03-28-2006, 04:05 PM | #1 |
Member#: 97031
Best way to keep engine bay looking clean
Hey i was wondering what everyone uses/ does to keep there engine bay clean and looking new?
03-28-2006, 04:32 PM | #2 |
Member#: 34832
Vehicle:1989 M3 White |
dont drive the car.
03-28-2006, 04:34 PM | #3 |
Member#: 97031
good idea....but seriously?
03-28-2006, 04:38 PM | #4 |
Member#: 34832
i power wash mine regulary spray detergent on, use a scrub dish sponge to get the real dirty areas
if you have a cone or pod or otherwise Open air filter make sure to cover it in a bag, i also cover the alternator with a bag just to be safe. |
03-28-2006, 04:48 PM | #5 |
Member#: 16157
South East
Vehicle:'03 Mazda P5 <>< '02 WRX & '08 MS3 SOLD!!! |
Been discussed numerous times. Run a search for "Engine Cleaning" or something to that nature and you'll pull up some great info
03-28-2006, 04:52 PM | #6 |
Member#: 61105
Vehicle:2009 Legacy Spec.B OBP |
search for it as it has been covered many times. Most people use a degreaser like simple green. Does a good job and smells good too.
03-28-2006, 04:52 PM | #7 | |
Member#: 99397
RMIC
Vehicle:15 WRX, 83 DR30, 93 R32 GTS-T, 93 R32 GTR |
03-28-2006, 05:29 PM | #8 |
Member#: 110417
VIC
Vehicle:2005 Mazda RX8 Winning Blue |
I use a degreaser like "simple green" and it works wonders! Make sure to cover your alternator and air filter!
03-28-2006, 05:56 PM | #9 |
Member#: 84680
Yup. I washed down my engine bay after covering the battery, alternator and fuse box with foil and spraying certain greasy portions with Simple Green.
BTW, there are a TON of threads about this. |
03-28-2006, 06:32 PM | #10 | |
Member#: 40702
South East
Vehicle:2002 Wagon stg 3.5 WRB |
03-28-2006, 06:37 PM | #11 |
Member#: 33522
TXIC
Vehicle:07 - the next big thing ;) |
simple green + pressure washer
03-28-2006, 06:41 PM | #12 | |
Member#: 29871
Vehicle:2OO2 ~WRX~ Macadamia Metallic |
03-28-2006, 07:12 PM | #13 |
Member#: 60972
BAIC
The easiest way that I've found is to use a pressure washer and presoak the engine bay. Then spray it down with Eagle One Heavy Duty degreaser and then hit again with the pressure washer. Once your done with the cleaning spray some Armour All on it and close the hood. Open the hood the next day and bam your engine is clean and shiny. Ask anyone who knows me and they can tell you that my engine is the cleanest around.
03-28-2006, 08:14 PM | #14 |
Member#: 37617
Vehicle:2007 |
The search button keeps mine clean.
But really... Spray with a hose, simple green, rinse off. Dry, apply 303 aerospace protectant to all rubber/plastic. |
03-28-2006, 09:01 PM | #15 | |
Member#: 80169
E. Canada
Vehicle:2004 PSM WRX Cobb Stage 2 biotch! |
03-29-2006, 10:28 AM | #16 | |
Member#: 5223
Vehicle:2002 Impreza WRX Silver Metallic |
Many tire shine products also contain PDMS and would be good under the hood (for example, I've used a couple of different tire foams with success). However, some of the "extreme shine" type products are still solvent-based dimethyl silicone. Rule of thumb: If the dressing goes on clear and oily, best to avoid it under the hood. If it has a white, milky look to it (which ultimately dries clear), it's PDMS, and should be safe. Tort Last edited by TortoiseAWD; 09-20-2006 at 11:20 AM. |
03-29-2006, 01:48 PM | #17 |
Member#: 25306
International
Vehicle:2016 STi White |
In my experience washing out the bay is the best way to get all the heavy crap off, but i now use this stuff that i get at checkers/kragen/schucks* called "trim shine"
its mainly used for all the plastic molded parts like on the chvy avalance and honda element, but i use it for making under my hood look brand spankin new... the good thing about it is that its not oily/greasy like armor all and its ok if you overspray on the paint... i wouldnt leave it on their if you get some but its not going to eat the clear coat... honestly the best stuff i have found to make the eng bay bling... comes in a can, similar to a can of spray paint, its a black can white lettering and a yellow top, and i even think its called "trim shine"... you'll know it when you see it... hope this helped a bit... good luck |
03-29-2006, 02:26 PM | #18 |
Member#: 1134
Vehicle:2015 Outback H-6 White |
Simple Green works well for me, but a few folks mentioned a Mr. Clean automotive product I think, a while back, that supposedly is as good or better....
03-29-2006, 05:01 PM | #19 | |
Member#: 89746
NESIC
Vehicle:2002 WRX Stage 4 PSM w/Gold RPF1's on 255s |
i use stuff called Grease Lightning,
03-29-2006, 05:33 PM | #20 | |
Member#: 80169
E. Canada
03-30-2006, 10:06 AM | #21 | |
Member#: 5223
ArmorAll does still sell "Extreme Tire Shine", which appears to be the type of dressing you'd want to avoid under the hood and for interiors (clear, oily, solvent-based dimethyl silicone), but their interior "protectants" - regular, low gloss, and high gloss - are all PDMS dressings with varying levels of the active resin. Tort |
03-30-2006, 10:12 AM | #22 | |
Member#: 5223
I'll have to give that one a try . . . I've had good luck with other Stoner products, but it never crossed my mind to try Trim Shine under the hood. Tort |
03-30-2006, 12:32 PM | #23 | |
Member#: 31761
Vehicle:2005 sold! STi Aspen White w/ Gold rims |
Honestly... I keep my engine bay clean by driving it in clear/sunny weather. Rain will seriously dirty up that engine bay. So... stay out of the rain. |
03-31-2006, 10:22 AM | #24 |
Member#: 97043
TXIC
Vehicle:08 STI 02 Z28 - project |
and mud gets rally cars dirty and ugly. they should just stick to driving slowly on pavement since drifting throws up nasty rubber too.
i use WD-40 and a rag. it removes everything bad, doesn't do anything bad, and you just wipe it up so it doesn't smoke and burn. easy, cheap, effective. |
08-03-2006, 11:59 AM | #25 | |
Member#: 113271
Vehicle:2006 STi Obsidian Black Pearl |
best way to keep rims clean?? | STIpimp2006 | Car Care & Detailing | 25 | 11-21-2009 12:42 AM |
Best Way to keep car from rolling | newrexracer | Brakes, Steering & Suspension | 12 | 03-28-2006 11:32 PM |
Best way to keep brake dust off the wheels | tacomaprime | Brakes, Steering & Suspension | 3 | 03-31-2005 03:06 PM |
What's the best way to keep coffee fresh? | dropmech | Off-Topic | 21 | 07-27-2004 03:08 AM |
