09-14-2005, 11:00 PM | #1 |
Member#: 86291
Vehicle:'97 LegaSTi-2.5XTR '96 BrightonCoupeWRX-SR30 |
N/A legacy 2.2 fuel pump specs
you guys did a great job answering my questions about legacy turbo injector flow rates. Now all i need to know is how much the N/A fuel pump flows, preferably in lph but idk if thats how they are rated by subaru.
thanks so much Justin
09-15-2005, 03:43 PM | #2 |
Member#: 4800
TXIC
Vehicle:1990 Legacy & OB XT AWD 6MT EJ22T AWIC Swap |
Discharge pressure is 36.3 psi
Discharge flow is rated at "More than 80 lph" at the following voltage/pressure [12V at 36.3 psi] |
09-15-2005, 08:10 PM | #3 | |
Member#: 86291
09-16-2005, 12:58 PM | #4 |
Member#: 4800
TXIC
That's what the factory manual says.....
I can double check a different manual when I get home, but it's probably correct. |
09-16-2005, 01:03 PM | #5 |
Member#: 86291
do you know what color injectors the car had that you reading out of the manual from?
09-19-2005, 09:47 AM | #6 |
Member#: 4800
TXIC
Red.
However the 90 & 91 n/a legacies had the same rated pump, but their injectors were grayish for the AT and black I believe for the MT's. |
09-19-2005, 01:15 PM | #7 |
Member#: 86291
so it doesnt matter what injectors the car had, they all share the same fuel pump? probably with the exception of the turbo model with the pinks we talked about in my injector thread.
09-19-2005, 01:21 PM | #8 | |
Member#: 4800
TXIC
The part # may have changed, but the pump's specs stayed the same. |
09-19-2005, 10:36 PM | #9 |
Member#: 86291
ok thanks a bunch!
09-21-2005, 01:12 AM | #10 |
Member#: 86291
ok so i did a little home work and converted the 360cc/min flow of the turbo injectors to LPH.
360cc/min x 60 = 26,100cc/hr 26,100cc/hr to LPH move decimal 3 places left = 26.1LPH 26.1LPH x 4 injectors = 86.4LPH max flow do i have a problem running an 80LPH pump at the top end? |
09-22-2005, 01:29 PM | #11 |
Member#: 86291
just need to know if i can get away with it or not or if i messed up calculating stuff
09-23-2005, 11:35 AM | #12 |
Member#: 38120
South East
Vehicle:1991 Rio Red Legacy Turbo |
It would not be a good thing. You would probably run a bit lean at the top end, where you need the fuel most.
If it could keep up, you would be running it harder than it was designed for, thus shortening its life. I would recommend just replacing it with a high-flow unit. I put a Walbro GSS-341 255 LPH unit in mine. It was drop-in, and less than $100. |
09-23-2005, 01:12 PM | #13 |
Member#: 86291
yours was turbo from factory right? So do you have the OE pump for your car? it should be a 150lph...i would be interested in it if you do.
09-29-2005, 11:31 PM | #14 | |
Member#: 4800
TXIC
Let me know if you're interested. |
09-30-2005, 12:35 AM | #15 |
Member#: 86291
i might have a wrx pump becoming availible to me shortly, but if that does not happen i might be interested in yours.
Similar Threads | ||||
FS OH: Greddy E-manage Blue, custom UP, mod. BPM DP, intercooler, 2 wrx fuel pumps | AWDrivin | Engine/Power/Exhaust | 16 | 03-18-2007 09:02 PM |
WRX vs. STi fuel pump specs? | Bayley | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 12 | 04-04-2005 10:26 AM |
99' Impreza 2.5RS fuel pump | GC8STIV2 | Private 'For Sale' Classifieds | 0 | 10-30-2004 01:13 PM |
TRADE: stock WRX fuel pump for 2.5RS fuel pump. Riverside CA | RyansJDMgc8 | Private 'For Sale' Classifieds | 0 | 07-05-2004 06:47 PM |
Legacy and Impreza fuel pumps | scoobyimprza | Subaru Conversions | 2 | 07-31-2003 12:10 PM |
