09-07-2006, 07:40 PM | #1 |
Member#: 65126
NESIC
Vehicle:00 Leggy Wagon 99 Silverado, 06 HD |
turbo upgrade on my swap question.
I have a complete version 5 swap. It has a vf28 turbo on it, which I believe is orriginal. NorthUrsalia has a version 6 sti engine and his has a vf30. I am wondering if both of these turbos are orriginal.
Did a ver5 come with a vf28, & a ver6 came with a vf30? Also I am looking to get more power out of my ver5 what turbo should I go with and who should I have tune it. (has anyone done any upgrades/tuning to an older sti?) F1 dyno said they couldnt tune it! Franz isnt @ KTR anymore! TDC tuning never returned my email! Lachute tuning never returned my email!
09-07-2006, 11:47 PM | #2 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
using the stock ecu lachutte is the ONLY place that can do it
call them .. they will answer the phone in french but they also speak english there are however 2 noteable plug n play ecu stand alone options link and autronic |
09-08-2006, 10:49 AM | #3 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
Jeremy,
The vf28 is original to your v5. The vf30 is not original to his v6. The V6 got the VF-29, which is identical to the vf-28,except it got a titanium compressor wheel. The VF-30 is not much more different than those 2 turbos, except it uses more modern bearings. Personally, if you want a newer turbo and a little quicker spool up, then you could install a vf-30 and run it on your stock ECU. There's no reason for a custom tune unless you are trying to push it for max power. Though, if more power is all you care about, the VF-28 and the VF-30 have nearly identical peak power. A 16g or 18g would be a more appropriate choice if you are looking to get past 325-350chp, which is roughly the limit of your current turbo... |
09-10-2006, 07:05 PM | #4 |
Member#: 43916
RMIC
Vehicle:2001 Impreza 4.7 Blue Ridge Pearl |
pe1820
i didnt say anything |
Doing a turbo upgrade on my 05 STi. Have question about tune. | The Reaper 975 | Engine Management & Tuning | 2 | 03-09-2006 03:30 PM |
Looking to upgrade the turbo setup on my 06 WRX.. | riggs | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 87 | 12-04-2005 11:06 PM |
Thinking about doing a WRX front brake swap on my RS...Questions | WRC1 | Brakes, Steering & Suspension | 0 | 05-04-2005 03:13 PM |
Single turbo upgrade on JDM twin turbo GT | shadyrich | Legacy Forum | 14 | 04-02-2003 09:54 PM |
turbo upgrades on WRX | Gunn | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 09-14-2001 06:14 PM |
