12-05-2003, 07:27 AM | #1 |
Member#: 11669
Vehicle:Evo IX 345 WHP |
What parts in addition to turbine wheel to convert....
What parts do I need in addition to a TD06H turbine wheel to convert my TD05H(7cm2)-20G to TD06H(7cm2)-20G?
What sort of change in spool up would you expect? 500 RPM? Does the turbine wheel come attached to a shaft and is it the same size as the one I have? Presumably there is adequate material in the 7cm2 housing to remove to accommodate this wheel? I was thinking about the 06H rather than the 06 because I saw a report on here which said that the 06H had no loss of spool.
12-05-2003, 08:13 AM | #2 |
Member#: 23015
Vehicle:95-> GC8 Black, blue and blue |
The turbine is a turbine/shaft single part.
Turbine seems to make a bigger difference to power ceiling than housing on the garrett turbos. Maybe it's time to get a bigger turbo after all! It's only been a week, PMSL! Paul |
What time in 03 did subaru change to widers gearsets. | jstam | Transmission (AT/MT) & Driveline | 2 | 08-06-2008 08:54 PM |
What to do in addition to timing belt | 94'325is | Service & Maintenance | 1 | 05-12-2008 09:03 PM |
What does an 8cm turbine equate to in AR terms? | Andrew | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 35 | 02-09-2007 09:52 AM |
If you were to get a night time, part time job in addition to your fulltime work.... | Snoopy | Off-Topic | 50 | 11-15-2006 11:23 PM |
Parts in Hong Kong? Need help to find! | nemowrx | Vancouver Impreza Club Forum -- VIC | 6 | 05-20-2002 09:25 PM |
