11-13-2012, 01:50 PM | #1 |
Member#: 218475
TXIC
Vehicle:2007 CGM STI |
Differential or axle problem???
Hey it's been a while since I been on this site. My 07 STI has a problem up front, basically at low speeds it feels quite wobbley and it pulls hard to the right at full throttle. If I put my DCCD all the way to the rear it goes away. Does anyone know what this could be? Pm me or email me at j.saa.engratgmail.com
11-13-2012, 02:11 PM | #2 |
Member#: 284792
RMIC
Vehicle:2011 STI Blurple |
Snip.
11-13-2012, 04:34 PM | #3 |
Member#: 234397
Vehicle:2004 WRX STI WRB 15 DGM FXT |
axle sounds like to me up front.
11-16-2012, 09:45 AM | #4 |
Member#: 149262
Vehicle:03WR rallycarFXTleg PrimerGrey |
Whatever it is be careful not to make it worse by hammering the throttle
11-25-2012, 01:30 PM | #5 |
Member#: 218475
TXIC
Thanks for the advice y'all. I appreciate any more info on things I can look for while under the car or things like that...
11-26-2012, 02:20 AM | #6 |
Member#: 139816
Vehicle:2019 Impreza White |
sounds like there may be something wrong with the front diff. sounds like its trying to send power to the other wheel but its having trouble.
11-26-2012, 03:12 AM | #7 |
Member#: 100300
Vehicle:06 WRX CGM |
Sounds like torque steer up front. Is one of the front half shafts disconnected or broken?
11-26-2012, 11:07 AM | #8 |
Member#: 218475
TXIC
Thanks for the info I'm gonna take a look at it this weekend.
11-26-2012, 03:38 PM | #9 |
Member#: 65133
Also check for play in the steering system and ball joint. Having the right front wheel with extra play could cause the wheel torque off in a direction when power or torque is pushed through it. Have you hit anything recently with the right side?
11-29-2012, 09:40 AM | #10 |
Member#: 218475
TXIC
Thanks ill look into it, and no I haven't hit anythin..
03-26-2013, 10:06 PM | #11 |
Member#: 218475
TXIC
Bump need advice!
03-26-2013, 10:29 PM | #12 |
Member#: 280572
E. Canada
Vehicle:2011 sti sedan plasma blue pearl |
If u have checked everything over and everything is good when was the last time u had an alignment done. Toe could be out which can cause pulling to one side or the other.
Have a look at your tires to see if there is uneven or excessive tire wear. |
03-26-2013, 10:42 PM | #13 |
Member#: 218475
TXIC
If it was an alignment issue, would it make a slapping sound, and wobbly feeling at low speed, when the torque is evenly split?
03-26-2013, 11:17 PM | #14 | |
Member#: 280572
E. Canada
How old is your suby plus mileage. Have u checked your bushings also. Is the slapping sound feel like metal on metal?? Could be an axle if its making a clicking sound if that's what you mean by slapping sound |
03-27-2013, 07:09 AM | #15 | |
Member#: 218475
TXIC
03-27-2013, 07:10 AM | #16 |
Member#: 218475
TXIC
Another piece of info is that firestone(where I take my car for lifetime alignment told me sometime ago I need to replace my camber bolts in order to properly align it anymore, which I never did).
03-27-2013, 07:29 AM | #17 | |
Member#: 280572
E. Canada
There's bushings all over in your suspension, have a look where every part meets one another take a bar and pry in between to see if there excessive movement and deep cracks in the rubber. |
03-27-2013, 07:34 AM | #18 | |
Member#: 280572
E. Canada
If this is the case u need to raise your suby up a little higher. Last edited by trev762; 03-27-2013 at 06:15 PM. |
03-27-2013, 01:00 PM | #19 |
Member#: 218475
TXIC
No I'm not lowered
03-27-2013, 02:32 PM | #20 |
Member#: 124254
Vehicle:2006 06 SGM Slowbaru "The Scoobinator" |
03-27-2013, 03:00 PM | #21 |
Member#: 280572
E. Canada
03-27-2013, 05:54 PM | #22 |
Member#: 218475
TXIC
Wow counterfit, no need for that Bs. I just need some advice.
05-30-2013, 02:42 PM | #23 |
Member#: 218475
TXIC
For anyone who cared, or has the same problem, it was the passenger side front differential roller bearing. Some how it warped, and it looks like it is due to someone bottoming out pretty bad. Car is fixed now, and drives perfectly again. Hope this helps!
