Old 05-17-2013, 01:06 AM   #1
FastWrxWagon87
Member#: 333346
Default 02 Wrx 245/45/17
How do I stop the wheel from rubbing on the spring/shock?
FastWrxWagon87 is offline   Reply With Quote
Old 05-17-2013, 01:08 AM   #2
FastWrxWagon87
Member#: 333346
Stiffer shock and spring or coil-over kit?
Old 05-17-2013, 02:08 AM   #3
bako
Member#: 226211
2002 impreza WRX JDM
blue
less camber or wheel spacers
bako is offline   Reply With Quote
Old 05-17-2013, 03:41 AM   #4
JonnyV2889
Member#: 197384
2006 WRX Ltd
This ^
If you need to clear the fender and don't want to do more fender work, you're looking at camber plates as well.
JonnyV2889 is offline   Reply With Quote
Old 05-17-2013, 07:51 AM   #5
JarHarms
Member#: 138994
2006 WRX, 6MT, 5x114
Seriously - First off "front", "rear", or "both"? Confirm that it is the "wheel" or the "tire" that is making contact with "what location" on the strut housing. And why not funish your wheel (width and offset) and current alignment specs? Did it rub before? Are these new wheels or tires of a differnt size than before? Did you change the suspension recently? If you want useful suggestions then offer up some extra info......
Not as serious - Don't drive the car and it won't rub anymore.
Old 05-17-2013, 09:16 AM   #6
MD04WRX
Member#: 72891
2018 STI
99 2.5RS 2dr - 2017 XV
Plus a 245-45 is too tall.
MD04WRX is offline   Reply With Quote
Old 05-17-2013, 09:24 AM   #7
Robin2
Member#: 390
2020 Forester Sport
Dark Grey
Big tire for sure. I have that size on 11wrx and it's fine. for 02-07wrx, it will rub.
should bought 245-40-17 instead.
Robin2 is offline   Reply With Quote
Old 05-17-2013, 08:27 PM   #8
FastWrxWagon87
Member#: 333346
Its rubbing on the the upper shock plate that houses the spring, rubs both front and back
Old 05-17-2013, 08:29 PM   #9
FastWrxWagon87
Member#: 333346
I just have the tires laying around and need a quick wheel tire swap for a trip but they look so good I would like to do some suspension work to avoid further rubbing
Old 05-17-2013, 08:31 PM   #10
FastWrxWagon87
Member#: 333346
Its the tires rubbing in the front and back on the lower-side of the top of the shock or spring housing
Old 05-17-2013, 08:33 PM   #11
cartwheels4amile
Member#: 190405
1991 Legacy Turbo
Pearl White
Trust me, you're doing more damage than good trying to get these to fit. I know because I briefly ran a set of tires this large on my 02. Your wagon has even less clearance than my sedan, and while the tires did look good (very meaty) they are too tall, and ruin the final drive ratio of the car. You should have noticed that it feels slower than usual. Do yourself a favor and source some 215/45/17 or 235/40/17 tires. If you can't find those, 225/45/17 will work in a pinch (that's what I run, and what came stock on the 04-07 STI). Good luck.
cartwheels4amile is offline   Reply With Quote
Old 05-18-2013, 01:41 AM   #12
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
yew got the wrong tires on the wrong wheels
Old 05-18-2013, 07:18 AM   #13
JarHarms
Member#: 138994
This plus you're not going to feasibly fix that without changing the wheels and/or tire size. Don't waste effort on the trying to fix it via your suspension.
Old 05-18-2013, 04:29 PM   #14
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
If it's really close to not rubbing, you can get 3mm wheel spacers.
245/45 is a pretty bad size for performance on the stock 2.0L unless you have a short ratio transmission or are using them in a situation you'll always be over 3500 RPM. It's also a difficult size to fit into the GD rear. 8" wide wheels work, may need a fender roll for high-ish offset, but 235/45 is a better size for 8" wheels. 9" wheels are much tighter. You need to be real careful about offset and fender clearance, as you have already noticed.
245/40 is a full inch smaller diameter, essentially the same diameter as stock. It fits better and is a better height for gearing as well, so most who want 245 will choose 245/40.
