Brakes & Suspension Forum sponsored by The Tire Rack |
09-22-2015, 01:06 PM | #1 |
Member#: 398397
Vehicle:2010 Subaru Wrx Sti |
Alignment issue
I've installed whiteline com c top hats, Swift spec-r springs, and Cusco rear lcas.
I went to subaru to get a custom alignment of -2.0f -1.5r and 0 toe. Apparently the best they can do is -.98fl -1.68fr -1.29rl -1.74rr. -0.01 front toe and -0.02 rear toe. My alignment was fine before changing these parts. The tech said that when ever she changed the rear alignment the front would change too? Input would be greatly appreciated.
09-22-2015, 01:10 PM | #2 |
Member#: 296742
NESIC
Vehicle:'16 STI, '11 WRX, '96 328i DSP |
She?
I think I found your problem! Just kidding, but seriously, she is clearly incompetent if she is claiming adjustments in the rear result in changes on the front. Go somewhere else and get it aligned, then go back with a printout of your new alignment and get your money back from the place that failed. |
09-22-2015, 01:31 PM | #3 |
Member#: 398397
Yeah that's what I thought. The rear alignment shouldn't affect the front.
09-22-2015, 01:34 PM | #4 |
Member#: 10228
Vehicle:2002 Subaru WRX |
The problem is that you went to SUBARU of all places to get an alignment. They will almost only allow factory values, no customer specified values.
You need to go to an alignment shop, that is not at a dealer. Try your local forum for references. Perhaps your location and profile information should be filled in to better assist you? |
09-22-2015, 01:38 PM | #5 | |
Member#: 296742
NESIC
If he asked for a custom alignment, and they agreed to it, then they aren't only going to align it to factory specs. |
09-22-2015, 01:41 PM | #6 |
Member#: 10228
09-22-2015, 02:09 PM | #7 |
Member#: 296742
NESIC
09-22-2015, 02:24 PM | #8 |
Member#: 398397
Yeah I talked to the tech and she said that when ever she aligns the rear apparently it messes up the front alignment which i don't understand at all. I'm headed home now to check what she did and I'll make sure the top hat and perchs are all on right but I'm pretty sure they are.
09-22-2015, 02:44 PM | #9 |
Member#: 247304
South East
Vehicle:2011 STI WR Blue |
The statement is correct. When you change the rear settings it has an effect on the front. Preferred approach is set the rear first then the front, IMO. There is NO REASON that a good shop can't match camber from side to side with adjustable LCA frt camber plates or bolts...sloppy work.
09-22-2015, 03:03 PM | #10 | |
Member#: 296742
NESIC
09-22-2015, 06:37 PM | #11 | |
Member#: 375462
NWIC
Vehicle:2006 Impreza WRX STI WR Blue |
That being said, you generally don't notice this when you align a car that is more-or-less where it needs to be (i.e. a car that is doing a maintenance alignment and didn't jump a curb). When a customer comes in with a bunch of new parts and the alignment is way off, you often need to go rear -> front -> rear -> front to get it dialed in, as the first front alignment change will be significant and *will* change the rear. Any more than one extra rear/front cycle and you're likely dealing with a newbie tech. It sounds like this tech hasn't done many alignments aside from warranty/lease cars. Lastly, when I say the rear affects the front, and vice versa, I am talking minimal amounts here. You should not see more than 0.1-0.2 deg camber change. You did ask for custom settings, however, and it's a lot more difficult to hit a specific value than it is a range specific in the FSM. Jouncing the suspension alone will cause a 0.1-0.2 deg camber shift... and you (or the tech) *should* jounce both ends before you consider the job complete. Unless you have the exact fuel load you want and the tech lets you sit in the driver's seat while you're up on the alignment rack, it's gonna change a decent amount when you sit your butt in the seat. You should be willing to accept a fair window, and for the love of God make sure they're matching the L/R camber - that's the other hint I got that it's a fairly green tech. Last edited by mrsaturn7085; 09-22-2015 at 06:42 PM. |
09-22-2015, 07:08 PM | #12 |
Member#: 296742
NESIC
.1 or .2 is basically bushing deflection at rest. Every time you put the car back down the number will be randomly different by that margin.
The only thing that makes a difference front to rear is thrust angle. You cannot change the front camber buy adjusting anything in the rear. It isn't physically possible. |
09-23-2015, 12:22 AM | #13 |
Member#: 375462
NWIC
Yeah? How about ride height?
I'm telling you it happens on an alignment rack all the time. |
09-23-2015, 12:40 AM | #14 |
Member#: 296742
NESIC
09-23-2015, 08:44 AM | #15 |
Member#: 398397
Would a 5mm spacer affect the alignment?
09-23-2015, 07:07 PM | #16 |
Member#: 375462
NWIC
09-23-2015, 07:09 PM | #17 |
Member#: 296742
NESIC
09-23-2015, 07:16 PM | #18 |
Member#: 296742
NESIC
Okay, I'll bite.
Adjusting the ride height on the rear may affect the front caster reading, as the car will physically change the angle it is sitting at, along the same plane that caster is measured, relative to the alignment rack. But again, that is a false reading because caster, relative to the chassis, has not changed. And still, as far as camber goes, there is no way to affect front camber by adjusting anything in the rear. It just isn't physically possible. |
09-23-2015, 10:52 PM | #19 | ||
Member#: 375462
NWIC
This is the part you're neglecting - weight-on-wheels. Any time you change the angle of the car when viewed from the side, you change the compression of the front and rear springs due to the static transfer of the effective mass fore or aft (albeit minor), thus changing alignment on both ends. As a side note, this is also why you need to have the tires inflated to the proper pressure before an alignment. An large initial alignment change in the rear (such as adjustment after swapping out all your suspension) will noticeably affect the front. I've corner-weighted and aligned enough cars to know this. Far more noticeable on heavier street or GT-style cars than open-wheel due to the overall mass of the vehicle. Did this tech understand why this was happening when she aligned the car? Probably not - she was just telling the customer what was happening. But this is WHY she was seeing this. Had she given the rear and front another go-around, it wouldn't have been seen. Quote:
That statement implies things like camber curves don't matter. The reading is not false, the static conditions (which we align for) have changed. If you'd like the last word here, go for it. Just like the bushing deflection comment earlier, you can't argue with physics, only attempt to trivialize them. |
09-23-2015, 11:19 PM | #20 |
Member#: 296742
NESIC
You are so damn wrong, and so friggin far off topic, I'm at a loss.
If I adjust toe, caster, or camber through any method on the rear, NOTHING CHANGES ON THE FRONT. Any changes you see are simply bushing deflection every time you drop the car back on the ground. I could push on the wheel with my hand and make the damn machine read a drastically different number. The tech didnt change the ride height on his non ride height adjustable car. And nobody adjusts ride height while on an alignment rack. |
09-23-2015, 11:37 PM | #21 | |||
Member#: 375462
NWIC
Secondly, why are you taking readings with the car in the air? Readings should be taken on a level platform. If you raise one end and lower it, you should jounce the suspension. Quote:
Here is a front-end model of a GD chassis. Adjusting the camber and taking compressed tire profile into account, the number "262" which is ride height to front suspension pickup, will change. You have effectively changed front-end ride height without changing the spring length. Depending on whether weight transfers fore or aft, you will either compress or decompress the spring, thus making the change in the rear more significant, or more-or-less cancelling it out. |
09-23-2015, 11:48 PM | #22 |
Member#: 296742
NESIC
There is no ride height adjustment.
09-27-2015, 02:17 PM | #23 |
Member#: 431006
NESIC
Vehicle:2006 Legacy2.5i Lim. Blue |
Unless you were to life you're car
09-27-2015, 02:18 PM | #24 |
Member#: 431006
NESIC
Life** which idk why you would with a Subaru lol
09-30-2015, 12:57 PM | #25 | |
Member#: 430803
Vehicle:2011 WRX Dark Grey Metallic |
