10-16-2008, 11:22 AM | #1 |
Member#: 173553
International
Vehicle:1996 Civic VTi Dark blue |
STI and WRX intake manifold difference?
OK. I’m sure it has being covered before, but I could not find it! So any help would be nice.
Is the STI intake manifold better or is just “cosmetics”? If it is, will a 06 + STI manifold fit/work with my 06 WRX? Any advantages? Thanks
10-16-2008, 11:37 AM | #2 |
Member#: 112759
Vehicle:2015 Stock OEM AsFu* 3.6r OMG S.C'd |
should fit no prob both dbw set ups
10-16-2008, 11:40 AM | #3 |
Member#: 133597
SCIC
I believe they are the same minus the red.
10-16-2008, 12:53 PM | #4 |
Big Ron
Super Moderator Member#: 18062
Vehicle:on car parts so PM me b4 j00 buy |
It will net 0HP and 0TQ at the expensive of one pain in the ass install...doing that swap is a mother let me tell you.
10-16-2008, 01:04 PM | #5 |
Member#: 50992
SCIC
Vehicle:09 Tribeca Worst subaru blue |
when did the wrx goto the plastic manifold? 08? Cause I'm thinking there could be benefits of getting rid of it.
Plastic FTL |
10-16-2008, 01:22 PM | #6 | |
Member#: 173553
International
Yes, 2008. |
10-16-2008, 02:08 PM | #7 |
Member#: 173690
Vehicle:2005 Ferd F-TeenThousand |
10-16-2008, 02:23 PM | #8 |
Member#: 167739
Vehicle:15 Forester NA dat gas mileage |
10-16-2008, 06:02 PM | #9 |
Member#: 136358
Vehicle:2006 WRX Limited 6mt/5x114/vf43/S204 |
Yea from what I read the red is just some heat resistor thing, but it doesn't really net anything at all. If you want the red take yours off and just paint it.
10-16-2008, 11:51 PM | #10 |
Member#: 157894
Vehicle:2007 WRB WRX EJ257 |
I believe there a few small little nik nak differences but nothing that causes power gains/losses. And the 08 manifolds aren't plastic (which I'm sure you know or figured, anyway). I've heard that material is actually better for retaining heat than the metal. Just what I've been told, though...
10-17-2008, 01:07 AM | #11 |
Member#: 23553
Vehicle:2005 STI - Insanity! 2014 WRX - Daily |
Stick with the stock manifold. The plastic manifold is lighter and works just as well.
10-17-2008, 01:09 AM | #12 | |
Member#: 173553
International
Not plastic, but something that looks like plastic... I heard that is not just about heat. It is easy/cheap to make a very smooth surface with "plastic". Regards |
10-17-2008, 01:14 AM | #13 |
Member#: 51588
SCIC
Vehicle:2006 WRX TR 1997 Supra Turbo |
The red paint on the STI intake manifold is just that - paint. No thermal characteristics.
The 08s do have a plastic [or plastic-esque] IM. The STis don't, but the WRXs do. Benefits are decreased heat transmission [it's like a big phenolic spacer... kinda...ish], drawbacks are decreased holding pressure. |
04-02-2009, 01:11 AM | #14 |
Member#: 183629
Vehicle:2015 WRX World Rally Blue |
do you know how much pressure it can handle? (the 08 plastic)
04-02-2009, 06:26 AM | #15 | |||
Member#: 143391
Vehicle:2007 WRX TR R.I.P Paul! :( |
I saw some one on another forum take one and block it off and it held 35PSI over night with no problems! FYI thats more abuse in 12 hours then a 35R would put on it in a year! The new Composite Intake manifold has nothing wrong with it! The only real problem is the new I/C. It has composite end tanks and at higher boost levels they are known to start leaking at the joint to the core. As for the OPs question its red paint! thats it. Nothing more. |
04-02-2009, 07:12 PM | #16 |
Member#: 68647
Vehicle:07 STI 35R 05 BMW M3 ZCP |
just stick with the plastic manifold. I have yet to read where one failed under pressure and like already said it saves weight and is smoother on the inside.
09-21-2009, 09:25 AM | #17 |
Member#: 219676
International
Vehicle:09 Forester XT Steel Silver |
What about swapping the 08 wrx intake manifold with the 09 wrx?
09-21-2009, 10:06 AM | #18 |
Member#: 216135
Vehicle:2011 |
09-21-2009, 04:19 PM | #19 |
Member#: 183813
South East
Vehicle:2006 WRX TR OBP WRX STi SGM |
Compromise? But for the OP if you're planning on deleting your TGVs any time soon just paint it then. |
09-22-2009, 07:58 PM | #20 |
Member#: 124720
Vehicle:2009 WRX Hatch Black |
Can anyone else hear a plastic whistle sound around 4k rpms on their 09 WRX? Kinda sounds like a train whistle. I just figure its the intake manifold.
09-22-2009, 08:08 PM | #21 |
Member#: 199106
Vehicle:PMme 4 Speed Density Patches on OEM ECU |
Running a STi manifold on an 06 wrx here. I had GS port it but they had no wrx cores. Only difference was the FPR vac line tap, needed a longer hose, no big deal.
09-22-2009, 11:20 PM | #22 |
Member#: 159745
South East
Vehicle:2007 drunkman tuned mega meth |
09-23-2009, 12:21 AM | #23 |
Member#: 220098
Vehicle:2009 Leggy GT |
FWIW the LGT uses the same manifold. I bought a STi off ebay soley for the wrinkle red color and wanting WRX throttle body placement for intercooler routing.
Hill up at Agile performance told me this was actually a good mod to do, because the LGT/08+wrx manifold suffers from "alot of turbulence" in the air stream. I didnt ask any other questions about it, but he knows what he is doing enough for me to believe him. :shrug: I dont think (nor got the impression that he does) it is a life-altering, dyno-smashing modification, but is not without merit, and may be worth considering for the 08+ crowd doing TGV's anyway....its not expensive, and you are "in the neighborhood" so to speak. Just be aware whatever IC setup you were running previously, some or all of it wont work afterwords. |
09-23-2009, 09:13 AM | #24 |
Member#: 216135
Vehicle:2011 |
Hmmm, if anything the composite manifold is likely to reduce turbulent flow since it is so smooth inside relative to a cast aluminum manifold.
09-23-2009, 09:34 AM | #25 |
Member#: 220098
i think it has more to do with the way the throttle body was aligned/placed than the interior surface. Ive also never looked inside one of the composite manifolds. There could be parts where the molding left protruding edges at the runners or tb or wherever. The composite manifold is much cheaper to produce than the sti one is, and lets face it, subaru wasnt out looking to do the modding community favors by making the change, it was purely a cost decision. If it functioned better for less money, one has to ask the question why the STI's wasnt changed in 2008 like the wrx was. I would imagine subaru left the metallic one on the sti for a reason.
Similar Threads | ||||
2.5I and WRX intake manifolds | fateo66 | Engine/Power/Exhaust | 57 | 04-23-2010 11:31 AM |
KS: STI shortblock, wrx intake manifold, coilpacks and more | kcscoob | Engine/Power/Exhaust | 4 | 10-07-2009 04:48 PM |
RS SOHC and WRX Intake manifold differences | Odyknuck | Normally Aspirated with bolt-on Forced Induction Powertrain | 11 | 02-03-2009 05:25 AM |
V8 Heads and WRX Intake Manifold | ejh25 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 09-06-2006 04:22 PM |
2004 STi and WRX ride height difference? | jroberts | Brakes, Steering & Suspension | 2 | 08-29-2004 12:30 PM |
