07-10-2003, 11:37 PM | #1 |
Member#: 29214
South East
Vehicle:05 WRX Wag (Work) 91 Legacy Wag (Play) |
need Ej25 specs
I'm trying to get together some data for Desktop Dyno, to create
some camshaft files, so on and so forth. put simply, this data will allow you to plot which course is the best to take for your engine, it gives you a dynograph of the engine. the numbers are not right-on if you were to take it to an actual dyno and dyno the engine, but the numbers are typically between 10 and 20hp/tq of what the software reports. I need some information that I can't find myself, looking here for help. Right now the first car is a 2000 Impreza 2.5RS Coupe The specifications I need: Head type, number of exhaust/intake valves per cylinder. Intake and Exhaust Valve Size head combustion space (82.01cc ?) Induction flow @ 1.50inHg (expressed in CFM) Manifold type, Individual runner I believe? The camshaft: type, hydraulic roller? Intake lift @ 0.050 Exhaust lift @ 0.050 Lobe Center Intake Duration Exhaust Duration Camshaft timing Intake Valve Open (Before Top Dead Center, BTDC) Intake Valve Close (After Bottom Dead Center) Exhaust Valve Open (BBDC) Exhaust Valve Close (ATDC) valve overlap for confirmation. this is one value that comes out after calculation of all previous values, it's not required because you can't input it, but if you know it, give it here so I know the values come out right.
JDM ej25 spec | qtr_wrx | Normally Aspirated Powertrain | 9 | 07-05-2008 07:32 AM |
Need Legacy Spec B engine specs | franknbeans | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 7 | 06-20-2008 09:50 AM |
NEED engine specs for EJ25 | Roadrace1999 | Subaru Conversions | 3 | 05-17-2006 10:55 AM |
My Impreza GF8 EJ25 spec | Bill Shih | Member's Car Gallery | 154 | 02-06-2004 10:11 PM |
EJ25 specs? | FLUBYUx2 | Normally Aspirated Powertrain | 1 | 02-02-2001 04:48 PM |
