Tire & Wheel Forum sponsored by The Tire Rack |
10-19-2011, 12:17 PM | #1 |
Member#: 133267
Vehicle:2004 psm WRX |
What's ur Fave All-Season Tire & Why???
Folks that live in places with wet winter weather, what is you favorite high or ultra high performance all-season tire to run on your Suby?
Just moved to the Pacific Northwest last year, I now clearly see just how important they are for safety Just to simplify the thread, please omit 'snow tires' and focus on AS....
10-19-2011, 12:20 PM | #2 |
Member#: 141952
Vehicle:2023 M340i |
conti dws. best all season in snow and rain that i have driven on. not a sharp handling tire, but all seasons are a compromise and you might as well focus on the reason you are buying them in the first place.
10-19-2011, 12:25 PM | #3 |
Member#: 6598
Vehicle:2017 Golf R Limestone Grey |
I've been a fan of the Bridgestone RE960AS for a long time. Pricey, but a very good, well rounded tire.
10-19-2011, 07:48 PM | #4 |
Member#: 45076
Vehicle:2004 Stg 2 wagon AT 16 BRZ. Both silver |
My bfg supersport A/S in 205 55 R16 on my stockers work great in the winters in the tristate area.
10-19-2011, 07:59 PM | #5 |
Member#: 70710
Vehicle:2002 04STi Swaped RS w/PPGS & 02 Wagon w/PPGs |
General Altimax Arctic.....yes they are snow tires but....I run mine All Season and thrash them daily. They wear like iron and grip like a mo-fo 22k on my set with more than 3/4 tread left. I actually bought another set of 4 sitting because how impress I am with them.
10-19-2011, 08:20 PM | #6 | |
Member#: 141952
10-19-2011, 08:30 PM | #7 |
Member#: 70710
perhaps but the dunlop 3d are like +20% more $$$$ and more so the the further the size get pushed up...... :/
10-19-2011, 08:33 PM | #8 |
Member#: 141952
10-19-2011, 09:04 PM | #9 |
Member#: 298282
E. Canada
Vehicle:1993 Impreza WRX Grey |
yo
Falcon Espia FTW!!! by far my favorite on my 93 subaru for winter. lots of control and the rubber is super soft so it grips all the snow. ive gone threw 3 feet of snow litterally with them.
10-20-2011, 08:56 AM | #10 |
Member#: 123843
Vehicle:2016 STI LTD CWP Let LED's light your way! |
I'm excluding "popular" in terms of what the current talk is about and "cheap" in terms of price.
Goodyear Eagle F1 All Season Why? *The tire is stable at high-speeds, both wet or dry. *When changing lanes in the rain, there is no 'floating'. This is also considers being reasonable in terms of driving when raining. *When encountering pooling water, the tires will, by and large, cut through it with little loss of track or stability. This also considers being reasonable in terms of driving when raining. Meaning, don't expect to drive 80mph, for example, hit a standing pool of water, and have the car continue straight as if the water were not there. *If the car is pushed in the rain (I don't recommend this) the car will stick. *Is designed for use in light snow. Note however that if your suspension / chassis is moderately to heavily modified, the overall set-up may be too stiff and so you start to take away the tire's ability to continue to 'give' with respect to driving in light snow. If this is the case, then an actual snowtire is recommended. Otherwise, you can use the tire in light snow, but must consider all factors at hand. Comparison: Bridgestone Potenza RE-92 *Original equipment *All-season tire *New Were fine on an unmodified car for both wet and light snow conditions. If the car were pushed a bit in the rain, they would break loose every now-and-again. Once the suspension / chassis was modified, they were still fine for wet condition use, but they would break loose every now-and-again. They would also float if there was too much water on the road: pooling or between lanes. Once the suspension / chassis was modified, they were no longer appropriate for light snow use. The need for a better high-performance non-summer tire was warranted. Comparison: Dunlop Direzza Z1 Star Specs: *UHP summer tire *New *Used in conjunction with a modified chassis / suspension *Used in the summer *Used the day they were installed during very wet weather conditions While driving straight, staying in one lane only, the car would float very slightly. When changing lanes, the car would float. These are a great dry-weather tire. ******* All factors must be considered: *No two drivers are alike *No two cars are alike *Your drivng habits *Your driving needs You cannot rely on what only one person says. Using my Star Spec example above, these tires, when new, on my car, were not good in the rain. Other have had different results. Some people don't like Goodyear as an overall brand. Some say they don't like the F1 A/S. You must consider the source and the conditions: modified suspension? Track car? Daily driver? etc? Last edited by Big-E; 10-22-2011 at 05:49 PM. Reason: Grammar / Sentence Structure |
10-20-2011, 07:50 PM | #11 |
Member#: 45076
I also have a set of rims with the goodyear f1 a/s and they are great as big e says but they are noisy as hell compared to any tire i have ever owned.
10-21-2011, 07:44 AM | #12 |
Member#: 136296
TXIC
Vehicle:2005 STi OBP |
Have money? Potenza RE-970 A/S Pole Position. Solid, stiff sidewall, responsive handling, very good wet traction, and undeinable and sticky dry traction. Lower treadwear and kinda expensive.
Don't have money? Kumho Ecsta 4x looks like a promising contender for the RE-970 with slightly lower traction capabilities and near-useless snow traction but a significatly better treadwear at a significanly lower price, but still has very crisp and sharp handling. Brand new tire so i'm still following reviews to see how well it fares. Need light snow traction and excellent treadwear at the expense of responsiveness? Continental ExtremeContact DWS. Softer sidewall makes it significanly slower to respond to steering input and more mushy, but the added benefit is a softer and softer ride. Very impressive snow and cold traction, good dry traction, and extremely impressive wet traction and hydroplaning resistance. The treadwear has been extremely impressive as well, lasting significanly longer than the Potenza. Priced between the Potenza and the Kumho. I have had the RE-970's and my gf's 08 STi has the ExtremeContact DWS, i'm looking at getting the Kumho's as my next set as snow and wet traction is less of a priority for me. |
10-21-2011, 11:32 AM | #13 | |
Member#: 116052
Vehicle:2011 STI ( Sold ) WRB |
10-21-2011, 02:28 PM | #14 |
Member#: 298558
F1's are decent
10-21-2011, 10:15 PM | #15 |
Member#: 44283
Nokian WR2 all weather tires are great for the Pacific NW. They are snow rated but are good in all conditions - I use them year round.
10-22-2011, 11:06 AM | #16 |
Member#: 256881
South East
Vehicle:2010 IMPREZA SSM |
For the money and performance I have Goodyear Eagle GT's and I'm pretty happy with them but as I said for the money. I'm sure there are better tires just out of my price range. I heard those Conti's DWS were pretty good.
10-22-2011, 03:53 PM | #17 |
Member#: 136296
TXIC
Just read that you needed cold weather snow/slush traction. I would highly recommend the Conti ExtremeContact DWS in as narrow as you can get it to mount on your wheel.
10-22-2011, 05:53 PM | #18 | |
Member#: 123843
I think it's hit-or-miss with respect to the noise. Some say when the tires start to wear that they tend to become more noisy. It also depends on the road surface as well. Unfortunately one cannot "test drive" a set of tires. Or at least that's what I know. |
10-23-2011, 01:51 AM | #19 |
Member#: 133267
Thinking of going with the Continentals, great reviews on Tirerack.com- decided to go with the 18x8 Rota Tarmac 3s, the 235/40/18s would fit just fine. Could use the softer sidewalls for the bad Oregon roads
Snow isnt really an issue other than the short trips to Hood for board time, mostly rainy winter NW conditions other than that... |
10-23-2011, 10:05 AM | #20 |
Member#: 266105
Vehicle:2011 WRX Blue |
The continental DWS is a great all-season tire. My wife had these on her Audi A4 (225 width) and I gave them a good testing last winter and they handled the snow great. They also handled rain and anything else great.
10-23-2011, 02:15 PM | #21 |
Member#: 6295
if you plan on driving bald peak RD, I would get a dedicated set of winters
10-25-2011, 08:11 PM | #22 |
Member#: 295514
Vehicle:2018 STi CBS! |
Personally, I enjoy the Continental DWS. So far they have shown to be reliable on nice days and rainy days. I'm pretty excited for driving it in the snow, rumor has it that it's great in the snow.
10-25-2011, 11:47 PM | #23 |
Member#: 275191
Vehicle:2002 Impreza WRX Silver |
There's a new kid in town... General Gmax AS-03. They got very good reviews back in the spring. Conti/General either underestimated the demand or were slow to get the tires out, but they're available now. So far I've been able to thrash them in the dry and during a couple of days of gully washers. Their dry traction is amazing (subjective) for an all weather. I really got a chance to put them to the test making a "brisk" run from Boise to Lowman and back. The wet weather traction really blew my mind. I mean their wet grip is a thing of beauty. The tread blocks have a generous amount of space that makes me think that they will provide excellent (light) snow performance for an all weather. The side wall seems stiffer than my buddy's Conti DWS's too.
There aren't a lot of reviews out yet, but given time I think that they will be a very viable option compared to the (ever popular) Conti's. |
10-26-2011, 12:02 AM | #24 |
Member#: 214796
Vehicle:2004 OBS |
Continental DWS for sure. I've had them for a few months now and driven through very torrential rain, with some hard stops during it and the tires felt great the whole time. I'm waiting to see what they're going to be like in the snow but so far from all the reviews I've found they should be pretty good.
I think TireRack did a review of comparable All Season tires in snowy conditions and the DWS came out on top by a good bit. Considering that they are better then the RE960AS and cheaper, they are a great tire for the money. (FYI, I used to have RE960AS and yes they were great but for the price and the reviews I've seen so far, the DWS is better all around) |
10-27-2011, 05:50 PM | #25 |
Member#: 187209
Vehicle:2011 WRX Sedan SWP |
Pirelli p zero nero a/s, i drive them yr round in ut & the handle great in all conitions
Similar Threads | ||||
ford, dodge, GM. who if ur FAVE?(truck) | snowman4us | Off-Topic | 41 | 10-01-2012 12:28 PM |
WTB front endlinks, 225/45r17 all-season tires & 3" downpipe | jaytech | Tri-State Area Private Classifieds | 9 | 03-24-2010 12:09 PM |
FS: nearly new 195/60/15 all-season tires & 15" steelies | ten80 | NWIC Private Classifieds | 1 | 03-03-2009 07:58 AM |
Socal: 18x7.5 White TE-37 w/ Pirelli UHP All-Season Tires & Ray Extended Lug Nuts | sbrcr267 | Wheels/Tires | 10 | 03-17-2007 10:22 PM |
WTB: '05 WRX Wheel & all-season tires | Joris | Vancouver Impreza Club Forum -- VIC | 0 | 11-05-2005 08:25 PM |
