04-24-2004, 08:21 PM | #1 |
Member#: 28546
BAIC
Vehicle:00 BMW M Coupe Silver |
Help replacing factory boost gauge - please
Wanting to replace the factory boost gauge in an '04 STi... Was looking at a VDO gauge...
Question 1: what is the measurement/interface with the factory gauge? Q2: Anyone know of any compatible gauges? Q3: The units of measurement on the factory gauge are not the same as the available VDO gauges... will that matter? Will I need to swap out senders altogether? Please considering pardoning my major ignorance... Any help you can offer is appreciated. D!
04-24-2004, 08:27 PM | #2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
The factory gauge is a mechanical unit, there is no sender- just the vacuum line that connects to it from the engine. If you get another mechanical gauge you can plug the same line into it.
The gauge is a 42mm size. You can get an Omori 45mm gauge and make it fit into the stock pod on the steering column, many have done this. As for the units of measurement, the stock gauge uses metric units (mPA) whereas most aftermarket gauges use SAE units (PSI), but as long as you know how to interpret the readings it really doesn't matter. |
04-24-2004, 08:32 PM | #3 |
Member#: 28546
BAIC
Thanks Mulder...
I am scrapping the stock boost gauge/housing in favor of the cleaner gauge cluster bezel (the one that integrates a gauge into each lower extremity of the instrument cluster area). I will incorporate an oil temperature gauge into the other spot... VDO offers red lighting - though I'd prefer amber to match the dash - but I'm still looking... My bimmer has amber lighting and those gauges are VDO, so maybe I'll have to keep looking... |
04-24-2004, 08:50 PM | #4 |
Trust no one
Ok, if you aren't re-using the housing then any gauge will work. As I said if it's mechanical you can just hook the existing hose to it. If it's electrical with a remote sender the line gets connected to the sender.
Factory boost gauge install help needed | nayr924 | Interior & Exterior Modification | 3 | 09-24-2007 11:52 PM |
Factory Boost Gauge replacement in psi? | GTO PHIL | Newbies & FAQs | 14 | 01-09-2006 07:36 PM |
turbo timer boost gauge install w/ factory boost gauge | Blakestyle521 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 10-21-2004 10:19 AM |
Factory boost gauge help | zojirushi | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 08-13-2003 12:42 PM |
Found problem with tube to factory boost gauge- please help | GregH | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 06-15-2002 09:39 PM |
