10-06-2007, 02:08 AM | #1 |
Member#: 138717
gauge install caused rear defroster to stay on
Hey, I have a 06 WRX and just got boost, EGT and oil pressure gauges installed today. The gauges work fine, but now the rear window defroster won't turn off. The light for the button remains on even when you push the button; and when you push the button the gauges turn on and off. Is there a problem with having the rear defroster on the whole time the car is running? and is there a way to turn off the defroster?
Thanks
10-06-2007, 07:39 AM | #2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Something is miswired. If you had a shop do the install go back there ASAP and make them fix their mistake.
10-06-2007, 08:16 AM | #3 |
Member#: 123843
NESIC
Vehicle:2016 STI LTD CWP Let LED's light your way! |
It's not about turning off the defroster -- it's about having your gauges properly installed.
Maybe the shop that installed your gauges did not realize that Subaru uses a switched ground system? Don't try to "fix" the defroster in favor of the gauges -- nothing is wrong with the defroster. Fix the real problem first, the gauges! Good luck! |
10-06-2007, 09:11 AM | #4 |
Member#: 53443
Vehicle:2001 LL Bean Outback Winestone |
I agree with the other posters and there is a problem with leaving the defroster on continusly. The shop has tied into the wrong wire to supply power to the gauges. Maybe they got confused with a wire that is the same color as a power wire or worse, they just probed around until they found something that looked like it was a power wire.
BIG-E is correct in saying they tapped into a switched ground wire. The power going to the gauges is in series with the defroster heating element. The gauges are now acting as a ground connection to the defroster, which keeps the heater on even though the defroster switch is off. When you turn the defroster switch on then the gauge power connection gets tied to ground through the defroster switch and turns off the gauges, but turns the defroster on as it should be. If this was my car I would go back the to the shop and ask to speak to the manager. Then explain to him what you have found out. I would try to find out what they using for a wiring reference to install the gauges. They need to fix this correctly and at no extra cost to you. One quick and smart way to supply power to a new accessory is to use a fuse tap. Suppling power that way requires no slicing into wires where there may be trouble later on if not done correctly. Last edited by Cougar4; 10-06-2007 at 02:39 PM. |
10-06-2007, 02:25 PM | #5 |
Member#: 138717
ok, i'll bring my car back to the shop, but it's closed during the weekend. Will having the rear defroster on throughout the weekend be bad? (my wrx is the only car i can drive)
10-06-2007, 02:29 PM | #6 |
Trust no one
Is the defroster really on, or just the light on the button? You can feel the window to see if it's getting warm.
The ECU times the defroster out after about 15 minutes so it won't run constantly, although I'm not sure whether a short in the button wiring would keep resetting the timer. To be sure, you can always find the fuse or relay for the rear defrost and pull it. |
Fix: Rear Diff Light Stays On - STI Cluster Swap Into WRX | pioneer_sti | Electrical & Lighting | 17 | 10-08-2016 12:58 PM |
Does the TPMS light cause VDC to stay on? | 09rexwagon | Tire & Wheel | 0 | 04-08-2010 03:16 PM |
What Causes Clutch pedal to stay down? | Falkonite | Newbies & FAQs | 9 | 06-29-2009 11:05 AM |
('93-'01) I know the rear defrost is weak on subaru | dawhim | Impreza Forum | 9 | 12-21-2004 11:36 PM |
What Would Cause Lights to Stay On? | Machine Age Victim | Electrical & Lighting | 2 | 01-11-2004 01:41 AM |
