Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 05-05-2012, 06:18 PM   #26
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
The other issue is the FSM specs those bolts at 114.3 ft/lbs. it's actually 114.3 Nm, or 80 ft/lbs (for the front)
My Brembos came on JDM Spec-C knuckles, and when I removed the bolts the holes and bolts were like new. :-D
I should've sent them to a Machine Shop to get TimeSerted, but I didn't remember until after I sent them to powder.
You bet your ass I used a healthy dose of Copper Anti-Seize on each bolt..
Old 05-18-2012, 06:48 PM   #27
newby
Member#: 182577
2006 sti
aspen white
Originally Posted by MaSTi View Post
+1. Just be ready if/when you need to touch the bolts!! I haven't run into a single owner who's attempted to loosen them and have them be ok!!
i am doing my brakes and rotors today, thought i was going to make it... then the last damn bolt got me. for anyone else that is planning on doing this get the 12x1.5 tap, your going to need it.
newby is offline   Reply With Quote
Old 05-19-2012, 02:55 PM   #28
tuzzio
Member#: 292532
05 STI
Honesty did pads and rotors the other day... Had not a single problem with the bolts at all.. Then my rear tone rings broke.
tuzzio is offline   Reply With Quote
Old 05-19-2012, 02:58 PM   #29
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
I recently had one of my front Brembo caliper bolts become loose, after it was drilled out last year. I tightened it up, and of course the threads stripped out. I ended up picking up a Time-Sert kit from Bel-Metric in Tewksbury, MA. They are right off rt. 3 and are an official Time-Sert dealer.
I also picked up a Time-Sert tap guide as well. Went home and did everything by hand with a tap wrench, and it came out 100% perfect. For Brembo's, you want the 16.2mm carbon steel inserts. Do NOT get the stainless steel ones. (these should only be used where necessary, such as medical or food industry)
M12x1.5 Time-Sert kit
Acejam2k is offline   Reply With Quote
Old 05-19-2012, 03:09 PM   #30
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
You drilled out the holes and countersinks by hand? You sir have WAYYYYY more patience than I.
Old 05-19-2012, 03:22 PM   #31
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Yes I did - but I used the tap guide as well. I honestly haven't drilled many things like this before, so I just squeezed the tap guide against the surface of the caliper as hard as I could, to ensure it was aligned straight. This allowed the tap wrench/bit to be pretty much straight.
The entire process took me about 30 minutes or so, and for the actual tapping part, I did the "few threads in, back it all out" method.
Changing Brake Pads on MY06 WRX T WRX rawr Service & Maintenance 12 11-21-2009 05:26 PM
help with changing brake pads on 04 sti vangstaboi86 Brakes, Steering & Suspension 2 04-04-2007 03:58 AM
Hawk HPS Brake pads on Sti STI-C-YA Brakes, Steering & Suspension 10 06-29-2005 08:25 PM
Change brake fluid on STi cboggess Brakes, Steering & Suspension 8 05-17-2004 01:43 PM
brake pads on RS changing them.. bratmantlz Brakes, Steering & Suspension 4 03-21-2001 09:06 AM
