09-28-2011, 05:28 PM | #1 |
Member#: 236549
Vehicle:2007 WRX Wagon STish WRB |
Horrible stumble when cold/moderate when warm
I've searched other similar threads, but all of those have other symptoms and usually display a CEL, which mine does not.
Issue: Runs like CRAP when cold, gets better once it warms up a little. Still has a slight hesitation under light and moderate load; seems to run fine at WOT. Car: Stock '07 WRX w/ K&N PANEL filter (not intake) and STi OEM axle-back. Currently running AP Stage 1 since the car's stock. I've replaced the plugs, cleaned the MAF, and cleaned/re-oiled the K&N. I also checked the MAF voltage with the AP, and it rises and falls with throttle/rpm as it should (or so it appears). Is this a tuning issue? I was thinking the AP map was making it run richer when cold, thus the bad stumble. But I re-loaded the stock map, unmarried it, and it still does it, but not as bad. I'm just thinking, as with any "issue", if you add power the problem is exacerbated. Ideas? Thoughts? Thanks.
09-29-2011, 10:27 AM | #2 |
Member#: 4803
Does it idle poorly as well when cold or is the issue only present when you are driving?
Bill |
09-29-2011, 11:13 AM | #3 |
Member#: 95189
BAIC
Vehicle:2002 WRX Wagon PSM |
Yea, this doesn't sound like a tune issue, sounds like a mechanical issue. Especially considering you took it back to stock and your having the same issues.
09-30-2011, 09:46 AM | #4 | ||
Member#: 236549
Thanks for the reply guys. |
09-30-2011, 10:57 AM | #5 |
Member#: 4803
Yeah, if it is doing it with the stock map, then you have some kind of mechanical issue. The best thing to do at this point is to get a data log when the hesitation occurs and when you have the rough idle. Try not to make it a huge log that is difficult to go through. Instead, just start the logging right before the hestitaiton (or bad idle) is occuring and end it right after.
Here's a general video on how to get started with data logging. Use the default logging set, but for your particular issue, also add "A/F Correction 1". Bill |
10-17-2011, 11:12 AM | #6 |
Member#: 236549
Bill,
Got some short logs in per your direction. I'm assuming at this point I need to email the .xls logs to a tuner for analysis? I'll be honest, I only have a slight idea of what I'm looking at (and conversely, what it's SUPPOSED to look like). |
10-18-2011, 09:32 AM | #7 | |
Member#: 4803
Bill |
11-22-2011, 06:09 PM | #8 |
Member#: 236549
Didn't realize .csv was a type of .xls file.
11-22-2011, 06:26 PM | #9 |
Member#: 236549
Log 2
https://docs.google.com/open?id=0B8z...RkZjJkZTI4NDEy Log 1 https://docs.google.com/open?id=0B8z...I3MjQwMTNkOTI5 I'm not sure if these are telling much, I'll try to run a couple more when it's really misbehaving. Thanks. |
11-22-2011, 06:56 PM | #10 |
Member#: 233580
Vehicle:2006 sti obp |
I would think this has to do with the avcs since they are oil drivven and cold oil would flow differently than it being hot.
I think they have oil screen filters that may need cleaning. But I am far from a subaru expert yet lol |
11-23-2011, 09:27 AM | #11 | |
Member#: 4803
Bill |
11-23-2011, 04:08 PM | #12 |
Member#: 236549
I noticed that too Bill. Having never used google docs, I wasn't sure if this was normal. So I just clicked "download" and "open" to view them. Let me know if I need to fark with something in google docs.
11-23-2011, 05:50 PM | #13 |
Member#: 287807
SCIC
Vehicle:2011 WRX Blue |
clean your maf
11-23-2011, 06:22 PM | #14 | |
Member#: 4803
Bill |
11-29-2011, 08:07 PM | #15 |
Member#: 236549
Hey Bill, thanks for the help.
I've created a new post over at the Cobb Forums. http://www.cobbforums.com/forums/sho...460#post659460 |
11-29-2011, 08:18 PM | #16 |
Member#: 236549
11-30-2011, 10:14 AM | #17 | |
Member#: 4803
Bill |
Similar Threads | ||||
Rough idle, misfire CEL, car stumbles when cold | roksax | Service & Maintenance | 6 | 07-22-2006 03:53 PM |
stumble on cold start with CIL rough idle | Deity | Normally Aspirated Powertrain | 7 | 11-05-2004 02:44 PM |
My car idles lumpy when cold but is fine when warm? | waitandbleed92 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 05-03-2004 04:37 PM |
Misfire/Stumble at cold startup | SilverBoosted | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 01-26-2003 04:01 AM |
Squeeky Rear Suspension when Cold, goes away when warm. | nhalterman | Brakes, Steering & Suspension | 2 | 12-12-2001 03:31 PM |
