12-15-2013, 08:37 PM | #20001 | |
Member#: 316869
Vehicle:2012 Impreza Sport Dark Gray |
I also dont have the best memory so if you figure out a different way to do it where you dont have to turn off the fogs when you turn the car off, then that would be fantastic.
12-15-2013, 08:57 PM | #20002 | |
Member#: 372100
Vehicle:2013 Premium 5dr CVT DGM |
Oh, and I wouldn't use h9's for fogs. 2100 lumens is too much light to shine on the ground, it would probably produce a lot of glare, imho. I'd stick with the 1350 lumens from the h11's, that's almost double the output of the stock fogs. |
12-15-2013, 09:23 PM | #20003 | |
Member#: 314216
Vehicle:2012 2.0i Sport 5MT DGM |
There are a few other relays in the same location and I'm sure some of them have switched power, so they could be tapped off. I don't usually leave my fogs on unless required, so I'm pretty good about making sure they are off, but I might forget someday, so a different source would be nice for the trigger side of the relay. I might get back down there and look, that side is much easier than the drivers side. If I do before anyone else I will post the update. |
12-15-2013, 10:24 PM | #20004 |
Member#: 92967
SCIC
Vehicle:2007 Legacy gt Black |
12-15-2013, 11:10 PM | #20005 |
Member#: 352158
NESIC
Vehicle:2012 Impreza Metallic Grey |
Yea mine uses the factory bluetooth but best buy threw the microphone on the windshield so it has better quality sound. I don't know of anything that's plug in and play honestly. I just picked up a cheap pioneer deck that was $200 One of the AVH series and had best buy install it then I went home and threw a bypass on it. Without a bypass from microbypass.com it looks like crap because you stare at a blue screen while you're driving. The blue screen tells you to engage the parking brake to be able to use diff functions while you are driving. I don't watch video when I drive i just cant stand that stupid blue screen.
12-15-2013, 11:13 PM | #20006 |
Member#: 352158
NESIC
Its nice when you have bluetooth mode on the pioneer deck I literally play anything on my phone and i can hear the sound through my car speakers. I put the police scanner/CB app on and it feeds through my speakers.
12-16-2013, 10:26 AM | #20007 |
Member#: 323103
Vehicle:2018 WRX Pure der |
So my car used to squeak a little bit during humid mornings, but now its been a couple months since it started. The problem has gotten worse and the belt squeak/squeal happens almost every morning until the car is warm. Its at 55k miles, and I have extended warranty, but I doubt Ill be able to reproduce the sound at the dealer.
Is there an easy way to add tension to the belt? Would that even help? |
12-16-2013, 10:38 AM | #20008 |
Member#: 319157
Vehicle:2012 Impreza 4DR 5MT |
Myrt, are you referring to the accessory drive belt?
12-16-2013, 01:33 PM | #20009 |
Member#: 302570
Vehicle:2013 XV DGM! |
Has anyone else's auto up/down window switch quit working?
12-16-2013, 01:57 PM | #20010 |
Member#: 324017
Vehicle:2012 Impreza 2.0i Ice Silver Metallic |
I think that happens when the battery is disconnected. There's a procedure to reset it and make it work again in the manual. You have to roll the windows up and down a few times, holding the switch for a few seconds after it finishes going up/down, or something like that.
12-16-2013, 02:32 PM | #20011 |
Member#: 334126
Vehicle:2016 2.5i Premium MT Dark Gray Mettallic |
auto up down and the annoying seat belt chime all have to be redone after you disconnect battery
12-16-2013, 03:47 PM | #20012 |
Member#: 306398
Vehicle:2012 Impreza Premium Camellia Red |
The window procedure is in the manual. I'd have to browse through the thread for the seat belt one. I need to remember to redo that.
12-16-2013, 03:55 PM | #20013 |
Member#: 345877
Vehicle:2013 Impreza Sport Ice Silver |
What resets with the seatbelt chime?
I'm doing my battery soon and just want to know what to look for.. lol |
12-16-2013, 06:24 PM | #20014 |
Member#: 89967
NESIC
Vehicle:2020 Volvo S60 Gray |
To fix the seatbelt I believe you plug and unplug the the seat belt continuously for about 30-35 seconds.
12-16-2013, 06:35 PM | #20015 |
Member#: 345877
But by not doing it the seatbelt won't beep if it's not plugged in? lol
12-16-2013, 07:40 PM | #20016 |
Member#: 323103
Idk, you tell me. lol The engine starts squeaking like an old junker. I assumed it was the belt. I guess the car isn't exactly new anymore, but I feel like I just bought the damn thing and it sounds 10 years old.
12-16-2013, 08:14 PM | #20017 |
Member#: 319157
If that's the case, your belt and pulleys might be glazed. The slippage causes them to polish each other, causing more slippage. I had a car with this problem, and a brand new OEM belt squeaked. Installing a Goodyear Gatorback belt solved it. It has a different groove pattern and a rougher compound than OEM belts. Don't apply any sort of lubricant or treatment to the belt or pulleys.
12-16-2013, 08:23 PM | #20018 |
Member#: 323103
I see, not such an easy fix. Well now I just have to research how to remove and install a new belt.
12-17-2013, 12:51 AM | #20019 |
Member#: 314216
just watched the video on the new WRX....gotta admit, kinda want...
12-17-2013, 01:10 AM | #20020 |
Member#: 345877
Was totally thinking that. I thought it was ok when I first saw it, but was mostly turned off there was no wagon. I'm hoping for an STI version shortly after. I should be down on what I owe on mine enough to try and pick one up.
12-17-2013, 04:44 AM | #20021 |
Member#: 322264
Vehicle:2012 Impreza Sp 5sp Obs Blk Prl/Drk Gray Mtl |
12-17-2013, 06:54 AM | #20022 |
Member#: 317014
Vehicle:2017 Crosstrek ISM |
12-17-2013, 06:58 AM | #20023 |
Member#: 314216
12-17-2013, 07:59 AM | #20024 |
Member#: 302570
The "new" sti is supposedly going to have an ej engine.
12-17-2013, 10:11 AM | #20025 |
Member#: 372100
Yeah, if you believe what DBL_TKE said. He might not have been the first to say it, but he sure got everyone believing it before he disappeared.
He also said that the seats suck and that every model has LED headlights. He could be right, but I think he was just trolling... |
Possibly looking into a 2011 or 2012 Impreza? | xenonk | Mid Atlantic Impreza Club -- MAIC | 2 | 03-08-2020 05:34 PM |
2012 Impreza STI concept art | khaki_man | Member's Car Gallery | 37 | 03-15-2011 02:02 AM |
Newsflash: 2012 Impreza looks like BigElm's Butt | WagonMonster | Off-Topic | 4 | 02-28-2011 07:11 PM |
2012 Impreza Concept | Zakster87 | General Community | 14 | 11-17-2010 04:09 PM |
