Brakes & Suspension Forum sponsored by The Tire Rack |
04-14-2001, 12:59 AM | #1 |
Member#: 1954
Vehicle:1997 Impreza L/WRS WRB |
high performance wheel bearings
Is there such a thing for our car?
if so: were? and how much? thanx! |
04-14-2001, 11:16 AM | #2 |
Member#: 1954
come on!!!!!!!!
04-14-2001, 11:21 AM | #3 |
Member#: 4110
BAIC
Vehicle:04 FXT PSM |
I would also like to know about this. I have had wheel bearings blow out and have had to have them repacked $$$$$. It would be an especially important topic if your car sees a lot of dirt. Any Ideas, I would expect some sort of answer from the rally people (SubieGal, etc.)
-Brian |
04-15-2001, 12:19 AM | #4 |
Member#: 1954
bump
04-15-2001, 05:43 AM | #5 |
Member#: 865
Vehicle:2003 BMW M3 Phoenix Yellow |
I will ask Lance at Vermont Sports Car when I talk to him on Monday. This is of interest to me also as I will be putting on spacers and 8.5" rims soon.
Kurt |
04-15-2001, 07:49 AM | #6 |
Member#: 2643
Vehicle:2001 2.5 RS BRP |
All,
The folks at Prototype Technology Group (PTG) that campaigns a BMW M3 take new bearings and pack them with synthetic grease instead of the standard stuff. The higher "stress" capabilities of the grease help them last longer. Simple as that! Mike Gayle |
08-19-2004, 09:36 PM | #7 | |||||
Member#: 58882
04-15-2001, 06:30 PM | #8 |
Member#: 1426
NESIC
Vehicle:'07 335xi,14 Tundra 848 Evo Race Bike |
Unfortunately it's not as simple as that. Subaru released a set of bad bearings to the public and then had to come up with a process for measuring the defective parts. Ask any of your Subaru technicians and they'll take you through the measuring process. I'm not saying the synthetic grease won't help, because it will, but just be aware that these bearings are defective and will fail on a regular basis.
Fitz |
04-15-2001, 06:40 PM | #9 |
Member#: 1954
My point exactly. It's not like bearings are rare, and it's not like companies that make wheel bearings are rare. But what is a good company to go with to make some custom reeel fast wheel bearings.
I have two bearings on the right side of my car in which I just destroyed. I've been forced to drive with them for some time. It's anyoning and I can't drive faster than 45(max speed is going down.) |
04-15-2001, 10:09 PM | #10 |
Member#: 1512
Vehicle:99 2.5RS Rally Blue and Black |
I might be wrong, but the Subaru bearings probably aren't made by Subaru. I say "might be wrong" because FHI might own a bearing company.
Anyway, Timken, NHBB, etc. are good bearing companies and might have a bearing with the same physical dimensions. If anyone has the dimensions of the bearings, I'd be glad to cross reference. There are stacks of bearing catalogs at work. If there's a part number (not Subaru's, the bearing manufacturer's), that would be even better. -Steve [email protected] |
04-15-2001, 10:23 PM | #11 |
Member#: 4866
what do wheel bearings do and were are they located? at the axle shaft? near the diff? thanks
peace |
04-15-2001, 11:29 PM | #12 |
Member#: 1954
hey stever,
can you get F1 bearings I won't know what the number is or if it is even recognizable, because it's been so long since I replaced the brocken ones (still on my car). There are like 4-6 bearings on the subaru per axle (including the cvjoint axle bearings and diff-to-axle bearings) the ones I want are in between the hub and knuckle. if that doesn't work, I'll have hell to pay (litterally). |
04-16-2001, 01:24 PM | #13 |
Member#: 865
I talked to Lance at VT Sports Car today and he said that they just use stock WRX hubs for their rally cars. They are rebuilt after every race and they use neo bearing grease. I don't know what that grease is.
Kurt |
04-16-2001, 06:55 PM | #14 |
Member#: 2532
South East
Vehicle:2001 2.5RS-T BRP |
We recently put some ceramic wheel bearings in a drag race bike at work. They were $100 each so $500 for front and rear wheels. They are suposed to give 1-2 mph in the 1/4.
04-16-2001, 09:43 PM | #15 |
Member#: 4934
MWSOC
Vehicle:2007 White STI LTD Grey Mazda 5 |
BMW bearings are made my ***, a bearing company called ***. Seriously though, a high performance wheel bearing? Come on, use the stock ones how can a "performance bearing" help anything? If you drive hard they wear out faster, that's just the cost of racing. As long as they aren't defective as was said before, you should be fine for a long time.
04-17-2001, 03:19 AM | #16 |
Member#: 3069
Hey man you got **** behind your wheels?
You know its funny! |
04-17-2001, 08:35 PM | #17 |
Member#: 1512
There are differences in bearings. Typically, you'll find a few bearings in exactly the same size, but with different load capacities. It all depends on the alloys used, heat treatment, tolerances, etc. Rod ends are the same way. You can get cheap ones for less than $20 each, but the same size in a decent bearing will be over $50. The load capacity will be way higher and there won't be nearly as much slop.
Anybody know if Schumacher's Ferrari had Subaru wheel bearings -Steve [email protected] |
04-18-2001, 05:59 PM | #18 |
Member#: 699
Vehicle:2002 golf TDI Blue |
NEO bearing grease is a brand of synthetic grease available from Baker Enterprises, Signal Hill CA
Similar Threads | ||||
Please Explain High Performance vs Ultra High Performance Tires. | andyfish | Tire & Wheel | 10 | 02-04-2005 12:52 AM |
Enkei High Performance Wheel Groupbuy | importhookup | Vendor 'Group Buy' Classifieds | 9 | 07-09-2004 03:55 PM |
Enkei High Performance wheels!! | NinosAutoAccesories | Wheels/Tires | 40 | 04-20-2004 10:56 AM |
High pitched squeal and excessive heat from right rear - wheel bearing? | TimStevens | Brakes, Steering & Suspension | 6 | 08-04-2003 01:15 PM |
High performance Low Weight Wheels | Jimmer | Motorsports | 7 | 12-07-2001 02:42 PM |
