum man, this is supposed to be in FACTORY forced induction. But to answer your question, if I was to buy any uppipe, it would be PDE or a JDM catless.
02-26-2003, 10:36 AM | #3 |
Member#: 31624
Vehicle:02 WRX White uppipe, turbo-back, MBC |
Ignore Kaos200. If your car has FACTORY forced induction (turbo from the factory) then your in the right place.
There have been no scientific tests done to answer your question. No side-by-side comparison dynos have every been done with uppipes on the same car, same dyno, same day. So no one really know which one would give you more torque. That being said I would recommend APS if your were to buy one. A guy did test gutting his uppipe -vs- an aftermarket upipe and they were identical in HP and Torque. Not bad for a free mod. |
02-26-2003, 10:56 AM | #4 |
Member#: 14934
Vehicle:2002 WRX WRB |
I'd be very surprised if there was a performance difference between aftermarket uppipes. Even the various uppipe manufacturers don't claim to make more power than competing uppipes.
02-26-2003, 11:00 AM | #5 |
Member#: 3767
SCIC
Vehicle:2015 WRX Limited WR Blue |
I'd have to agree with Mattr; go with the APS uppipe...it's got some pretty slick tweaks built into its design. AFAIK none of the other aftermarket uppipes can compare. I'll probably switch to the APS pipe when I upgrade turbos...I'm tired of dealing with my leaky upipe
http://www.airpowersystems.com.au/wr...pe/up_pipe.htm |
02-26-2003, 11:36 AM | #6 | |
Member#: 7327
NWIC
Vehicle:2008 Mazdaspeed3 2006 Wrangler Sport |
At any rate, the uppipe to choose for best torque would be one that is not oversized (meaning the ID is less than 2" since the turbo inlet is less than 2"). Oversized uppipes do not flow better when they still have to go into an inlet that is smaller. The Perrin and Vishnu pipes are both made of very high quality materials and correctly designed, size and fit wise. The perrin is much lower price though. I'd highly recommend using header wrap on any uppipe you end up with. The added heat retention will garuntee faster turbo spooling and less escaped heat to the engine bay to heatsoak your coolant/intercooler/oil. |
02-26-2003, 01:27 PM | #7 |
Member#: 8281
Vehicle:1967 Alfa Romeo GTA |
Theoretically the APS uppipe should be superior as it appears to be a heavy cast material and there should be less heat loss before entering the turbo and therefore should slightly improve spool-up.
Also, castings tolerate heatwrap much better than tubular manifolds. |
02-26-2003, 02:13 PM | #8 |
Member#: 24570
Vehicle:wrx 13.51@98 1/4 1.72 best 60ft |
APS or Perrin are the 2 best Uppipes on the market today, I think.
02-26-2003, 02:50 PM | #9 | |
Member#: 31624
02-26-2003, 07:26 PM | #10 | |
Member#: 7327
NWIC
(1) APS (best by far thanks to it's cast iron and flex joint) (2) Vishnu (high quality materials, very strong) (3) Perrin (hi-quality matls, thoughtful bungless design, low price) |
02-26-2003, 07:27 PM | #11 | |
Member#: 7327
NWIC
02-27-2003, 12:56 AM | #12 | |
Member#: 3767
SCIC
foofy-arsed...I love it! |
02-27-2003, 01:05 AM | #13 | |
Member#: 27636
International
Vehicle:I haz 183 IggPoints |
Mike http://kanedasrealm.net |
Which Uppipe for 2.0 with EVO III | SacksLax | Newbies & FAQs | 9 | 11-10-2009 11:21 PM |
Best torque converter for 02 wrx? | bran521 | Newbies & FAQs | 1 | 11-29-2008 03:51 PM |
Which uppipe is best?!? | SIX STAR | Engine Management & Tuning | 3 | 04-15-2004 09:45 AM |
MRT Camber Plates....which direction for best Castor/Camber | Ryan24 | Brakes, Steering & Suspension | 4 | 06-18-2003 12:08 PM |
So for the best ICE performance than snow, which tire is best for ICE? | V6 | Brakes, Steering & Suspension | 14 | 12-14-2000 06:49 PM |
